F25M35XX ISO controlCard release 1.0 and 2.0 difference?
Hi I just purchased a new C2000 Microcontrollers development kit and im having some problems connecting and loading the code. I know the cofiguration is fine because it works on my older microcontroller. I noticed the new one is release 2.0 and the old one is release 1.0 The first error I get when connecting target is that its held in reset mode. If I click retry it seems to get past that. Then as soon as I try and load the program I get the error thats seen below. This is with loading the file RT-SineFIRFFT given by TI.
Cortex_M3_0: Loader: One or more sections of your program falls into a memory region that is not writable. These regions will not actually be written to the target. Check your linker configuration and/or memory map.
Cortex_M3_0: Trouble Setting Breakpoint with the Action "Terminate Program Execution" at 0x20baa4: (Error -1066 @ 0x20BAA4) Unable to set requested breakpoint in memory. Verify that the breakpoint address is in writable memory. (Emulation package 0.0.0.0)
Cortex_M3_0: Trouble Setting Breakpoint with the Action "Finish Auto Run" at 0x206c50: (Error -1066 @ 0x206C50) Unable to set requested breakpoint in memory. Verify that the breakpoint address is in writable memory. (Emulation package 0.0.0.0)
CS_DAP_0: Error: (Error -5008 @ 0xFFFFEC70) Unable to access the DAP. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 0.0.0.0)
CS_DAP_0: Error: (Error -5002 @ 0xFFFFEC76) Unable to access the DAP. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 0.0.0.0)
Cortex_M3_0: Error: (Error -1044 @ 0xFFFFEC70) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 0.0.0.0)
Cortex_M3_0: Error: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 0.0.0.0)
C28xx_0: Error: (Error -1135 @ 0x3FFEAD) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.0.681.0)
C28xx_0: Error: (Error -1044 @ 0x0) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.0.681.0)
