I tried to implement a example to configured the adc in a TMS570LS4357, but I have many problems during my programation.
First, I tried use other channel and other adc group. I use the ADC 2 and the pin 19. I configured the adc in HALCode like a image
But when I activated the pin 19, the time is in 0, no change like in the example
And when I program the code the MCU only wait for the finish of the conversion. I use the same configuration (adc 1 and pin 9), bbut the code do the same, is only wait for the finish of the conversation. I don't know what is the problem.
This is the code that I use:
void main(void)
/* USER CODE BEGIN (3) */
adcData_t adc_data;
adcData_t *adc_data_ptr = &adc_data;
unsigned int j, value;
sciInit();
adcInit();
adcStartConversion(adcREG2, 1U);
//while(!adcIsConversionComplete(adcREG2, 1U));
adcGetData(adcREG2, 1U, adc_data_ptr);
value=(unsigned int)adc_data_ptr->value;
for(j=0;j<8;j++)
command[j]=(value>>28)&15;
if(command[j]>9)
command[j]+=7;
command[j]+=48;
value=value<<4;
sciSend(CPU, 8 , command);
sciSend(CPU, 2, (unsigned char*)"\r\n");
And thanks for your attention
