Hi Again,
I developed a code for Tcp and Udp connection. it's working fine but over 2 days later ethernet connection stops. But mcu is working fine already. My source code is here about ethernet (!! Sorry, it is not clear code , because it has debug codes :) ):
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include <ctype.h>
#include "inc/hw_ints.h"
#include "driverlib/interrupt.h"
#include "driverlib/rom.h"
#include "driverlib/rom_map.h"
#include "driverlib/sysctl.h"
#include "driverlib/systick.h"
#include "driverlib/gpio.h"
#include "driverlib/pin_map.h"
#include "driverlib/flash.h"
#include "utils/locator.h"
#include "utils/lwiplib.h"
#include "utils/ustdlib.h"
#include <lwip/ip_addr.h>
#include "isl/isl_define.h"
#include "isl/isl_systick.h"
#include "isl/isl_serial.h"
#include "isl/isl_bluetooth.h"
#include "isl/isl_ethernet.h"
#define SYSTICKHZ 100
#define SYSTICKMS (1000 / SYSTICKHZ)
#define SYSTICK_INT_PRIORITY 0x80
#define ETHERNET_INT_PRIORITY 0xC0
volatile enum
iEthNoConnection,
iEthDHCPWait,
iEthDHCPComplete,
iEthDNSWait,
iEthTCPConnectWait,
iEthTCPConnectComplete,
iEthQueryWait,
iEthTCPOpen,
iEthIdle
} eState;
typedef struct
struct pbuf *psBuf;
uint32_t ui32Idx;
tBufPtr;
extern void UDP_Received(char *rcv_msg);
extern void TCP_Received(char *rcv_msg);
extern void GetIpAddress(uint32_t ip);
struct udp_pcb *ptel_pcb;
struct tcp_pcb *psTCP;
volatile bool tcpConnected=false;
volatile bool ipIsOk=false;
uint32_t g_ui32IPAddress;
struct ip_addr destip;
uint16_t destPortTcp;
extern void ISL_Ethernet_TCP_State(uint32_t State);
extern uint32_t SysClock;
struct ip_addr
MakeIpAddress(char *str)
struct ip_addr ip;
unsigned char value[4] = {0};
size_t index = 0;
while (*str) {
if (isdigit((unsigned char)*str)) {
value[index] *= 10;
value[index] += *str - '0';
} else {
index++;
str++;
IP4_ADDR(&ip,value[0],value[1],value[2],value[3]);
return ip;
void
lwIPHostTimerHandler(void)
uint32_t ui32NewIPAddress;
ui32NewIPAddress = lwIPLocalIPAddrGet();
if(ui32NewIPAddress != g_ui32IPAddress)
if(ui32NewIPAddress == 0xffffffff)
else if(ui32NewIPAddress == 0)
else
g_ui32IPAddress = ui32NewIPAddress;
ISL_Ethernet_TCP_State(IP_OK);
ipIsOk=true;
void
ISL_Send_Ethernet_UDP(char msg[], uint16_t len, char *ip, uint16_t port)
if(!ipIsOk)
return;
struct pbuf *p;
do
p=pbuf_alloc(PBUF_TRANSPORT,len, PBUF_RAM);
}while(p==NULL);
memcpy(p->payload,msg,len);;
p->len=len;
destip=MakeIpAddress(ip);
udp_sendto(ptel_pcb,p,&destip,port);
pbuf_free(p);
void
udp_echo_recv(void *arg, struct udp_pcb *pcb, struct pbuf *p, struct ip_addr *addr, u16_t port)
char msg[]="";
memcpy(msg,p->payload,p->len);
msg[p->len]='\0';
UDP_Received(msg);
/* echo
char msg[]="";
if (p != NULL)
msg[p->len]='\0';
udp_sendto(pcb,p,addr,1236);
pbuf_free(p);
static void BufPtrInit(tBufPtr *psBufPtr, struct pbuf *psBuf)
psBufPtr->psBuf = psBuf;
psBufPtr->ui32Idx = 0;
static uint8_t BufData8Get(tBufPtr *psBufPtr)
return(((uint8_t *)psBufPtr->psBuf->payload)[psBufPtr->ui32Idx]);
uint32_t BufPtrInc(tBufPtr *psBufPtr, uint32_t ui32Inc)
psBufPtr->ui32Idx += ui32Inc;
if(psBufPtr->ui32Idx >= psBufPtr->psBuf->len)
psBufPtr->psBuf = psBufPtr->psBuf->next;
if(psBufPtr->psBuf == 0)
ui32Inc = 0;
return(ui32Inc);
void
ISL_Config_Ethernet_UDP(uint32_t Port)
while(!ipIsOk)
do
ptel_pcb = udp_new();
}while(ptel_pcb == NULL);
udp_bind(ptel_pcb, IP_ADDR_ANY, Port);
udp_recv(ptel_pcb, udp_echo_recv, NULL);
void
ISL_Ethernet_TCP_Close(void)
err_t err;
if(psTCP)
tcp_arg(psTCP, NULL);
tcp_sent(psTCP, NULL);
tcp_recv(psTCP, NULL);
tcp_err(psTCP, NULL);
do
err=tcp_close(psTCP);
}while(err!=ERR_OK);
do
err=tcp_output(psTCP);
ISL_Ethernet_TCP_State(TCP_DISCONNECTED);
static err_t
TCPSent(void *pvArg, struct tcp_pcb *psPcb, uint16_t len)
return (ERR_OK);
static err_t
TCPReceive(void *pvArg, struct tcp_pcb *psPcb, struct pbuf *psBuf, err_t iErr)
if(psBuf->len==0)
ISL_Ethernet_TCP_Close();
pbuf_free(psBuf);
return ERR_CONN;
tBufPtr sBufPtr;
BufPtrInit(&sBufPtr, psBuf);
char rcv[500];
char *str=rcv;
while(1)
uint8_t rcv_ch=BufData8Get(&sBufPtr);
*str=rcv_ch;
str++;
if(BufPtrInc(&sBufPtr, 1) != 1)
*str='\0';
TCP_Received(rcv);
break;
struct pbuf *psBufCur;
psBufCur = psBuf;
while(psBufCur->len!=0)
tcp_recved(psPcb, psBufCur->len);
psBufCur = psBufCur->next;
if(psBufCur == 0)
break;
pbuf_free(psBuf);
return(ERR_OK);
static err_t
TCPConnected(void *pvArg, struct tcp_pcb *psPcb, err_t iErr)
if(iErr != ERR_OK)
return iErr;
else
ISL_Ethernet_TCP_State(TCP_CONNECTED);
tcp_recv(psPcb, TCPReceive);
tcp_sent(psPcb, TCPSent);
eState = iEthTCPConnectComplete;
return (ERR_OK);
void
ISL_Send_Ethernet_TCP(char *Data,uint16_t len)
char send[20];
if(len>tcp_sndbuf(psTCP))
//cok buyuk data
return;
err_t eError;
eError = tcp_write(psTCP, Data, len,TCP_WRITE_FLAG_COPY);
if(eError!=ERR_OK)
sprintf(send,"ISL_Send_Ethernet_TCP ERROR : %d",eError);
ISL_Send_SerialPort_String(send,1);
return;
else
eError=tcp_output(psTCP);
if(eError!=ERR_OK)
sprintf(send,"ERROR : %d",eError);
void
ISL_Config_Ethernet_TCP(char *ip, uint32_t port)
char send[20];
err_t eError;
if(!ipIsOk)
return;
destPortTcp=port;
if(psTCP!=NULL)
tcp_init();
do
psTCP = tcp_new();
}while(psTCP == NULL);
do
eError=tcp_connect(psTCP, &destip, destPortTcp, TCPConnected);
if(eError!=ERR_OK)
sprintf(send,"ISL_Config_Ethernet_TCP ERROR : %d",eError);
}while(eError!=ERR_OK);
ISL_Send_SerialPort_String("TCP Connected",1);
void
ISL_Config_Ethernet(void)
uint8_t MACArray[8];
uint32_t ui32User0,ui32User1;
#ifdef PART_TM4C129ENCPDT
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOK);
GPIOPinConfigure(GPIO_PF1_EN0LED2);
GPIOPinConfigure(GPIO_PK4_EN0LED0);
GPIOPinConfigure(GPIO_PK6_EN0LED1);
GPIOPinTypeEthernetLED(PORT_F, GPIO_PIN_1);
GPIOPinTypeEthernetLED(PORT_K, GPIO_PIN_4);
GPIOPinTypeEthernetLED(PORT_K, GPIO_PIN_6);
#endif
#ifndef __DRIVERLIB_ISL_SDCARD_H__
ROM_SysTickPeriodSet(SysClock / SYSTICKHZ);
ROM_SysTickEnable();
ROM_SysTickIntEnable();
#endif
ROM_FlashUserGet(&ui32User0,&ui32User1);
if((ui32User0 == 0xffffffff) || (ui32User1 == 0xffffffff))
while(1)
MACArray[0] = ((ui32User0 >> 0) & 0xff);
MACArray[1] = ((ui32User0 >> 8) & 0xff);
MACArray[2] = ((ui32User0 >> 16) & 0xff);
MACArray[3] = ((ui32User1 >> 0) & 0xff);
MACArray[4] = ((ui32User1 >> 8) & 0xff);
MACArray[5] = ((ui32User1 >> 16) & 0xff);
lwIPInit(SysClock, MACArray,0,0,0,IPADDR_USE_DHCP);
LocatorInit();
LocatorMACAddrSet(MACArray);
LocatorAppTitleSet("isb");
ROM_IntPrioritySet(INT_EMAC0, ETHERNET_INT_PRIORITY);
ROM_IntPrioritySet(FAULT_SYSTICK, SYSTICK_INT_PRIORITY);
while(!ipIsOk);
