I am trying to use SIO module on DSP/BIOS 5.42.0.07 and CCSv5 for a DSP C5535, but when I open Tconf and select SIO. Insert SIO is greyed out.
Is SIO module supported on BIO 5.42.0.07 for C5535?
Is there a way to enable it?
Thanks in advance.
Thanks in advance.
Hi Diego de la Cruz,
Yes, this is supported. I think the problem is probably that you don't yet have a driver in your configuration. For example, I'm able to create a SIO instance if I first right click on DGN (under "Device Drivers") and then click "insert DGN."
After that DGN instance is added, I can then right click on SIO and "insert SIO" is not greyed out.
Steve
