• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » OMAP™ Applications Processors » OMAP 4 Forum » Leopard LI-5M06CMAF - OMAP4460 Camera Parallel Interface
Share
  • Forums
Options
  • Subscribe via RSS
This question is answered
Zhi Yong Woo
Posted by Zhi Yong Woo
on Apr 03 2012 18:33 PM
Intellectual740 points
Hi all experts:
Is OMAP4460 come with Camera Parallel Interface hardware that is kind of similar to OMAP3750's Camera Parallel Interface?
I am thinking of using this camera module onto OMAP4460. I saw blogs talking about using different camera module but similar CMOS sensor interface onto BeagleBoard xM. Here is the link:
http://gdansk.bradley.edu/wp_4copter_b/?p=76
http://blog.galemin.com/2011/04/li-5m03-camera-on-beagleboard-xm/
They have successfully make the driver working on OMAP3750 but I haven seen anyone manage to migrate the driver to OMAP4460. So, if anyone know someone has done this please post the link here. I would like to share the info to everyone in this forum...
Also, can anyone tell me some guildlines on how to configure OMAP4460 to listen to parallel port for camera interface.
I will be using SoM development board. http://www.variscite.com/products/item/76-var-som-om44-ti-omap4460
Not sure how many people come across this development kit?
Yong
CPI camera parallel interface
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Mayank Mangla
    Posted by Mayank Mangla
    on Apr 09 2012 08:20 AM
    Expert3845 points
    Wish you all the best for your effort, but please understand that parallel camera port is not officially supported on OMAP4. I doubt if anyone has succeeded in bringing up up any sensor on OMAP4 CPI.
    Please click the Verify Answer button on this post if it answers your question.
    Report Abuse
    • Reply
  • Zhi Yong Woo
    on Apr 09 2012 20:00 PM
    Hi Mayank,
    So, what is your recommendation if I want to use camera on OMAP4460? Do you know any good candidate to recommend?
    Report Abuse
    • Reply
  • Mayank Mangla
    on Apr 09 2012 21:21 PM
    Expert3845 points
    We recommend CSI2 sensors. You can also use a parallel  - CSI bridge chip to connect parallel sensors, but most bridge chips support a low data rate, besides adding to system cost.
    Report Abuse
    • Reply
  • Zhi Yong Woo
    on Apr 10 2012 00:32 AM
    So, do you have any case recommended CSI2 camera that I can work on OMAP4460? I hope to get something which is working then only I explore on other camera that no one has try on before.
    Report Abuse
    • Reply
  • Mayank Mangla
    on Apr 10 2012 06:40 AM
    Expert3845 points
    These are the sensors used on our blaze reference design
    1. Sony IMX060 - 12MP RAW sensor
    2. Omnivision OV5650 - 5MP RAW sensor
    3. Omnivision OV5640 - 5MP smart sensor
    4. Omnivision OV14825 - 14MP RAW sensor
    Please note that adding support for a sensor required Ducati code modifications. Please check that you have access to Ducati source before proceeding.
    A better option for you may be to use a smart sensor (like OV5640) and interface it through V4L2 driver on A9 side. This code is opensource. Please refer to
    https://gitorious.org/omap4-v4l2-camera
    Report Abuse
    • Reply
  • Zhi Yong Woo
    on Apr 10 2012 07:37 AM
    Oh... thats great!!!
    So how can I have the access to Ducati source? Do I need to pay for that?
    Report Abuse
    • Reply
  • Mayank Mangla
    on Apr 10 2012 08:36 AM
    Expert3845 points
    you dont need to pay, but you need NDA and a licensing agreement with TI. If you are an individual developer it maybe too much hassle. Therefore I suggest using a smart sensor with A9 side V4l2 framework. You can also use a USB class camera.
    Report Abuse
    • Reply
  • Zhi Yong Woo
    on Apr 10 2012 08:54 AM
    Right, I got you!
    I think my approach will be as your recommendation.
    Finally, I am not clear about some imaging processing when using OMAP4460. I knew the CMOS sensor is producing RAW RGB data and I knew that OMAP4460 does have Image encoder like image resizer, autofocus, exposure and some video codec.
    I am wondering, are these processing are done by OMAP itself and they should not included by the driver right?
    To be honest, I am not very clear in understand how these system work from hardware to software. Would you mind to point me to some reference so that I can quickly get a clear picture on how these thing work together.
    Report Abuse
    • Reply
  • Mayank Mangla
    on Apr 10 2012 09:55 AM
    Expert3845 points
    You are correct. Image pipeline and video codecs and not part of sensor driver. But we still need sensor driver to do the following
    1. Setup external sensor interfaces
    2. Setup sensor modes and output format, resolution etc
    3. Connect sensor output to OMAP image/video processing pipeline.
    Report Abuse
    • Reply
  • Zhi Yong Woo
    on Apr 10 2012 21:47 PM
    Thanks for clarifying all my questions and I have actually started going into the open source camera driver that you direct me to. The only one thing I am not too sure is, can I use two similar camera on CSIA and CSIB with this driver?
    Finally, about the DSP - Do I need OS to drive the DSP to perform like 1280x720 30fps mp4 h264 codec? Else do I need to do something manually to fully utilise OMAP4460 Hardware DSP?
    Report Abuse
    • Reply
  • Mayank Mangla
    on Apr 10 2012 21:59 PM
    Verified Answer
    Verified by Magdalena Iovescu
    Expert3845 points
    As of now he framework supports only 1 camera, but with some modifications 2 cameras should be possible. Hopefully some one from opensource community can contribute to that.
    Using video engine is fairly straightforward. There are OMX components available for most codecs. A9 code needs to use standard OMX APIs to use these components. If you are on Android or generic Linux there are higher level multimedia frameworks (Stagefright for Android and gstreamer for linux) available.
    Report Abuse
    • Reply
  • Zhi Yong Woo
    on Apr 11 2012 01:53 AM
    That is sound good to me.
    Do I need to have any OS to run the multimedia frameworks in order to test the camera driver? Any suggestions for that?
    Report Abuse
    • Reply
  • Mayank Mangla
    on Apr 11 2012 07:45 AM
    Expert3845 points
    yes.. you need Android (preferable) or Linux running on target board. Please refer to OMAP4 release notes.
    To build the code you need a Ubuntu PC.
    Report Abuse
    • Reply
  • Zhi Yong Woo
    on Apr 11 2012 08:08 AM
    Right I see! That is what I though too. but I am a bit confuse from the instruction stated at the link you recommended: https://gitorious.org/omap4-v4l2-camera/pages/Home
    According to the "Testing Notes", why we need the "command line test" and "yavta" if we have OS? Can you please give me some advices on this?
    Thank you!
    Report Abuse
    • Reply
  • Mayank Mangla
    on Apr 11 2012 08:23 AM
    Expert3845 points
    There are usage instructions with gstreamer and Android HAL in the same release notes.
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
