• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » Multimedia Software Codecs » Multimedia Software Codecs forum » [ISSUE] DVTB failed when decode mpeg4 file with resolution >D1
Share
  • Forum
Options
  • Subscribe via RSS
This question is answered
xiaoyang xie
Posted by xiaoyang xie
on Dec 21 2011 22:03 PM
Intellectual280 points
dvtb_mpeg4_720p_fail.TXT
Hi, experts
Our product development has completed with the H264&mpeg2 part. And now we need to add mpeg4 decode support. I verify the problem by running the dvtb.
Also, I modify the decode demo in the dvsdk_demos_3_10_00_16 to support mpeg4, but it fails at another step(D1 is OK). So I think checking the function in the dvtb is easier.
And I find the dvtb script mpeg4dec2.dvs only supports D1 while h264dec2.dvs supports 1080p. So I don't know whether you have tested the mpeg4 decoding with resolution >D1. Looking forward to your replies.
[Setup]
1. Hardware: DM6467T
2. DVSDK: dvsdk_3_10_00_19
3. Codec: cs2dm6467_1_00_00_10
3. Dvtb version: dvtb_4_20_10
[Test steps]
1. Copy mpeg4dec2.dvs from the script folder and change the input file to a D1 mpeg4 file
2. Run ./dvtb-r -s mpeg4dec2_D1.dvs
3. Modified the max width&height value in mpeg4dec2.dvs and change the input file to a 720p mpeg4 file
setp mpeg4dec2 maxWidth 1280
setp mpeg4dec2 maxHeight 720
4. Run ./dvtb-r -s mpeg4dec2_720p.dvs
[Test results]
2. Decode runs correctly
4. Decode failed at [DVTB-ERROR]: linux/dvtbMpeg4Dec2.c: Unable to initialize Video Decoder
In the log
@5,420,159us: [+6 T:0x41347490 S:0x41346b54] CE - Engine_createNode> Remote node creation FAILED (0x80008008).
[DSP] @5,270,178tk: [+7 T:0x8ba0006c S:0x8ba03d1c] ti.sdo.ce.alg.Algorithm - Algorithm_create> Algorithm creation FAILED; make sure that 1) alg params are correct/appropriate, 2) there is enough internal and external algorithm memory available -- check DSKT2 settings for heap assignments and scratch allocation
TI employee Vincent tell me to ask question in this forum to see if this is a codec issue. My former post is at below link
http://e2e.ti.com/support/embedded/linux/f/354/t/154167.aspx
MPEG4 Davinci 6467
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • xiaoyang xie
    on Dec 21 2011 23:09 PM
    dvtb_mpeg4_d1_OK.TXT
    this is the log decoding D1
    Report Abuse
    • Reply
  • Sayanna Chandula
    Posted by Sayanna Chandula
    on Dec 21 2011 23:32 PM
    Verified Answer
    Verified by xiaoyang xie
    Intellectual1080 points
    You can refer to the MPEG4 decoder data sheet(mpeg4_decoder_dm6467_datasheet.pdf) for the maximum resolution supported. It should be available at CODECS_INSTALL_DIR\packages\ti\sdo\codecs\mpeg4dec\docs.
    The MPEG4 decoder v01.00.00 supports a maximum of PAL D1 (720 x 576) and WVGA (864 x 480) resolutions.
    Sayanna
    Report Abuse
    • Reply
  • xiaoyang xie
    on Dec 22 2011 00:27 AM
    Yes, I find the description now, this version of codec don't support higher resolution.
    I came across this file yesterday but didn't notice this :(
    Report Abuse
    • Reply
  • xiaoyang xie
    on Dec 22 2011 00:53 AM
    And I find out that the latest codec of mpeg4 V1.00.09 also not support resolution >D1.
    It will be a inferiority of our product, as some IP stream we need to decode is 720p and encoded by TI old processor.
    http://software-dl.ti.com/dsps/dsps_public_sw/codecs/DM6467/index_FDS.html
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
