• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » High Speed Interface » High Speed Interface Forum » Product recommondation - 200Mbit 5m rough neighbourhood - SR#:1-778289320
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 1 day ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 5 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 6 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
This question is not answered
Michael M.
Posted by Michael M.
on May 24 2012 08:55 AM
Expert4990 points
Hi all,
a customer is searching for a solution. Please read below.
We are designing a data link between two boards. It is going to be used in a very rough neigbourhood, inside a power electronics converter, a high voltage motordrive inverter.
The distance between the boards just a few meters, but there is going to be severe common mode noise voltages between the boards.
We are planning to use Cat5 Ethernet cables, and Ethernet transformers in both ends, in order to handle the common mode voltages.
We cannot use Ethernet PHY, because we must have full control of the encoding and decoding in the FPGA's on each board.
We use this datalink to obtain tight synchronism between the boards. Optical fiber is not an option here, but we are going to use that elsewhere.
Data rate is 100 Mbit/s (Manchester coding => 200 Mbit/s.)
Do you have any suggestions on how to make such a communication link?
LVDS differential signaling would be ideal, but we need isolation transformers due to the common mode voltages in our system. LVDS also use signal level, in the 100 mV region. While we would have signal levels in the 1V range, in order to increase the noise margin.
Emitted noise is not an issue here, immunity is. I have been looking at M- LVDS and PECL transceivers, but I haven't seen any application information where they are used with transformers.
Is it a good idea to use those with transformers?
I have also considered putting two or more M-LVDS transmitters in parallel, in order to beef up the signal level. Is this a good idea?
Which interface devices do you recommend here?
One alternative is to use the CLCL001 as transmitter. It seems to be able to drive cables. The DS90LV001 could be used as receiver.
How would CLCL001 like to see Ethernet transformers in each end of the cable?
 We have also looked at DS15EA101 and DS15BA101.  Is it a good idea to use such fast devices?  How would these like to see transformers in the cable ends?
 The datasheet for DS15EA101 says that Transformer coupling is not supported.  Why? What is hidden there? How would it work if there were transformers there anyway.
(We are planning to use 5- 10 meter cat5 cable and 1000BASE-T transformers with 1,5 kV insulation, Pulse Engineering HX5004NL  We hope that the high insulation voltage will give low capacitance between the windings.)
Any ideas?
regards,
Michael
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Michael M.
    on Jun 12 2012 07:45 AM
    Expert4990 points
    Any Idea on this?
    Michael
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
