I have an application the essentially does the following
1) Engine_open
2) Do some processing
3) Engine_close and exit the application.
I run this application over and over, but sometimes the application fails with the error posted below. After this I always need to reboot the board. How do I root cause this issue?
App-> DEVNODE THREAD STARTED.
@4,315,001us: [+0 T:0x41efa490 S:0x41ef9d5c] OG - Global_atexit> enter (fxn=0x31780)
@7,315,331us: [+0 T:0x41efa490 S:0x41ef9d64] CE - Engine_open> Enter('CodecEngine', 0x0, 0x41ef9dfc)
@7,315,484us: [+0 T:0x41efa490 S:0x41ef9d34] OM - Memory_alloc> Enter(0x34)
@7,315,514us: [+0 T:0x41efa490 S:0x41ef9d34] OM - Memory_alloc> return (0x67d08)
@7,315,606us: [+0 T:0x41efa490 S:0x41ef9cdc] CE - rserverOpen('devnodeServer.x64P'), count = 0
@7,315,636us: [+0 T:0x41efa490 S:0x41ef9c9c] OP - Processor_create> Enter(imageName='devnodeServer.x64P', linkCfg='(null)', attrs=0x41ef9d34)
@7,315,759us: [+0 T:0x41efa490 S:0x41ef9c6c] OM - Memory_alloc> Enter(0x24)
@7,315,789us: [+0 T:0x41efa490 S:0x41ef9c6c] OM - Memory_alloc> return (0x67d40)
@7,315,850us: [+0 T:0x41efa490 S:0x41ef9c74] OP - doCmd> Enter (cmdId=1, proc=0x67d40)
@7,315,881us: [+0 T:0x41efa490 S:0x41ef9c64] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x671c0]
@7,315,942us: [+0 T:0x40af3490 S:0x40af2d5c] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x671c0] status[0]
@7,315,972us: [+0 T:0x40af3490 S:0x40af2d84] OP - getCmd_d> Exit (result=1)
@7,316,033us: [+0 T:0x40af3490 S:0x40af2d5c] OP - Processor_create_d> Enter(proc=0x67d40)
@7,316,064us: [+0 T:0x40af3490 S:0x40af2d3c] ti.sdo.ce.ipc.Power - Power_on> Enter(handle=0x67d5c)
@7,316,094us: [+2 T:0x40af3490 S:0x40af2d3c] ti.sdo.ce.ipc.Power - Power_on> Opening Local Power Manager for the DSP on /dev/lpm0...
@7,316,186us: [+2 T:0x40af3490 S:0x40af2d3c] ti.sdo.ce.ipc.Power - Power_on> Turning on DSP power...
@7,595,122us: [+7 T:0x40af3490 S:0x40af2d3c] ti.sdo.ce.ipc.Power - Power_on> Turning on DSP power FAILED
@7,595,213us: [+2 T:0x40af3490 S:0x40af2d3c] ti.sdo.ce.ipc.Power - Power_on> return (1)
@7,595,274us: [+6 T:0x40af3490 S:0x40af2d5c] OP - Processor_create_d> Power_on failed.
@7,595,305us: [+2 T:0x40af3490 S:0x40af2d5c] OP - Processor_create_d> return (0)
@7,595,335us: [+0 T:0x40af3490 S:0x40af2d7c] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x671d8]
@7,595,366us: [+0 T:0x40af3490 S:0x40af2d7c] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x671d8]
@7,595,396us: [+0 T:0x40af3490 S:0x40af2d84] OP - getCmd_d> Enter (proc=0x40af2dec)
@7,595,427us: [+0 T:0x40af3490 S:0x40af2d5c] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x671c0] timeout[0xffffffff]
@7,595,488us: [+0 T:0x41efa490 S:0x41ef9c64] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x671c0]
@7,595,518us: [+0 T:0x41efa490 S:0x41ef9c4c] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x671d8] timeout[0xffffffff]
@7,595,549us: [+0 T:0x41efa490 S:0x41ef9c4c] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x671d8] status[0]
@7,595,579us: [+0 T:0x41efa490 S:0x41ef9c74] OP - doCmd> Exit (result=2)
@7,595,610us: [+0 T:0x41efa490 S:0x41ef9c8c] OP - Processor_delete> Enter(proc=0x67d40)
@7,595,640us: [+1 T:0x41efa490 S:0x41ef9c8c] OP - Processor_delete(0x67d40) freeing object ...
@7,595,701us: [+0 T:0x41efa490 S:0x41ef9c64] OM - Memory_free> Enter(0x67d40, 0x24)
@7,595,762us: [+0 T:0x41efa490 S:0x41ef9c64] OM - Memory_free> return (0x1)
@7,595,793us: [+0 T:0x41efa490 S:0x41ef9c8c] OP - Processor_delete> return.
@7,595,823us: [+6 T:0x41efa490 S:0x41ef9cdc] CE - rserverOpen: can't start 'devnodeServer.x64P'; Processor_create failed
@7,595,854us: [+0 T:0x41efa490 S:0x41ef9cdc] CE - rserverOpen('devnodeServer.x64P'): 0x0 done.
@7,595,915us: [+0 T:0x41efa490 S:0x41ef9d0c] CE - Engine_close(0x67d08)
@7,595,946us: [+0 T:0x41efa490 S:0x41ef9ce4] CS - Server_disconnectTrace('0x67d08', 0x0)
@7,596,007us: [+0 T:0x41efa490 S:0x41ef9ce4] CS - Server_disconnectTrace> return(0)
@7,596,037us: [+0 T:0x41efa490 S:0x41ef9ce4] OM - Memory_free> Enter(0x67d08, 0x34)
@7,596,068us: [+0 T:0x41efa490 S:0x41ef9ce4] OM - Memory_free> return (0x1)
@7,596,098us: [+0 T:0x41efa490 S:0x41ef9d0c] CE - Engine_close exit
Segmentation fault
