Ethernet Forum Guidelines
Welcome to the Ethernet Forum.  In order to facilitate getting help from this forum, please:
1)  Searching the forum for an existing answer to your question might be the quickest and easiest path to an answer.
2) Start the Subject line with the part number, followed by a short description of what the post is about.  This helps the other members in the forum understand the basic content of your question or problem.  The part number is important because it increases the probability that someone who has worked with that specific IC will see your post and be able to assist.
3) Please use tags for your posts.  Include the part number in question plus additional key words such as "DP83848, 1000Base-T, auto-negotiation, etc." The tags improve future search functionality and will help others find the post if it is relevant to their problem.
4) If you are satisfied with the answer, PLEASE mark click "Verify Answer".
