• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » MSP430F5438 BSL using Serial Comms ...
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • MSP430F5438 BSL using Serial Comms ...
    This question is answered
    Lane Mitcham
    Posted by Lane Mitcham
    on Mar 18 2009 14:57 PM
    Prodigy230 points
    Has anyone successfully used the BSL_Scripter and a Bootstrap Loader interface that uses the TEST, RESET, with TA0.0 & TA0.1 as the serial interface?
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • old_cow_yellow
      Posted by old_cow_yellow
      on Mar 21 2009 11:34 AM
      Guru25735 points
      It works for me. But I did not test all the features and limitations as stated in the readme file.
      Report Abuse
      • Reply
    • Lane Mitcham
      on Apr 21 2009 06:58 AM
      Verified Answer
      Verified by BrandonAzbell
      Prodigy230 points
      I finally figured out that the batch of chips that I was using had the BSL disabled.  I got some more samples from TI and all is well.
      Thank you,
      Lane
      Report Abuse
      • Reply
    • BenH
      Posted by BenH
      on Apr 21 2009 09:45 AM
      Intellectual300 points
      What what denotes a  chip with the the BSL disabled?
      Report Abuse
      • Reply
    • BrandonElliott
      Posted by BrandonElliott
      on Apr 21 2009 09:47 AM
      Genius13815 points
      I mentioned this in a similar thread, but I thought I'd repeat it here: FYI the chips with BSL disabled are the experimental "XMS" chips. If your top-side markings have XMS430... instead of MSP430 then your BSL is disabled! Order or sample a newer revision.
      Report Abuse
      • Reply
    • BenH
      Posted by BenH
      on Apr 21 2009 10:00 AM
      Thank You. That was my guess as I have both versions here in front of me. I just though I'd make sure.
      Report Abuse
      • Reply
    • Sunil Shet
      Posted by Sunil Shet
      on Apr 26 2012 05:58 AM
      Intellectual305 points
      Hi every one,
      I am new to BSL programming.
      I don't know how to write BSL code and
      Which is the software used to download BSL code to the MSP430F5438.
      Please help me.
      Sunil
      Report Abuse
      • Reply
    • Lane Mitcham
      on Apr 26 2012 06:18 AM
      Prodigy230 points
      Sunil,
      You need to do a search for these documents; SLAA096D and SLAA089D.  These documents will tell you about  the BSL interface.  SLAA096D also has an associated zip file that has a BSL executable that runs on a Windows based PC and will program an MSP430 chip via the BSL interface as long as you have the associated circuitry described in the documents mentioned above.
      My only warning is to not use the "X" chips or the MSP430F5xxxA chips use the regular MSP430F5xxx (NON "A") chips.  The "X" chips have the BSL interface disabled and the timing on the "A" chips do not use the standard timing.
      Good luck!
      Lane
      Report Abuse
      • Reply
    • Sunil Shet
      on Apr 26 2012 07:06 AM
      Dear Lane Mitcham ,
       Thanks for your useful information,
      i am using MSP430F5438 chip.
      i am searching those documents which you have mentioned.. but i am not finding it.
      if you have more information's please help me.
      Thanks and Regards
      Sunil
      Report Abuse
      • Reply
    • Lane Mitcham
      on Apr 26 2012 08:32 AM
      Prodigy230 points
      Features of the Bootstrap Loader.pdf
      I have attached SLAA089D.pdf.
      Report Abuse
      • Reply
    • Lane Mitcham
      Prodigy230 points
      Here is the SLAA096D.pdf.
      Report Abuse
      • Reply
    • Lane Mitcham
      on Apr 26 2012 08:33 AM
      Prodigy230 points
      Bootstrap Loader.zip
      Here is the zip file that goes along with SLAA096D
      Report Abuse
      • Reply
    • Lane Mitcham
      on Apr 26 2012 08:54 AM
      Prodigy230 points
      BSL_Scripter.zip
      Here is another useful zip file.  This is the easiest to use, IMHO.
      Report Abuse
      • Reply
    • Sunil Shet
      on Apr 27 2012 01:30 AM
      Dear Lane Mitcham ,
      Thanks and Regards
      Sunil
      Report Abuse
      • Reply
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on Apr 27 2012 08:04 AM
      Guru140245 points
      Lane Mitcham
      More correctly, the A chips have a critical timing on the BSL entry sequence while the non-A don't (actually a bug in the CPU startup microcode). And the timing requirements for the A version are so tight that they cannot be met with an USB->serial bridge and are hard to comply even with a real serial port on any higher-level OS due to all the abstraction layers for even low-level serial port access. (on Win7 even harder than under XP or Linux)
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    • Sunil Shet
      on Apr 30 2012 02:25 AM
      Dear Sir,
      when i try to download the Application code to the MSP430F5438 using BSL programmer(BSL_Scripter.exe)
      i am facing following Problem...
      BSL Scripting application 1.06
      The local time is: 12:19 on 30.04.2012
      Initializing, Mode: 5438 COM: COM1 DONE
      Changing Baud Rate to 9600 DONE
      Mass Erase: FAIL(ee)
      RX Password: FAIL(ee)
      Writing MSP430TB.txt to device: FAIL writing data block starting at 5c00
      CRC from 5c00 of 4096 bytes to 982b FAIL....
      please help me...
      Thank you..
      MSP430F5438 BSL
      Report Abuse
      • Reply
    12
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
