When I use this codec to encode 1080P, the X64P is generated successfully, but when I use it to encode, the result is: the I frame is good, but the size is a little large, but P frame size is 12 byte, such as in 30 frames, ths size is (108290, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12, 12).
My environment is :
DM6467
DVSDK 2_00_00_22
codec_engine_2_26_02_11
xdais_6_26_01_03
bios_5_41_13_42
HDVICP version 1.01.020
The code server config file encode.cfg:
/* set up OSAL */
var osalGlobal = xdc.useModule('ti.sdo.ce.osal.Global');
osalGlobal.runtimeEnv = osalGlobal.DSPLINK_BIOS;
/* configure default memory seg id to BIOS-defined "DDR" */
osalGlobal.defaultMemSegId = "DDR2";
/* Initialize trace buffer size */
osalGlobal.traceBufferSize = 0x40000;
/* Enable DSP-side BIOS logging */
var LogServer = xdc.useModule('ti.sdo.ce.bioslog.LogServer');
* ======== Server Configuration ========
var Server = xdc.useModule('ti.sdo.ce.Server');
Server.threadAttrs.stackSize = 16384;
/* get various codec modules; i.e., implementation of codecs */
var H264ENC = xdc.useModule('ti.sdo.codecs.h264enc.ce.H264ENC')
var H264FHDVENC = xdc.useModule('ti.sdo.codecs.h264fhdvenc.ce.H264FHDVENC');
var AACHEENC = xdc.useModule('ti.sdo.codecs.aacheenc.ce.AACHEENC');
var G711ENC = xdc.useModule('ti.sdo.codecs.g711enc.ce.G711ENC');
/* Linking in the HDVICP Lib module */
xdc.useModule('ti.sdo.codecs.hdvicp.HDVICP');
if (prog.build.cfgArgs.profile == "eval") {
/* This server is for evaluation, so use the watermarked versions */
print("Configuring server to use watermarked codecs...");
H264ENC.alg.watermark = true;
H264FHDVENC.alg.watermark = true;
AACHEENC.alg.watermark = true;
G711ENC.alg.watermark = true;
else
/* This server is for production, so use the actual versions */
print("Configuring server to use original codecs...");
H264ENC.alg.watermark = false;
H264FHDVENC.alg.watermark = false;
AACHEENC.alg.watermark = false;
G711ENC.alg.watermark = false;
H264ENC.alg.codeSection = "DDR2";
H264ENC.alg.udataSection = "DDR2";
H264ENC.alg.dataSection = "DDR2";
H264FHDVENC.alg.codeSection = "DDR2";
//H264FHDVENC.alg.intMemSection = "IRAM";
H264FHDVENC.alg.udataSection = "DDR2";
H264FHDVENC.alg.dataSection = "DDR2";
/* Switching off Outs Bufs Cache */
H264ENC.manageInBufsCache = [true, true, true, true, true, true, true, true, true, true, true, true, true, true, true, true];
H264ENC.manageOutBufsCache = [true, true, true, true, true, true, true, true, true, true, true, true, true, true, true, true];
//H264ENC.manageOutBufsCache = [ false, false, false, false, false, false, false, false, false, false, false, false, false, false, false, false ];
H264FHDVENC.manageInBufsCache = [true, true, true, true, true, true, true, true, true, true, true, true, true, true, true, true];
H264FHDVENC.manageOutBufsCache = [true, true, true, true, true, true, true, true, true, true, true, true, true, true, true, true];
Server.algs = [
{name: "h264enc", mod: H264ENC,groupId:0,threadAttrs: {
stackMemId: 0, priority: Server.MINPRI + 1}
{name: "h264fhdvenc", mod: H264FHDVENC,groupId:0,threadAttrs: {
{name: "aacheenc", mod: AACHEENC,groupId:1,threadAttrs: {
stackMemId: 0, priority: Server.MINPRI + 2}
{name: "g711enc", mod: G711ENC,groupId:1,threadAttrs: {
* ======== DSKT2 and RMAN Configuration ========
* XDAIS Algorithm Memory and DMA allocation
var DSKT2 = xdc.useModule('ti.sdo.fc.dskt2.DSKT2');
DSKT2.DARAM0 = "IRAM";
DSKT2.DARAM1 = "IRAM";
DSKT2.DARAM2 = "IRAM";
DSKT2.SARAM0 = "IRAM";
DSKT2.SARAM1 = "IRAM";
DSKT2.SARAM2 = "IRAM";
DSKT2.ESDATA = "DDRALGHEAP";
DSKT2.IPROG = "IRAM";
DSKT2.EPROG = "DDR2";
DSKT2.DSKT2_HEAP = "DDR2"; /* to allocate internal DSKT2 object */
/* Scratch group 0 */
DSKT2.DARAM_SCRATCH_SIZES[0] = 65536;
DSKT2.SARAM_SCRATCH_SIZES[0] = 65536;
/* Scratch group 1 */
DSKT2.DARAM_SCRATCH_SIZES[1] = 0;
DSKT2.SARAM_SCRATCH_SIZES[1] = 0;
var RMAN = xdc.useModule('ti.sdo.fc.rman.RMAN');
RMAN.useDSKT2 = true;
RMAN.tableSize = 10;
RMAN.semCreateFxn = "Sem_create";
RMAN.semDeleteFxn = "Sem_delete";
RMAN.semPendFxn = "Sem_pend";
RMAN.semPostFxn = "Sem_post";
var EDMA3 = xdc.useModule('ti.sdo.fc.edma3.Settings');
EDMA3.maxPaRams[0] = 384;
EDMA3.maxTccs[0] = 49;
EDMA3.maxTccs[1] = 0;
EDMA3.maxEdmaChannels[0] = 49;
EDMA3.maxEdmaChannels[1] = 0;
EDMA3.maxQdmaChannels[0] = 0;
EDMA3.maxQdmaChannels[0] = 4;
EDMA3.maxQdmaChannels[1] = 0;
EDMA3.regionConfig = "DM6467_Config";
var EDMA3CHAN = xdc.useModule('ti.sdo.fc.ires.edma3chan.EDMA3CHAN');
var HDVICP = xdc.useModule('ti.sdo.fc.ires.hdvicp.HDVICP');
var HDINTC = xdc.useModule('ti.sdo.fc.hdintc.HDINTC');
HDINTC.interruptVectorId_0 = 10;
HDINTC.interruptVectorId_1 = 11;
HDINTC.hdvicpInterruptEventNo_0 = 29;
HDINTC.hdvicpInterruptEventNo_1 = 39;
HDINTC.biosInterruptVectorId_0 = 7;
HDINTC.biosInterruptVectorId_1 = 8;
HDINTC.biosInterruptEventNo_0 = 30;
HDINTC.biosInterruptEventNo_1 = 31;
The encode.tcf is:
* Setup platform-specific memory map, CLK rate, etc.
var mem_ext = [
// will use for cmem: base: 0x87800000 (120MB offset), size: 0x04200000 (66MB)
comment: "DDRALGHEAP: off-chip memory for dynamic algmem allocation",
base: 0x8BA00000,
len: 0x04000000, // 66MB
space: "code/data"
comment: "DDR2: off-chip memory for code and data",
base: 0x8FA00000, // 250MB offset
len: 0x00400000, // 4MB size
space: "code/data"
comment: "DSPLINK: off-chip memory for DSPLINK code and data",
base: 0x8FE00000, // 254MB
len: 0x00100000, // 1MB
space: "code/data"
comment: "RESET_VECTOR: off-chip memory for the reset vector table",
base: 0x8FF00000,
len: 0x00000080,
space: "code/data"
/* Specify the L2 memory setting */
var device_regs = {
l1PMode: "32k",
l1DMode: "32k",
//l2Mode: "32k"
l2Mode: "64k"
var params = {
clockRate: 594,
catalogName: "ti.catalog.c6000",
deviceName: "DM6467",
regs: device_regs,
mem: mem_ext
* Customize generic platform with parameters specified above.
utils.loadPlatform("ti.platforms.generic", params);
* Enable heaps and tasks
bios.enableMemoryHeaps(prog);
bios.enableTskManager(prog);
* Create heaps in memory segments that are to have heap
bios.DDR2.createHeap = true;
bios.DDR2.heapSize = 0x00040000; // 256K
bios.DDRALGHEAP.createHeap = true;
bios.DDRALGHEAP.heapSize = bios.DDRALGHEAP.len;
* GBL
prog.module("GBL").ENABLEALLTRC = false;
prog.module("GBL").PROCID = 0;
bios.MEM.instance("IRAM").base = 0x11818000;
bios.MEM.instance("IRAM").len = 0x18000;
bios.MEM.instance("CACHE_L2").base = 0x11818000+0x18000;
bios.MEM.instance("CACHE_L2").len = 0x8000;
prog.module("GBL").C64PLUSCONFIGURE = true ;
prog.module("GBL").C64PLUSMAR128to159 = 0x0000ffff;
* HWI
bios.HWI_INT4.interruptSelectNumber = 16
bios.HWI_INT5.interruptSelectNumber = 17
* MEM
prog.module("MEM").STACKSIZE = 0x1000 ;
prog.module("TSK").STACKSIZE = 0x1000 ;
* Global Settings
prog.module("MEM").ARGSSIZE = 200;
* Enable MSGQ and POOL Managers
bios.MSGQ.ENABLEMSGQ = true;
bios.POOL.ENABLEPOOL = true;
* Set all code and data sections to use DDR
bios.setMemCodeSections (prog, bios.DDR2) ;
bios.setMemDataNoHeapSections (prog, bios.DDR2) ;
bios.setMemDataHeapSections (prog, bios.DDRALGHEAP) ;
* MEM : Global
prog.module("MEM").BIOSOBJSEG = bios.DDRALGHEAP;
prog.module("MEM").MALLOCSEG = bios.DDRALGHEAP;
* TSK : Global
prog.module("TSK").STACKSEG = bios.DDRALGHEAP ;
bios.TSK.instance("TSK_idle").stackSize = 0x1000;
//Fix for clock
prog.module("CLK").SPECIFYRATE = true;
prog.module("CLK").INPUTCLK = 148.5;
* Generate configuration files...
if (config.hasReportedError == false) {
bios.MEM.instance("IRAM").createHeap = 1;
//bios.MEM.instance("IRAM").heapSize = 0x18000;
bios.MEM.instance("IRAM").heapSize = 0x10000; //64k
bios.MEM.instance("IRAM").enableHeapLabel = 1;
bios.MEM.instance("IRAM").heapLabel = prog.extern("IRAM_HEAP", "asm");
// !GRAPHICAL_CONFIG_TOOL_SCRIPT_INSERT_POINT!
prog.gen();
what may cause such a situation.
Thanks.
