Android ICS: Ducati failing on 4AI.1.5 while working on 4AI.1.0 (OMAP4430/OMAP4460 Pandaboard)
Other Parts Discussed in Thread: TWL6030, 4430
Ducati is failing on 4AI.1.5 (Android ICS) while it was working on 4AI.1.0 on the Pandaboard. My build is largely inspired from blaze tablet and I'm using the blaze tablet *Ducati* binaries which were working fine on 4AI.1.0. I can decode video on 4AI.1.0 on the Panda. Ducati binaries haven't changed between 4A.I1.0 and 4AI.1.5: same md5sum of ducati-m3.bin. But on 4AI.1.5, Android fails to decode with hardware acceleration. Log is provided below.
Note that a similar problem has been reported here:
http://e2e.ti.com/support/omap/f/849/p/192881/689942.aspx
but that doesn't really help.
The interesting part of the log is:
[ 6.084381] omap-rproc omap-rproc.1: Loaded BIOS image ducati-m3.bin, size 5756300
[ 6.158996] omap_hwmod: ipu: failed to hardreset
[ 6.169860] omap-rproc omap-rproc.1: can't start rproc ipu: -5
and then:
D/DOMX ( 113): hardware/ti/domx/domx/omx_rpc/src/omx_rpc.c:140 RPC_InstanceInit()
D/DOMX ( 113): ERROR: Can't open device, errorno from open = 2
D/DOMX ( 113): hardware/ti/domx/domx/omx_rpc/src/omx_rpc_stub.c:200 RPC_GetHandle()
D/DOMX ( 113): ERROR: DOMX Write failed 0xffffffff -1
D/DOMX ( 113): ERROR: failed check:status >= 0 && errno != ENXIO - returning error: 0x81009 - Write failed due ducati in faulty state
The logcat extract above is really a consequence of the fact that ipu has not been started. I really don't think that there is a problem in user-space and there is quasi no modification between 1.0 and 1.5 on Android frameworks for hardware video acceleration. The problem is because IPU doesn't start. On 4AI.1.0, I don't have the failed reset of IPU. Also, note the crash if I try to access rproc.1 info.
Any idea what's wrong?
Thanks in advance,
Grégoire
Texas Instruments X-Loader 1.41 (May 27 2012 - 11:37:20)
Starting OS Bootloader from MMC/SD1 ...
U-Boot 2011.03 (May 27 2012 - 11:37:20)
CPU : OMAP4430
Board: OMAP4 Panda
I2C: ready
DRAM: 1 GiB
MMC: OMAP SD/MMC: 0
Using default environment
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
Panda #
Panda # setenv defaultdisplay
Panda # setenv console ttyO2,115200n8 androidboot.console=ttyO2
Panda # setenv optargs mem=456M@0x80000000 mem=512M@0xA0000000
Panda # setenv uimage uImage
Panda # setenv mmcrootfstype ext4 rootwait
Panda # boot
Unknown command 'userbutton' - try 'help'
reading boot.scr
121 bytes read
Running bootscript from mmc ...
## Executing script at 80000000
reading uImage
4371756 bytes read
Booting from mmc ...
## Booting kernel from Legacy Image at 80000000 ...
Image Name: Linux-3.0.21-00003-OMAP-Android+
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4371692 Bytes = 4.2 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.0.21-00003-OMAP-Android+ (gregoire@laptop) (gcc version 4.4.1 (Sourcery G++ Lite 2010q1-202) ) #45 SMP PREEMPT Sat Jul 21 15:53:13 PDT 2012
[ 0.000000] CPU: ARMv7 Processor [411fc093] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: OMAP4 Panda board
[ 0.000000] Malformed early option 'omapdss.def_disp'
[ 0.000000] android_display: setting default resolution 1920*1080, bpp=4
[ 0.000000] android_display: tiler1d 66355200
[ 0.000000] android_display: setting fb0.vram to 16588800
[ 0.000000] android_display: setting vram to 16588800
[ 0.000000] android_display: ion carveouts: 49938432 tiler2d, 17825792 nonsecure
[ 0.000000] omap_ion_init: id=2 [ba300000-bfd00000] size=5a00000
[ 0.000000] omap_ion_init: id=1 [b0900000-b3a00000] size=3100000
[ 0.000000] omap_ion_init: id=3 [af800000-b0900000] size=1100000
[ 0.000000] omap_ion_init: id=0 [b0900000-b0900000] size=0
[ 0.000000] omap_ion_init: id=4 [b0900000-b0900000] size=0
[ 0.000000] Reserving 33554432 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] OMAP4430 ES2.3
[ 0.000000] SRAM: Mapped pa 0x40300000 to va 0xfe400000 size: 0xd000
[ 0.000000] On node 0 totalpages: 177664
[ 0.000000] free_area_init_node: node 0, pgdat c0869500, node_mem_map c0a9c000
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32512 pages, LIFO batch:7
[ 0.000000] HighMem zone: 1792 pages used for memmap
[ 0.000000] HighMem zone: 143104 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 7 pages/cpu @c12a7000 s7072 r8192 d13408 u32768
[ 0.000000] pcpu-alloc: s7072 r8192 d13408 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 175616
[ 0.000000] Kernel command line: console=ttyO2,115200n8 mem=1G vmalloc=768M androidboot.console=ttyO2 omap_wdt.timer_margin=30 console=ttyO2,115200n8 androidboot.console=ttyO2 mem=456M@0x80000000 mem=512M@0xA0000000 mpurate=1000 buddy=t
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 512MB 182MB = 694MB total
[ 0.000000] Memory: 691392k/1325440k available, 714368k reserved, 579584K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xc8800000 - 0xf8000000 ( 760 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .init : 0xc0008000 - 0xc004e000 ( 280 kB)
[ 0.000000] .text : 0xc004e000 - 0xc07e8000 (7784 kB)
[ 0.000000] .data : 0xc07e8000 - 0xc086a060 ( 521 kB)
[ 0.000000] .bss : 0xc086a084 - 0xc0a9b1f0 (2245 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:410
[ 0.000000] omap_hwmod: dpll_mpu_m2_ck: missing clockdomain for dpll_mpu_m2_ck.
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Calibrating delay loop... 2007.19 BogoMIPS (lpj=7839744)
[ 0.015686] pid_max: default: 32768 minimum: 301
[ 0.015686] Mount-cache hash table entries: 512
[ 0.015686] Initializing cgroup subsys debug
[ 0.071411] Initializing cgroup subsys cpuacct
[ 0.071411] Initializing cgroup subsys freezer
[ 0.071411] CPU: Testing write buffer coherency: ok
[ 0.072021] L310 cache controller enabled
[ 0.072021] l2x0: 16 ways, CACHE_ID 0x410000c4, AUX_CTRL 0x5e470000, Cache size: 1048576 B
[ 0.150421] CPU1: Booted secondary processor
[ 0.220489] Brought up 2 CPUs
[ 0.220489] SMP: Total of 2 processors activated (4022.78 BogoMIPS).
[ 0.220672] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for emif_fw
[ 0.220672] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_instr
[ 0.223205] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_main_1
[ 0.223205] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_main_2
[ 0.223236] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_abe
[ 0.223236] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_cfg
[ 0.223236] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_per
[ 0.223236] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_wkup
[ 0.223266] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for mpu_private
[ 0.223266] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for sl2if
[ 0.223266] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ohci
[ 0.223266] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ehci
[ 0.223266] omap_hwmod: l3_div_ck: missing clockdomain for l3_div_ck.
[ 0.228302] _omap4_module_wait_ready: Timeout waiting for module enable (mcpdm_fck: clkctrl = 0x30002)
[ 0.231323] omap_hwmod: mcpdm: cannot be enabled (3)
[ 0.233367] print_constraints: dummy:
[ 0.233367] NET: Registered protocol family 16
[ 0.233367] GPMC revision 6.0
[ 0.233367] EMIF0 is enabled with IRQ142
[ 0.235046] EMIF1 is enabled with IRQ143
[ 0.235046] Last reset was cold reset (PRM_RSTST=0x1)
[ 0.235076]
[ 0.235412] OMAP GPIO hardware version 0.1
[ 0.236846] omap_mux_init: Add partition: #1: core, flags: 2
[ 0.236846] omap_mux_init: Add partition: #2: wkup, flags: 2
[ 0.237854] omap_mux_get_by_name: Could not find signal uart1_cts.uart1_cts
[ 0.237854] omap_hwmod_mux_init: Could not allocate device mux entry
[ 0.244689] HSI: skipping omap_device registration
[ 0.244781] OMAP DMA hardware revision 0.0
[ 0.244781] omap_rproc_get_pool: dsp - no carveout memory is available at all
[ 0.244781] omap_rproc_get_pool: ipu - carveout memory is unavailable: 0x0, 0x0
[ 0.252807] bio: create slab <bio-0> at 0
[ 0.253112] print_constraints: vwl1271: 1800 mV
[ 0.253112] i2c-core: driver [twl] using legacy suspend method
[ 0.253723] i2c-core: driver [twl] using legacy resume method
[ 0.253723] SCSI subsystem initialized
[ 0.254669] usbcore: registered new interface driver usbfs
[ 0.254974] usbcore: registered new interface driver hub
[ 0.255004] usbcore: registered new device driver usb
[ 0.255584] omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz
[ 0.255645] Skipping twl internal clock init and using bootloader value (unknown osc rate)
[ 0.259552] twl6030: PIH (irq 39) chaining IRQs 368..387
[ 0.261322] print_constraints: VUSB: 3300 mV normal standby
[ 1.079833] <3>Unknown charger detected! 0
[ 1.080352] twl6030_usb twl6030_usb: Initialized TWL6030 USB module
[ 1.080932] print_constraints: VMMC: 1200 <--> 3000 mV at 3000 mV normal standby
[ 1.081359] print_constraints: VPP: 1800 <--> 2500 mV at 1900 mV normal standby
[ 1.081359] print_constraints: VCXIO: 1800 mV normal standby
[ 1.081359] print_constraints: VDAC: 1800 mV normal standby
[ 1.082214] print_constraints: VAUX2_6030: 1200 <--> 2800 mV at 1800 mV normal standby
[ 1.082611] print_constraints: VAUX3_6030: 1000 <--> 3000 mV at 1200 mV normal standby
[ 1.082977] print_constraints: VANA: 2100 mV normal standby
[ 1.083740] print_constraints: CLK32KG:
[ 1.084564] print_constraints: CLK32KAUDIO:
[ 1.084747] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 1.084930] omap_i2c omap_i2c.3: bus 3 rev4.0 at 100 kHz
[ 1.085205] omap_i2c omap_i2c.4: bus 4 rev4.0 at 400 kHz
[ 1.085205] omap-rproc omap-rproc.0: dsp is available
[ 1.085754] omap-rproc omap-rproc.1: ipu is available
[ 1.085906] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 1.085906] Bluetooth: Core ver 2.16
[ 1.086486] NET: Registered protocol family 31
[ 1.086486] Bluetooth: HCI device and connection manager initialized
[ 1.086547] Bluetooth: HCI socket layer initialized
[ 1.086547] Bluetooth: L2CAP socket layer initialized
[ 1.086547] Bluetooth: SCO socket layer initialized
[ 1.086730] Switching to clocksource 32k_counter
[ 1.087646] Switched to NOHz mode on CPU #0
[ 1.087677] Switched to NOHz mode on CPU #1
[ 1.088317] musb-hdrc: version 6.0, musb-dma, otg (peripheral+host)
[ 1.388641] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 1.388641] musb-hdrc: MHDRC RTL version 2.0
[ 1.388916] musb-hdrc: setup fifo_mode 4
[ 1.388916] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 1.389129] musb-hdrc musb-hdrc: USB Peripheral mode controller at fc0ab000 using DMA, IRQ 124
[ 1.389404] NET: Registered protocol family 2
[ 1.389404] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 1.389404] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.389404] TCP bind hash table entries: 16384 (order: 6, 393216 bytes)
[ 1.391754] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.391754] TCP reno registered
[ 1.391784] UDP hash table entries: 64 (order: 0, 4096 bytes)
[ 1.391784] UDP-Lite hash table entries: 64 (order: 0, 4096 bytes)
[ 1.391784] NET: Registered protocol family 1
[ 1.392669] RPC: Registered named UNIX socket transport module.
[ 1.392669] RPC: Registered udp transport module.
[ 1.392669] RPC: Registered tcp transport module.
[ 1.392700] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.477416] omap_init_opp_table: no hwmod or odev for hsi, [18] cannot add OPPs.
[ 1.477416] omap_init_opp_table: no hwmod or odev for hsi, [19] cannot add OPPs.
[ 1.477722] ram_console: got buffer at a0000000, size 200000
[ 1.478729] ram_console: uncorrectable error in header
[ 1.478729] ram_console: no valid data in buffer (sig = 0xe8b8ba23)
[ 1.493255] console [ram-1] enabled
[ 1.493255] omap-iommu omap-iommu.0: ducati registered
[ 1.493255] omap-iommu omap-iommu.1: tesla registered
[ 1.510681] highmem bounce pool size: 64 pages
[ 1.510681] ashmem: initialized
[ 1.517272] fuse init (API version 7.16)
[ 1.517272] msgmni has been set to 218
[ 1.517272] Registering char device tf_driver (122:0)
[ 1.517272] SMCAG01.06.0 D
[ 1.520324] io scheduler noop registered
[ 1.520416] io scheduler deadline registered
[ 1.520416] io scheduler cfq registered (default)
[ 1.520416] start plist test
[ 1.524108] end plist test
[ 1.524780] OMAP DSS rev 4.0
[ 1.526977] Keyboard driver not present
[ 1.527465] dsscomp: initializing.
[ 1.527465] misc dsscomp: display0=hdmi_panel
[ 1.527465] misc dsscomp: found 1 displays and 4 overlays, WB overlay 1
[ 1.528289] could not allocate slot
[ 1.528900] omap-rproc omap-rproc.1: powering up ipu
[ 1.529205] virtio_rpmsg_bus virtio0: rpmsg backend virtproc probed successfully
[ 1.529205] virtio_rpmsg_bus virtio1: rpmsg backend virtproc probed successfully
[ 1.530822] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 104) is a OMAP UART0
[ 1.531158] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 105) is a OMAP UART1
[ 1.531616] omap_uart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
[ 2.697204] in hpd work 1, state=0
[ 2.701080] omapdss HDMI: ENTER hdmi_display_enable
[ 2.706542] console [ttyO2] enabled
[ 2.710601] omap_uart.3: ttyO3 at MMIO 0x4806e000 (irq = 102) is a OMAP UART3
[ 2.719024] omap_ion_probe: adding heap secure_input of type 2 with ba300000@5a00000
[ 2.727905] omap_ion_probe: adding heap tiler of type 4 with b0900000@3100000
[ 2.735870] omap_ion_probe: adding heap nonsecure_tiler of type 4 with af800000@1100000
[ 2.744842] omap_ion_probe: adding heap system of type 0 with b0900000@0
[ 2.752349] omap_ion_probe: adding heap tiler_reservation of type 5 with b0900000@0
[ 2.760955] omapdss HDMI: Set c-state constraint for HDMI
[ 2.760986]
[ 2.761047] brd: module loaded
[ 2.767150] loop: module loaded
[ 2.769073] Loading pn544 driver
[ 2.769073] (stk) :sysfs entries created
[ 2.769073] (stk) : debugfs entries created
[ 2.788055] HDCP: invalid AKSV
[ 2.790405] PPP generic driver version 2.4.2
[ 2.790466] PPP Deflate Compression module registered
[ 2.790466] PPP BSD Compression module registered
[ 2.807342] omapdss HDMI error: *** INVALID AKSV: 0 Do not perform HDCP AUTHENTICATION
[ 2.808013] PPP MPPE Compression module registered
[ 2.808044] NET: Registered protocol family 24
[ 2.808044] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.809814] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 2.809814] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 2.810028] ehci-omap ehci-omap.0: irq 109, io mem 0x4a064c00
[ 2.855468] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 2.861816] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.869476] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.877471] usb usb1: Product: OMAP-EHCI Host Controller
[ 2.877471] usb usb1: Manufacturer: Linux 3.0.21-00003-OMAP-Android+ ehci_hcd
[ 2.891296] usb usb1: SerialNumber: ehci-omap.0
[ 2.896850] hub 1-0:1.0: USB hub found
[ 2.901031] hub 1-0:1.0: 3 ports detected
[ 2.937164] usbcore: registered new interface driver cdc_acm
[ 2.937164] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.952453] Initializing USB Mass Storage driver...
[ 2.957855] usbcore: registered new interface driver usb-storage
[ 2.958465] omapdss DISPC error: timeout waiting for EVSYNC
[ 2.958557] USB Mass Storage support registered.
[ 2.975982] usbcore: registered new interface driver usbserial
[ 2.982604] usbserial: USB Serial Driver core
[ 3.023559] in hpd work 2, state=1
[ 3.235229] usb 1-1: new high speed USB device number 2 using ehci-omap
[ 3.289367] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 3.296966] android_usb gadget: Number of LUNs=1
[ 3.296966] lun0: LUN: removable file: (no medium)
[ 3.307464] android_usb gadget: android_usb ready
[ 3.613006] mousedev: PS/2 mouse device common for all mice
[ 3.619689] twl6030_pwrbutton_probe: Enter
[ 3.624816] input: twl6030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl6030_pwrbutton/input/input0
[ 3.638427] twl_rtc twl_rtc: Power up reset detected.
[ 3.644470] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 3.651885] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.660278] twl_rtc twl_rtc: Enabling TWL-RTC.
[ 3.665252] hub 1-1:1.0: USB hub found
[ 3.669616] hub 1-1:1.0: 5 ports detected
[ 3.675842] using rtc device, twl_rtc, for alarms
[ 3.680908] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 3.688323] i2c /dev entries driver
[ 3.692169] edid[000] = 00 ff ff ff ff ff ff 00 04 69 f3 22 7b e3 01 00
[ 3.692321] Linux media interface: v0.10
[ 3.692321] lirc_dev: IR Remote Control driver registered, major 248
[ 3.692321] IR NEC protocol handler initialized
[ 3.692321] IR RC5(x) protocol handler initialized
[ 3.692321] IR RC6 protocol handler initialized
[ 3.692779] IR JVC protocol handler initialized
[ 3.692779] IR Sony protocol handler initialized
[ 3.692779] IR RC5 (streamzap) protocol handler initialized
[ 3.692779] IR LIRC bridge handler initialized
[ 3.692810] Linux video capture interface: v2.00
[ 3.692810] dmm: probe base: fd300000, irq 145
[ 3.699096] OMAP Watchdog Timer Rev 0x00: initial timeout 30 sec
[ 3.700103] device-mapper: uevent: version 1.0.3
[ 3.700103] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[ 3.700103] Bluetooth: HCI UART driver ver 2.2
[ 3.700866] Bluetooth: HCI H4 protocol initialized
[ 3.700866] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[ 3.794982] edid[010] = 19 15 01 03 80 2f 1a 78 2a c7 20 a4 55 49 99 27
[ 3.796081] (stc): st_register(2)
[ 3.796081] (stc): chnl_id list empty :2
[ 3.796142] (stk) : st_kim_start
[ 3.813781] edid[020] = 13 50 54 bf ef 00 71 4f 81 40 81 80 95 00 b3 00
[ 3.813781] cpuidle: using governor ladder
[ 3.813781] cpuidle: using governor menu
[ 3.817321] Registered led device: pandaboard::status1
[ 3.817413] Registered led device: pandaboard::status2
[ 3.819213] usbcore: registered new interface driver usbhid
[ 3.819213] usbhid: USB HID core driver
[ 3.851776] edid[030] = d1 c0 01 01 01 01 02 3a 80 18 71 38 2d 40 58 2c
[ 3.852050] logger: created 256K log 'log_main'
[ 3.852142] logger: created 256K log 'log_events'
[ 3.852203] logger: created 256K log 'log_radio'
[ 3.852325] logger: created 256K log 'log_system'
[ 3.860229] No CPUfreq policy at this point.
[ 3.860656] OMAPRPC: Registration of OMAPRPC rpmsg service returned 0!
[ 3.861328] OMAP HSI: HSI driver version 0.4.3
[ 3.861572] OMAP HSI: Platform DRIVER register FAILED: -19
[ 3.861907] usbcore: registered new interface driver snd-usb-audio
[ 3.864105] SDP4430 SoC init
[ 3.912261] edid[040] = 45 00 dd 0c 11 00 00 1e 00 00 00 ff 00 42 36 4c
[ 3.918975] (stk) :ldisc_install = 1
[ 3.919281] twl6040-codec twl6040-codec: couldn't get VDDHF regulator -19
[ 3.931030] edid[050] = 4d 54 46 31 32 33 37 37 31 0a 00 00 00 fd 00 37
[ 3.938385] edid[060] = 4b 1e 55 10 00 0a 20 20 20 20 20 20 00 00 00 fc
[ 3.945617] edid[070] = 00 41 53 55 53 20 56 48 32 32 32 48 0a 20 01 5c
[ 3.945892] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 3.949829] asoc: null-codec-dai <-> MultiMedia1 mapping ok
[ 3.950866] asoc: null-codec-dai <-> MultiMedia2 mapping ok
[ 3.952239] asoc: null-codec-dai <-> Voice mapping ok
[ 3.953308] asoc: null-codec-dai <-> Tones mapping ok
[ 3.954345] asoc: null-codec-dai <-> Vibra mapping ok
[ 3.955047] asoc: null-codec-dai <-> MODEM mapping ok
[ 3.955657] asoc: null-codec-dai <-> MultiMedia1 LP mapping ok
[ 3.957000] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[ 3.958038] asoc: twl6040-dl1 <-> mcpdm-dl mapping ok
[ 3.959594] asoc: dmic-hifi <-> omap-dmic-dai-0 mapping ok
[ 3.961090] twl6040-codec twl6040-codec: ASoC: Failed to create Aux/FM Stereo In debugfs file
[ 3.961822] asoc: twl6040-dl1 <-> mcpdm-dl1 mapping ok
[ 3.962493] asoc: twl6040-ul <-> mcpdm-ul1 mapping ok
[ 3.963165] asoc: twl6040-dl2 <-> mcpdm-dl2 mapping ok
[ 3.963836] asoc: twl6040-vib <-> mcpdm-vib mapping ok
[ 3.964538] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[ 3.965240] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[ 3.965942] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[ 3.966674] asoc: MODEM <-> omap-mcbsp-dai.1 mapping ok
[ 3.967346] asoc: dmic-hifi <-> omap-dmic-abe-dai-0 mapping ok
[ 3.968017] asoc: dmic-hifi <-> omap-dmic-abe-dai-1 mapping ok
[ 3.968688] asoc: dmic-hifi <-> omap-dmic-abe-dai-2 mapping ok
[ 3.969421] asoc: null-codec-dai <-> omap-abe-vxrec-dai mapping ok
[ 3.971191] input: Panda Headset Jack as /devices/platform/soc-audio/sound/card0/input1
[ 3.973693] asoc: hdmi-audio-codec <-> hdmi-audio-dai mapping ok
[ 3.974121] ALSA device list:
[ 3.974121] #0: TI OMAP4 Board
[ 3.974121] #1: OMAP4HDMI
[ 3.974273] GACT probability NOT on
[ 3.974273] Mirror/redirect action on
[ 3.974304] u32 classifier
[ 3.974304] Actions configured
[ 3.974304] Netfilter messages via NETLINK v0.30.
[ 3.974365] nf_conntrack version 0.5.0 (10803 buckets, 43212 max)
[ 3.975311] ctnetlink v0.93: registering with nfnetlink.
[ 3.975341] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 3.975372] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 3.975677] xt_time: kernel timezone is -0000
[ 3.977569] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.977752] arp_tables: (C) 2002 David S. Miller
[ 3.977813] TCP cubic registered
[ 3.978485] NET: Registered protocol family 10
[ 3.983123] Mobile IPv6
[ 3.983184] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.983459] IPv6 over IPv4 tunneling driver
[ 3.988220] NET: Registered protocol family 17
[ 3.988250] NET: Registered protocol family 15
[ 3.988494] Bridge firewalling registered
[ 3.988616] Bluetooth: RFCOMM TTY layer initialized
[ 3.988647] Bluetooth: RFCOMM socket layer initialized
[ 3.988647] Bluetooth: RFCOMM ver 1.11
[ 3.988677] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.988677] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.988800] NET: Registered protocol family 35
[ 3.989166] NET: Registered protocol family 37
[ 3.989166] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 4.265808] edid[080] = 02 03 22 71 4f 01 02 03 11 12 13 04 14 05 0e 0f
[ 4.265838] edid[090] = 1d 1e 1f 10 23 09 07 01 83 01 00 00 65 03 0c 00
[ 4.265838] edid[0a0] = 10 00 8c 0a d0 8a 20 e0 2d 10 10 3e 96 00 dd 0c
[ 4.265869] edid[0b0] = 11 00 00 18 01 1d 00 72 51 d0 1e 20 6e 28 55 00
[ 4.265869] edid[0c0] = dd 0c 11 00 00 1e 01 1d 00 bc 52 d0 1e 20 b8 28
[ 4.265869] edid[0d0] = 55 40 dd 0c 11 00 00 1e 8c 0a d0 90 20 40 31 20
[ 4.265899] edid[0e0] = 0c 40 55 00 dd 0c 11 00 00 18 00 00 00 00 00 00
[ 4.265899] edid[0f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 c7
[ 4.265930] edid[100] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.265930] edid[110] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.265930] edid[120] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.265960] edid[130] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.265960] edid[140] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.265960] edid[150] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.265991] edid[160] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.265991] edid[170] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.265991] edid[180] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.266021] edid[190] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.266021] edid[1a0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.266052] edid[1b0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.266052] edid[1c0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.266052] edid[1d0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.266082] edid[1e0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.266082] edid[1f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.266204] panel size 47 by 26
[ 4.448852] mmc0: new high speed SDHC card at address 0001
[ 4.454895] ThumbEE CPU extension supported.
[ 4.459655] Registering SWP/SWPB emulation handler
[ 4.465301] mmcblk0: mmc0:0001 00000 7.60 GiB
[ 4.472869] mmcblk0: p1 p2
[ 4.479156] Reprogramming LPDDR2 timings to 400000000 Hz
[ 4.485198] sr_init: No PMIC hook to init smartreflex
[ 4.491058] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 4.499725] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 4.508361] smartreflex smartreflex.2: omap_sr_probe: SmartReflex driver initialized
[ 4.516632] usb 1-1.1: new high speed USB device number 3 using ehci-omap
[ 4.524566] SmartReflex class 1.5 driver: initialized (86400000ms)
[ 4.531799] Power Management for TI OMAP4.
[ 4.536437] OMAP4 PM: Static dependency added between MPUSS <-> EMIF, MPUSS <-> L4_PER/CFG MPUSS <-> L3_MAIN_1.
[ 4.547210] OMAP4 PM: Static dependency added between DUCATI <-> L4_PER/CFG and DUCATI <-> L3.
[ 4.556427] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1388000Calib=1253380 margin=0
[ 4.573577] clock: disabling unused clocks to save power
[ 4.579315] sr_class1p5_calib_work: core: Calibration complete: Voltage Nominal=1127000Calib=1063480 margin=0
[ 4.590484] omapfb omapfb: cannot parse default modes
[ 4.591369] mmc1: card claims to support voltages below the defined range. These will be ignored.
[ 4.611450] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.618255] mmc1: new SDIO card at address 0001
[ 4.625885] sr_class1p5_calib_work: iva: Calibration complete: Voltage Nominal=950000Calib=873580 margin=0
[ 4.642028] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 4.649566] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.672760] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1200000Calib=1088800 margin=0
[ 4.719696] sr_class1p5_calib_work: core: Calibration complete: Voltage Nominal=962000Calib=898900 margin=0
[ 4.730682] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1025000Calib=911560 margin=0
[ 4.743438] usb 1-1.2: new high speed USB device number 4 using ehci-omap
[ 4.868804] usb 1-1.2: New USB device found, idVendor=04cc, idProduct=1520
[ 4.876495] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.886260] hub 1-1.2:1.0: USB hub found
[ 4.890960] hub 1-1.2:1.0: 4 ports detected
[ 5.063415] (stk) :ldisc installation timeout
[ 5.068145] (stk) :ldisc_install = 0
[ 5.181060] usb 1-1.2.2: new full speed USB device number 5 using ehci-omap
[ 5.198516] cannot apply mgr(lcd) on inactive device
[ 5.204254] omapfb omapfb: failed to apply dispc config
[ 5.210388] cannot apply mgr(lcd2) on inactive device
[ 5.216186] omapfb omapfb: failed to apply dispc config
[ 5.223419] regulator_init_complete: VANA: incomplete constraints, leaving on
[ 5.233093] regulator_init_complete: VCXIO: incomplete constraints, leaving on
[ 5.243469] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 5.252410] omap4iss omap4iss: Revision 40000101 found
[ 5.258514] ov5640 3-003c: XVCLK set to rounded aproximate (19200000 Hz)
[ 5.267883] ov5640 3-003c: Failed reading register 0x302a!
[ 5.273956] ov5640 3-003c: Failure to detect OV5640 chip
[ 5.279785] omap4iss omap4iss: iss_register_subdev_group: Unable to register subdev ov5640
[ 5.288940] ov5650 3-0036: XVCLK set to rounded aproximate (19200000 Hz)
[ 5.298583] ov5650 3-0036: Failed reading register 0x300a!
[ 5.304718] ov5650 3-0036: Failure to read Chip ID (high byte)
[ 5.311218] omap4iss omap4iss: iss_register_subdev_group: Unable to register subdev ov5650
[ 5.324645] usb 1-1.2.2: New USB device found, idVendor=a110, idProduct=0002
[ 5.332519] usb 1-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.340942] usb 1-1.2.2: Product: Always Innovating USB Keyboard / Touchpad
[ 5.349487] usb 1-1.2.2: Manufacturer: Always Innovating
[ 5.359008] input: Always Innovating Always Innovating USB Keyboard / Touchpad as /devices/platform/omap/usbhs_omap/ehci-omap.0/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.0/input/input2
[ 5.376495] generic-usb 0003:A110:0002.0001: input: USB HID v1.11 Keyboard [Always Innovating Always Innovating USB Keyboard / Touchpad] on usb-ehci-omap.0-1.2.2/input0
[ 5.393188] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.402282] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 5.408843] Freeing init memory: 280K
[ 5.413208] input: Always Innovating Always Innovating USB Keyboard / Touchpad as /devices/platform/omap/usbhs_omap/ehci-omap.0/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.1/input/input3
[ 5.430267] generic-usb 0003:A110:0002.0002: input: USB HID v1.11 Mouse [Always Innovating Always Innovating USB Keyboard / Touchpad] on usb-ehci-omap.0-1.2.2/input1
[ 5.508422] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 6.126708] HDCP: failed to load keys
[ 6.227478] (stk) : timed out waiting for ldisc to be un-installed
[ 6.350769] usb 1-1.1: USB disconnect, device number 3
[ 6.372253] (stk) :ldisc_install = 1
[ 6.384704] PVR: PVRCore_Init
[ 6.388671] PVR: PVRSRVDriverProbe(pDevice=c78a4600)
[ 6.394165] PVR: SGX register base: 0x56000000
[ 6.398925] PVR: SGX register size: 65535
[ 6.403289] PVR: SGX IRQ: 53
[ 6.406402] PVR: EnableSystemClocks: Enabling System Clocks
[ 6.411071] Compat-wireless backport release: ol_R5.00.18
[ 6.411102] Backport based on wl12xx.git ol_R5.00.18
[ 6.424163] PVR: PVRCore_Init: major device 245
[ 6.435150] (stc): st_tty_open
[ 6.438507] (stk) :line discipline installed
[ 6.443389] (stk) :TIInit_7.2.31.bts
[ 6.662597] omaplfbOMAPLFBInit: Blitsville gc2d not present, blits disabled
[ 6.670410] omaplfb: OMAPLFBInitIonOmap: Device 0: Requesting 2 TILER 2D framebuffers
[ 7.079528] cfg80211: Calling CRDA to update world regulatory domain
[ 7.208587] (stc): add_channel_to_table: id 2
[ 7.213684] (stc): st_register(3)
[ 7.220184] (stc): add_channel_to_table: id 3
[ 7.225036] (stc): st_register(4)
[ 7.230682] (stc): add_channel_to_table: id 4
[ 7.271484] cfg80211: World regulatory domain updated:
[ 7.277862] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 7.287322] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 7.297210] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 7.307708] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 7.317169] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 7.326599] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 7.578277] PVR: Installing MISR with cookie bf038f48
[ 7.584228] PVR: Installing device LISR SGX ISR on IRQ 53 with cookie c726c500
[ 7.592529] PVR: OSUnMapPhysToLin: unmapping 65535 bytes from c8d20000
[ 7.599822] PVR: SysFinalise: Version string: SGX revision = 1.2.0
[ 8.621276] wl12xx: driver version: BETA_01202012_01-1547-g4efe999-dirty
[ 8.628662] wl12xx: compilation time: Sat Jul 14 07:31:32 2012
[ 8.636901] android_usb: already disabled
[ 8.643127] mtp_bind_config
[ 8.647766] adb_bind_config
[ 8.708068] adb_open
bash-3.2# [ 9.292114] (stc): remove_channel_from_table: id 2
[ 9.297576] (stc): remove_channel_from_table: id 3
[ 9.305664] (stc): remove_channel_from_table: id 4
[ 9.310791] (stc): all chnl_ids unregistered
[ 9.315551] (stk) :ldisc_install = 0
[ 9.319396] (stc): st_tty_close
[ 9.347015] omapdss HDMI: Enter omapdss_hdmi_display_set_mode
[ 9.361999] omapdss HDMI: Enter hdmi_display_disable
[ 9.380310] omapdss HDMI: Release c-state constraint for HDMI
[ 9.380310]
[ 9.388824] hdmi: clearing EDID info
[ 9.393646] omapdss HDMI: ENTER hdmi_display_enable
[ 9.403381] omapdss HDMI: Set c-state constraint for HDMI
[ 9.403411]
[ 9.412292] HDCP: invalid AKSV
[ 9.416137] hdcp_3des_cb: hdcp_keys not loaded = 0
[ 9.421356] omapdss HDMI error: *** INVALID AKSV: 0 Do not perform HDCP AUTHENTICATION
[ 9.533355] omapdss DISPC error: timeout waiting for EVSYNC
[ 9.666503] omapdss HDMI: Enter hdmi_display_disable
[ 9.666534] misc dsscomp: [c734d400] ignoring set failure -22
[ 9.666564] cannot apply mgr(tv) on inactive device
[ 9.666564] misc dsscomp: failed while applying -19
[ 9.674530] omapdss HDMI: Release c-state constraint for HDMI
[ 9.674530]
[ 9.675170] Invalid Device Structure
[ 9.711303] cannot apply mgr(tv) on inactive device
[ 9.717529] misc dsscomp: failed while applying -19
[ 9.726043] cannot apply mgr(tv) on inactive device
[ 9.736999] misc dsscomp: failed while applying -19
[ 9.750885] in hpd work 1, state=0
[ 9.754882] omapdss HDMI: ENTER hdmi_display_enable
[ 9.762176] omapdss HDMI: Set c-state constraint for HDMI
[ 9.762207]
[ 9.770721] HDCP: invalid AKSV
[ 9.774261] hdcp_3des_cb: hdcp_keys not loaded = 0
[ 9.782196] omapdss HDMI error: *** INVALID AKSV: 0 Do not perform HDCP AUTHENTICATION
[ 9.891052] cannot apply mgr(tv) on inactive device
[ 9.891510] omapdss DISPC error: timeout waiting for EVSYNC
[ 9.902984] misc dsscomp: failed while applying -19
[ 9.969726] in hpd work 2, state=1
[ 14.133728] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1325000Calib=1177420 margin=0
[ 17.333251] warning: `zygote' uses 32-bit capabilities (legacy support in use)
[ 24.533294] request_suspend_state: wakeup (3->0) at 24524627687 (2000-01-01 00:00:20.776214601 UTC)
[ 24.650360] (stc): st_register(2)
[ 24.654052] (stc): chnl_id list empty :2
[ 24.658538] (stk) : st_kim_start
[ 24.812896] (stk) :ldisc_install = 1
[ 24.821777] (stc): st_tty_open
[ 24.825500] (stk) :line discipline installed
[ 24.830657] (stk) :TIInit_7.2.31.bts
[ 24.861175] acc_open
[ 24.863830] acc_release
[ 25.354400] cfg80211: wext will not work because kernel was compiled with CONFIG_WIRELESS_EXT=n. Tools using wext interface, like iwconfig will not work.
[ 25.378845] wl12xx: loaded
modprobe: FATAL: Could not load /lib/modules/3.0.21-00003-OMAP-Android+/modules.dep: No such file or directory
[ 25.764068] wl12xx: open_count=0, add=1, current_fw=0
[ 25.769592] wl12xx: state: 0
[ 26.102447] (stk) :response timeout during fw download
[ 26.108123] (stk) :download firmware failed
[ 26.113159] (stk) :ldisc_install = 0
[ 26.117492] (stc): st_tty_close
[ 26.455200] wl12xx: TEST_CMD_INI_FILE_RADIO_PARAM: 00000000: 00 00 00 00 19 00 00 00 00 00 ec f6 00 0c 18 f8
[ 26.459167] (stk) :ldisc_install = 1
[ 26.515655] wl12xx: TEST_CMD_INI_FILE_RADIO_PARAM: 00000010: fc 00 08 10 f0 f8 00 0a 14 00 00 00 00 00 00 00
[ 26.519958] (stc): st_tty_open
[ 26.520019] (stk) :line discipline installed
[ 26.535614] (stk) :TIInit_7.2.31.bts
[ 26.564331] wl12xx: TEST_CMD_INI_FILE_RADIO_PARAM: 00000020: 00 00 00 00 00 00 00 ee f4 f8 fe 05 ea f3 fa 01
[ 26.591735] wl12xx: TEST_CMD_INI_FILE_RADIO_PARAM: 00000030: 06 e5 f1 fa 02 07 d9 01 80 00 1d 1f 22 26 27 29
[ 26.605865] wl12xx: TEST_CMD_INI_FILE_RADIO_PARAM: 00000040: 1d 1f 22 26 27 27 16 1d 1e 20 24 25 50 50 50 50
[ 26.629730] wl12xx: TEST_CMD_INI_FILE_RADIO_PARAM: 00000050: 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50
[ 26.695526] wl12xx: TEST_CMD_INI_FILE_RADIO_PARAM: 00000060: 50 50 50 50 50 50 50 50 01 02 02 02 02 00 15 15
[ 26.750457] wl12xx: TEST_CMD_INI_FILE_RADIO_PARAM: 00000070: 15 19 19 15 10 1e 2d 00 9a 01 ae 01 c2 01 cc 01
[ 26.789520] wl12xx: TEST_CMD_INI_FILE_RADIO_PARAM: 00000080: db 01 db 01 d1 01 80 80 80 80 80 80 80 00 00 00
[ 26.822143] wl12xx: TEST_CMD_INI_FILE_RADIO_PARAM: 00000090: 00 00 00 00 1c 1e 21 23 25 50 18 1e 21 23 25 50
[ 26.853027] wl12xx: TEST_CMD_INI_FILE_RADIO_PARAM: 000000a0: 16 1c 1e 20 20 50 50 50 50 50 50 50 50 50 50 50
[ 26.899261] wl12xx: TEST_CMD_INI_FILE_RADIO_PARAM: 000000b0: 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50
[ 26.912933] wl12xx: TEST_CMD_INI_FILE_RADIO_PARAM: 000000c0: 50 50 50 50 50 50 50 50 50 01 02 02 02 02 00 10
[ 26.923553] wl12xx: TEST_CMD_INI_FILE_RADIO_PARAM: 000000d0: 10 10 10 10 10 10 10 10 10 10 10 10 1e 2d 00 00
[ 26.977966] wl12xx: TEST_CMD_INI_FILE_EXT_RADIO_PARAM: 00000000: 00 00 00 00 26 00 00 00 00 00 00 00 00 00 00 00
[ 26.998992] wl12xx: TEST_CMD_INI_FILE_EXT_RADIO_PARAM: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 27.013610] wl12xx: TEST_CMD_INI_FILE_EXT_RADIO_PARAM: 00000020: 00 00 00 00
[ 27.107391] wl12xx: firmware booted (Rev 6.3.8.0.111)
[ 27.179687] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 27.340576] wl12xx: RX_FILTER: 00000000: 00 00 00 00 00 00 00 00 01 00 01 01 00 00 06 02
[ 27.356536] wl12xx: RX_FILTER: 00000010: 00 d2 8b 43 9f fd 00 00
[ 27.410156] wl12xx: RX_FILTER: 00000000: 00 00 00 00 00 00 00 00 01 01 01 01 00 00 02 02
[ 27.462493] wl12xx: RX_FILTER: 00000010: 33 33 00 00
[ 27.493072] wl12xx: RX_FILTER: 00000000: 00 00 00 00 00 00 00 00 00 00 00 00
[ 27.514068] wl12xx: RX_FILTER: 00000000: 00 00 00 00 00 00 00 00 00 01 00 00
[ 27.541900] wl12xx: RX_FILTER: 00000000: 00 00 00 00 00 00 00 00 01 00 01 01 00 00 06 02
[ 27.596343] wl12xx: RX_FILTER: 00000010: 00 d2 8b 43 9f fd 00 00
[ 27.630187] wl12xx: RX_FILTER: 00000000: 00 00 00 00 00 00 00 00 01 01 01 01 00 00 02 02
[ 27.666076] wl12xx: RX_FILTER: 00000010: 33 33 00 00
[ 27.771636] (stc): add_channel_to_table: id 2
[ 27.780822] (stc): st_register(3)
[ 27.798461] (stc): add_channel_to_table: id 3
[ 27.803619] (stc): st_register(4)
[ 27.808044] (stc): add_channel_to_table: id 4
[ 28.989959] (stc): remove_channel_from_table: id 2
[ 29.000488] (stc): remove_channel_from_table: id 3
[ 29.005645] (stc): remove_channel_from_table: id 4
[ 29.010803] (stc): all chnl_ids unregistered
[ 29.015533] (stk) :ldisc_install = 0
[ 29.019500] (stc): st_tty_close
[ 29.532897] (stc): st_register(2)
[ 29.536621] (stc): chnl_id list empty :2
[ 29.546386] (stk) : st_kim_start
[ 29.680450] (stk) :ldisc_install = 1
[ 29.735992] (stc): st_tty_open
[ 29.753021] (stk) :line discipline installed
[ 29.757934] (stk) :TIInit_7.2.31.bts
[ 30.501342] (stc): add_channel_to_table: id 2
[ 30.506378] (stc): st_register(3)
[ 30.510894] (stc): add_channel_to_table: id 3
[ 30.515716] (stc): st_register(4)
[ 30.520050] (stc): add_channel_to_table: id 4
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2# logcat
--------- beginning of /dev/log/main
I/DEBUG ( 108): debuggerd: Jul 14 2012 02:15:53
E/uim-sysfs( 105): uim: Inside main
E/uim-sysfs( 105): uim:ST built into the kernel ?
E/uim-sysfs( 105): uim:BT driver module un-available...
E/uim-sysfs( 105): uim:BT driver built into the kernel ?
E/uim-sysfs( 105): uim:FM driver module un-available...
E/uim-sysfs( 105): uim:FM driver built into the kernel ?
E/uim-sysfs( 105): uim:GPS driver module un-available...
E/uim-sysfs( 105): uim:GPS driver built into the kernel ?
E/uim-sysfs( 105): uim:FM V4L2 driver module un-available...
E/uim-sysfs( 105): uim:FM V4L2 driver built into the kernel ?
E/uim-sysfs( 105): uim:unable to chmod /dev/radio0, might not exist
E/uim-sysfs( 105): uim:found bluetooth rfkill entry @ 0
E/uim-sysfs( 105):
E/uim-sysfs( 105): uim:changed permissions for /sys/class/rfkill/rfkill0/state(0)
E/uim-sysfs( 105):
E/uim-sysfs( 105): uim: Inside st_uart_config
E/uim-sysfs( 105): uim:install set to 1
E/uim-sysfs( 105): uim:opening /dev/ttyO1, while already open
E/uim-sysfs( 105): uim:cleanup
E/uim-sysfs( 105): uim: Inside set_baud_rate
E/uim-sysfs( 105): uim: set_baud_rate() done
E/uim-sysfs( 105): uim: Setting speed to 3686400
E/uim-sysfs( 105): uim: Inside read_command_complete
E/uim-sysfs( 105): uim: Command complete started
E/uim-sysfs( 105): uim: Inside read_hci_event
E/uim-sysfs( 105): uim: read_hci_event
E/uim-sysfs( 105): uim: Command complete done
E/uim-sysfs( 105): uim: Speed changed to 3686400
E/uim-sysfs( 105): uim: Inside set_custom_baud_rate
E/uim-sysfs( 105): uim: Changing baud rate to 3686400, flow control to 1
E/uim-sysfs( 105): uim: set_custom_baud_rate() done
E/uim-sysfs( 105): uim: Installed N_TI_WL Line displine
--------- beginning of /dev/log/system
I/Vold ( 102): Vold 2.1 (the revenge) firing up
E/Vold ( 102): Error reading configuration (No such file or directory)... continuing anyways
I/Netd ( 107): Netd 1.0 starting
V/IMGSRV ( 103): Succesfully loaded gfx modules
V/IMGSRV ( 103): pvrsrvinit complete
I/ ( 112): ServiceManager: 0x281910
D/AndroidRuntime( 111):
D/AndroidRuntime( 111): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime( 111): CheckJNI is ON
I/SurfaceFlinger( 110): SurfaceFlinger is starting
I/SurfaceFlinger( 110): Could not open sysfs entry(/sys/devices/platform/omapdss/display0/s3d_capable)
I/SurfaceFlinger( 110): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
D/libEGL ( 110): loaded /system/lib/egl/libGLES_android.so
D/libEGL ( 110): loaded /vendor/lib/egl/libEGL_POWERVR_SGX540_120.so
I/ ( 113): ServiceManager: 0x1219958
I/audio_hw_primary( 113): boardtype used: hdmi_dongle(1)
I/AudioFlinger( 113): Loaded primary audio interface from OMAP audio HW HAL (audio)
I/AudioFlinger( 113): Using 'OMAP audio HW HAL' (audio.primary) as the primary audio interface
I/AudioFlinger( 113): Loaded a2dp audio interface from A2DP Audio HW HAL (audio)
I/CameraService( 113): CameraService started (pid=113)
D/libEGL ( 110): loaded /vendor/lib/egl/libGLESv1_CM_POWERVR_SGX540_120.so
D/libEGL ( 110): loaded /vendor/lib/egl/libGLESv2_POWERVR_SGX540_120.so
I/SurfaceFlinger( 110): EGL informations:
I/SurfaceFlinger( 110): # of configs : 33
I/SurfaceFlinger( 110): vendor : Android
I/SurfaceFlinger( 110): version : 1.4 Android META-EGL
I/SurfaceFlinger( 110): extensions: EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_base EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_fence_sync EGL_ANDROID_image_native_buffer EGL_AND
I/SurfaceFlinger( 110): Client API: OpenGL ES
I/SurfaceFlinger( 110): EGLSurface: 8-8-8-8, config=0x0
I/SurfaceFlinger( 110): OpenGL informations:
I/SurfaceFlinger( 110): vendor : Imagination Technologies
I/SurfaceFlinger( 110): renderer : PowerVR SGX 540
I/SurfaceFlinger( 110): version : OpenGL ES-CM 1.1
I/SurfaceFlinger( 110): extensions: GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_matrix_get GL_OES_read_format GL_OES_compressed_paletted_texture GL_OES_point_sprite GL_OES_point_size_array GL_OES_matrix_palet
I/SurfaceFlinger( 110): GL_MAX_TEXTURE_SIZE = 2048
I/SurfaceFlinger( 110): GL_MAX_VIEWPORT_DIMS = 2048 x 2048
I/SurfaceFlinger( 110): flags = 00010000
E/uim-sysfs( 105): uim: Un-Installed N_TI_WL Line displine
E/CameraHal( 113): (40137488) hardware/ti/omap4xxx/camera/BaseCameraAdapter.cpp:2619 CameraAdapter_Capabilities - supportedCameras= 1
I/CameraHal( 113): num_cameras = 1
I/AudioFlinger( 113): AudioFlinger's thread 0x1221938 ready to run
W/AudioFlinger( 113): Thread AudioOut_1 cannot connect to the power manager service
I/AudioPolicyService( 113): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
I/ti_hwc ( 110): Primary display is HDMI
I/ti_hwc ( 110): clone region is set to (0,0) to (1280,720)
I/ti_hwc ( 110): Primary display is HDMI - skip clone/dock logic
D/ti_hwc ( 110): #0: 1920x1080 60Hz
D/ti_hwc ( 110): #1: 640x480 59Hz
D/ti_hwc ( 110): #2: 640x480 72Hz
D/ti_hwc ( 110): #3: 640x480 75Hz
D/ti_hwc ( 110): #4: 800x600 56Hz
D/ti_hwc ( 110): #5: 800x600 60Hz
D/ti_hwc ( 110): #6: 800x600 72Hz
D/ti_hwc ( 110): #7: 800x600 75Hz
D/ti_hwc ( 110): #8: 1024x768 60Hz
D/ti_hwc ( 110): #9: 1024x768 70Hz
D/ti_hwc ( 110): #10: 1024x768 75Hz
D/ti_hwc ( 110): #11: 1280x1024 75Hz
D/ti_hwc ( 110): #12: 1152x864 75Hz
D/ti_hwc ( 110): #13: 1280x960 60Hz
D/ti_hwc ( 110): #14: 1280x1024 60Hz
D/ti_hwc ( 110): #15: 720x480 59Hz
D/ti_hwc ( 110): #16: 1280x720 60Hz
D/ti_hwc ( 110): #17: 1280x720 50Hz
D/ti_hwc ( 110): #18: 720x576 50Hz
D/ti_hwc ( 110): #19: 640x480 59Hz
D/ti_hwc ( 110): #20: 720x480 59Hz
D/ti_hwc ( 110): #21: 720x480 59Hz
D/ti_hwc ( 110): #22: 720x576 50Hz
D/ti_hwc ( 110): #23: 720x576 50Hz
D/ti_hwc ( 110): #24: 1280x720 50Hz
D/ti_hwc ( 110): #25: 1280x720 60Hz
D/ti_hwc ( 110): #26: 1920x540 50Hz
D/ti_hwc ( 110): #27: 1920x540 60Hz
D/ti_hwc ( 110): #28: 1920x1080 50Hz
D/ti_hwc ( 110): #29: 1920x1080 60Hz
D/ti_hwc ( 110): picking #16
I/ti_hwc ( 110): omap4_hwc_device_open(rgb_order=1 nv12_only=0)
I/ti_hwc ( 110): Unable to open gc-core device (1), blits disabled
D/libEGL ( 171): loaded /system/lib/egl/libGLES_android.so
D/libEGL ( 171): loaded /vendor/lib/egl/libEGL_POWERVR_SGX540_120.so
D/libEGL ( 171): loaded /vendor/lib/egl/libGLESv1_CM_POWERVR_SGX540_120.so
D/libEGL ( 171): loaded /vendor/lib/egl/libGLESv2_POWERVR_SGX540_120.so
E/BluetoothA2dpService( 111): SystemProperties.BLUETI_ENHANCEMENT == false, createStatusMap not implemented
E/BluetoothA2dpService( 111): SystemProperties.BLUETI_ENHANCEMENT == false, createSettingsMap not implemented
E/BluetoothA2dpService( 111): SystemProperties.BLUETI_ENHANCEMENT == false, createSettingValuesMap not implemented
E/BluetoothA2dpService( 111): SystemProperties.BLUETI_ENHANCEMENT == false, createMetadataMap not implemented
I/SamplingProfilerIntegration( 111): Profiling disabled.
I/Zygote ( 111): Preloading classes...
D/dalvikvm( 111): GC_EXPLICIT freed 36K, 84% free 414K/2560K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 4K, 82% free 478K/2560K, paused 1ms+0ms
D/dalvikvm( 111): GC_EXPLICIT freed 20K, 80% free 514K/2560K, paused 0ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 27K, 79% free 542K/2560K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 15K, 78% free 581K/2560K, paused 0ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 27K, 77% free 608K/2560K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 30K, 75% free 641K/2560K, paused 1ms+1ms
D/TextLayoutCache( 111): Using debug level: 0 - Debug Enabled: 0
W/Zygote ( 111): Class not found for preloading: android.media.AudioManager$2
I/dalvikvm( 111): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
D/MtpDeviceJNI( 111): register_android_mtp_MtpDevice
W/Zygote ( 111): Class not found for preloading: android.media.IRemoteControlClientDispatcher
W/Zygote ( 111): Class not found for preloading: android.media.IRemoteControlClientDispatcher$Stub
D/dalvikvm( 111): GC_EXPLICIT freed 20K, 74% free 679K/2560K, paused 1ms+0ms
D/dalvikvm( 111): GC_FOR_ALLOC freed 217K, 62% free 974K/2560K, paused 8ms
D/dalvikvm( 111): GC_EXPLICIT freed 44K, 60% free 1030K/2560K, paused 0ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 27K, 59% free 1059K/2560K, paused 3ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 8K, 57% free 1107K/2560K, paused 2ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 24K, 55% free 1173K/2560K, paused 2ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 48K, 44% free 1452K/2560K, paused 1ms+1ms
W/Zygote ( 111): Class not found for preloading: android.text.TextDirectionHeuristics$CharCount
W/Zygote ( 111): Class not found for preloading: android.text.method.WordIterator$1
D/dalvikvm( 111): GC_EXPLICIT freed 34K, 42% free 1486K/2560K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 32K, 42% free 1509K/2560K, paused 1ms+1ms
I/dalvikvm( 111): threadid=1: recursive native library load attempt (/system/lib/libwebcore.so)
D/dalvikvm( 111): No JNI_OnLoad found in /system/lib/libchromium_net.so 0x0, skipping init
D/dalvikvm( 111): GC_EXPLICIT freed 26K, 40% free 1557K/2560K, paused 2ms+1ms
W/Zygote ( 111): Class not found for preloading: android.widget.EdgeGlow
D/dalvikvm( 111): GC_EXPLICIT freed 25K, 39% free 1586K/2560K, paused 1ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 71K, 37% free 1632K/2560K, paused 1ms+1ms
E/PhonePolicy( 111): Could not preload class for phone policy: com.android.internal.policy.impl.PhoneWindow$ContextMenuCallback
D/dalvikvm( 111): GC_EXPLICIT freed 33K, 36% free 1654K/2560K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 28K, 35% free 1682K/2560K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 26K, 34% free 1713K/2560K, paused 2ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 32K, 33% free 1738K/2560K, paused 1ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 31K, 31% free 1766K/2560K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 71K, 29% free 1822K/2560K, paused 1ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 39K, 29% free 1838K/2560K, paused 1ms+1ms
I/System ( 111): Loaded time zone names for in 520ms (516ms in ICU)
I/System ( 111): Loaded time zone names for en_US in 270ms (266ms in ICU)
D/dalvikvm( 111): GC_EXPLICIT freed 325K, 24% free 1948K/2560K, paused 1ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 15K, 22% free 2009K/2560K, paused 2ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 51K, 21% free 2040K/2560K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 28K, 20% free 2072K/2560K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 37K, 19% free 2088K/2560K, paused 2ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 32K, 18% free 2111K/2560K, paused 1ms+2ms
I/Zygote ( 111): ...preloaded 2297 classes in 3648ms.
D/dalvikvm( 111): GC_EXPLICIT freed 22K, 18% free 2115K/2560K, paused 2ms+1ms
I/Zygote ( 111): Preloading resources...
D/dalvikvm( 111): GC_EXPLICIT freed 1K, 16% free 2170K/2560K, paused 1ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 1K, 14% free 2221K/2560K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 3K, 12% free 2268K/2560K, paused 1ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 3K, 10% free 2316K/2560K, paused 1ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 4K, 8% free 2363K/2560K, paused 1ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 5K, 6% free 2414K/2560K, paused 4ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 4K, 7% free 2461K/2627K, paused 1ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 5K, 5% free 2506K/2627K, paused 2ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 4K, 6% free 2555K/2691K, paused 2ms+3ms
D/dalvikvm( 111): GC_EXPLICIT freed 4K, 6% free 2605K/2755K, paused 1ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 5K, 6% free 2665K/2819K, paused 2ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 2K, 4% free 2715K/2819K, paused 4ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 3K, 5% free 2761K/2883K, paused 4ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 6K, 5% free 2809K/2947K, paused 1ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 7K, 4% free 2856K/2947K, paused 2ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 4K, 4% free 2904K/3011K, paused 1ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 9K, 3% free 2948K/3011K, paused 4ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 8K, 2% free 3027K/3075K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 5K, 3% free 3072K/3139K, paused 2ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 4K, 3% free 3122K/3203K, paused 4ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 4K, 2% free 3169K/3203K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 5K, 1% free 3245K/3267K, paused 2ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 4K, 3% free 3560K/3651K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 7K, 2% free 3613K/3651K, paused 1ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 2K, 2% free 3663K/3715K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 5K, 2% free 3712K/3779K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 4K, 1% free 3886K/3907K, paused 1ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 3K, 1% free 3933K/3971K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 5K, 3% free 4993K/5123K, paused 2ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 5K, 4% free 6014K/6211K, paused 2ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 4K, 3% free 6063K/6211K, paused 2ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 7K, 2% free 6107K/6211K, paused 2ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 6K, 1% free 6155K/6211K, paused 2ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 5K, 2% free 6202K/6275K, paused 1ms+3ms
D/dalvikvm( 111): GC_EXPLICIT freed 2K, 1% free 6254K/6275K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 4K, 1% free 6302K/6339K, paused 2ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed 6K, 1% free 6363K/6403K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 3K, 1% free 6428K/6467K, paused 2ms+1ms
I/Zygote ( 111): ...preloaded 379 resources in 2277ms.
D/dalvikvm( 111): GC_EXPLICIT freed 20K, 2% free 6462K/6531K, paused 1ms+2ms
I/Zygote ( 111): ...preloaded 31 resources in 34ms.
D/dalvikvm( 111): GC_EXPLICIT freed 14K, 2% free 6465K/6531K, paused 1ms+1ms
D/dalvikvm( 111): GC_EXPLICIT freed 6K, 2% free 6459K/6531K, paused 2ms+2ms
D/dalvikvm( 111): GC_EXPLICIT freed <1K, 2% free 6459K/6531K, paused 1ms+2ms
I/dalvikvm( 111): System server process 180 has been created
I/Zygote ( 111): Accepting command socket connections
E/BatteryService( 180): acOnlinePath not found
E/BatteryService( 180): usbOnlinePath not found
E/BatteryService( 180): batteryStatusPath not found
E/BatteryService( 180): batteryHealthPath not found
E/BatteryService( 180): batteryPresentPath not found
E/BatteryService( 180): batteryCapacityPath not found
E/BatteryService( 180): batteryVoltagePath not found
E/BatteryService( 180): batteryTemperaturePath not found
E/BatteryService( 180): batteryTechnologyPath not found
I/sysproc ( 180): Entered system_init()
I/sysproc ( 180): ServiceManager: 0xb9d790
D/SensorService( 180): nuSensorService starting...
I/SensorService( 180): MMA7455L 3-axis Low-g Accelerometer
I/sysproc ( 180): System server: starting Android runtime.
I/sysproc ( 180): System server: starting Android services.
D/SensorService( 180): nuSensorService thread starting...
I/sysproc ( 180): System server: entering thread pool.
I/SystemServer( 180): Entered the Android system server!
I/SystemServer( 180): Entropy Service
I/SystemServer( 180): Power Manager
I/SystemServer( 180): Activity Manager
I/ActivityManager( 180): Memory class: 48
I/SystemServer( 180): Telephony Registry
I/SystemServer( 180): Package Manager
I/ActivityManager( 180): Enabled StrictMode logging for AThread's Looper
D/dalvikvm( 180): GC_CONCURRENT freed 241K, 5% free 6651K/6983K, paused 2ms+3ms
D/dalvikvm( 180): GC_FOR_ALLOC freed 394K, 9% free 6639K/7239K, paused 31ms
E/StrictMode( 180): A resource was acquired at attached stack trace but never released. See java.io.Closeable for information on avoiding resource leaks.
E/StrictMode( 180): java.lang.Throwable: Explicit termination method 'close' not called
E/StrictMode( 180): at dalvik.system.CloseGuard.open(CloseGuard.java:184)
E/StrictMode( 180): at java.io.FileInputStream.<init>(FileInputStream.java:80)
E/StrictMode( 180): at com.android.server.pm.UserManager.readUserList(UserManager.java:114)
E/StrictMode( 180): at com.android.server.pm.UserManager.<init>(UserManager.java:81)
E/StrictMode( 180): at com.android.server.pm.UserManager.<init>(UserManager.java:85)
E/StrictMode( 180): at com.android.server.pm.PackageManagerService.<init>(PackageManagerService.java:931)
E/StrictMode( 180): at com.android.server.pm.PackageManagerService.main(PackageManagerService.java:834)
E/StrictMode( 180): at com.android.server.ServerThread.run(SystemServer.java:165)
D/StrictMode( 180): No activity manager; failed to Dropbox violation.
W/PackageManager( 180): Running ENG build: no pre-dexopt!
D/dalvikvm( 180): GC_CONCURRENT freed 269K, 7% free 6776K/7239K, paused 2ms+2ms
W/PackageManager( 180): Package com.android.gallery3d desires unavailable shared library com.google.android.media.effects; ignoring!
D/dalvikvm( 180): GC_CONCURRENT freed 157K, 4% free 7043K/7303K, paused 5ms+4ms
W/PackageManager( 180): Package com.android.camera desires unavailable shared library com.google.android.media.effects; ignoring!
D/dalvikvm( 180): GC_CONCURRENT freed 190K, 4% free 7283K/7559K, paused 5ms+4ms
W/PackageParser( 180): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #125
W/PackageParser( 180): No actions in intent filter at /system/app/Contacts.apk Binary XML file line #525
D/dalvikvm( 180): GC_CONCURRENT freed 220K, 5% free 7490K/7815K, paused 4ms+4ms
D/PackageManager( 180): No files in app dir /vendor/app
I/installd( 115): new connection
I/Installer( 180): connecting...
W/PackageManager( 180): Package com.skype.raider desires unavailable shared library com.htc.hardware.twinCamDevice; ignoring!
W/PackageManager( 180): Package com.skype.raider desires unavailable shared library com.motorola.hardware.frontcamera; ignoring!
W/PackageManager( 180): Package com.skype.raider desires unavailable shared library com.sprint.hardware.twinCamDevice; ignoring!
I/PackageManager( 180): Time to scan packages: 3.828 seconds
W/PackageManager( 180): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.contacts
W/PackageManager( 180): Unknown permission android.permission.ADD_SYSTEM_SERVICE in package com.android.phone
W/PackageManager( 180): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager( 180): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager( 180): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager( 180): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager( 180): Not granting permission android.permission.CALL_PRIVILEGED to package com.skype.raider (protectionLevel=3 flags=0x8be44)
W/PackageManager( 180): Unknown permission android.permission.READ_EXTERNAL_STORAGE in package com.android.videoeditor
W/PackageManager( 180): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager( 180): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.contacts
W/PackageManager( 180): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cp in package com.android.providers.contacts
W/PackageManager( 180): Unknown permission com.google.android.googleapps.permission.ACCESS_GOOGLE_PASSWORD in package com.android.development
W/PackageManager( 180): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.development
W/PackageManager( 180): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.ALL_SERVICES in package com.android.development
W/PackageManager( 180): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.YouTubeUser in package com.android.development
W/PackageManager( 180): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x8be45)
D/dalvikvm( 180): GC_EXPLICIT freed 382K, 7% free 7451K/7943K, paused 4ms+2ms
I/SystemServer( 180): Account Manager
D/PackageManager( 180): generateServicesMap(android.accounts.AccountAuthenticator): 3 services unchanged
I/SystemServer( 180): Content Manager
D/PackageManager( 180): generateServicesMap(android.content.SyncAdapter): 5 services unchanged
I/SystemServer( 180): System Content Providers
I/ActivityThread( 180): Pub settings: com.android.providers.settings.SettingsProvider
D/SettingsProvider( 180): cache for settings table 'secure' rows=37; fullycached=true
D/SettingsProvider( 180): cache for settings table 'system' rows=51; fullycached=true
I/SystemServer( 180): Lights Service
I/SystemServer( 180): Battery Service
I/SystemServer( 180): Vibrator Service
I/power ( 180): *** set_screen_state 1
I/SystemServer( 180): Alarm Manager
I/SystemServer( 180): Init Watchdog
I/SystemServer( 180): Window Manager
I/InputManager( 180): Initializing input manager
D/dalvikvm( 180): GC_CONCURRENT freed 318K, 5% free 7675K/8071K, paused 1ms+3ms
W/StatusBarManager( 180): warning: no STATUS_BAR_SERVICE
E/ASFDummyExtractor( 113): isASFParserAvailable
W/ASFDummyExtractor( 113): ASF parser is not available
E/EventHub( 180): could not get driver version for /dev/input/mice, Not a typewriter
I/InputManager( 180): Starting input manager
I/SystemServer( 180): Bluetooth Service
I/WindowManager( 180): Enabled StrictMode logging for WMThread's Looper
I/WindowManager( 180): Enabled StrictMode for PolicyThread's Looper
D/EventHub( 180): No input device configuration file found for device 'Panda Headset Jack'.
I/EventHub( 180): New device: id=1, fd=99, path='/dev/input/event1', name='Panda Headset Jack', classes=0x80, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false
D/EventHub( 180): No input device configuration file found for device 'Always Innovating Always Innovating USB Keyboard / Touchpad'.
I/EventHub( 180): New device: id=2, fd=100, path='/dev/input/event3', name='Always Innovating Always Innovating USB Keyboard / Touchpad', classes=0x80000008, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false
E/EventHub( 180): could not get driver version for /dev/input/mouse0, Not a typewriter
I/BluetoothProfileState( 180): Message:Entering Stable State
I/AudioPlayer( 113): TimeInterpolator::seek(media_time=0)
I/AudioPlayer( 113): mLatencyUs = 0
I/AudioPlayer( 113): TimeInterpolator state STOPPED -> FIRST_ROLLING (input: POST_BUFFER)
I/AudioPlayer( 113): TimeInterpolator FIRST_ROLLING frame_usecs=23219
D/BluetoothAdapterStateMachine( 180): PowerOff process message: 1
D/BluetoothAdapterStateMachine( 180): Bluetooth state 10 -> 11
I/SystemServer( 180): Input Method Service
W/InputManagerService( 180): Couldn't create dir.: /data/system/inputmethod
W/ResourceType( 180): Failure getting entry for 0x7f060000 (t=5 e=0) in package 0 (error -75)
I/bluedroid( 180): Starting hciattach daemon
I/AudioPlayer( 113): void omap_enhancement::TimeInterpolator::pause(bool)()
I/AudioPlayer( 113): TimeInterpolator state FIRST_ROLLING -> STOPPED (input: STOP)
I/AudioPlayer( 113): TimeInterpolator::seek(media_time=139314)
I/AudioPlayer( 113): TimeInterpolator state STOPPED -> STOPPED (input: STOP)
E/AudioPlayer( 113): TimeInterpolator calling set_state() should actually change a state.
E/AudioPlayer( 113): TimeInterpolator this state should not be reachable.
I/SystemServer( 180): Accessibility Manager
I/Display ( 180): Mirroring region is Rect(0, 0 - 1280, 720)
I/EventHub( 180): New device: id=3, fd=118, path='/dev/input/event2', name='Always Innovating Always Innovating USB Keyboard / Touchpad', classes=0x80000003, configuration='', keyLayout='/system/usr/keylayout/Generic.kl', keyCharacterMape
D/EventHub( 180): No input device configuration file found for device 'twl6030_pwrbutton'.
I/EventHub( 180): New device: id=4, fd=119, path='/dev/input/event0', name='twl6030_pwrbutton', classes=0x1, configuration='', keyLayout='/system/usr/keylayout/twl6030_pwrbutton.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', bue
I/InputReader( 180): Device added: id=4, name='twl6030_pwrbutton', sources=0x00000101
I/InputReader( 180): Device added: id=3, name='Always Innovating Always Innovating USB Keyboard / Touchpad', sources=0x00000101
I/InputReader( 180): Device added: id=2, name='Always Innovating Always Innovating USB Keyboard / Touchpad', sources=0x00002002
I/InputReader( 180): Device added: id=1, name='Panda Headset Jack', sources=0x80000000
I/InputReader( 180): Reconfiguring input devices. changes=0x00000004
I/ActivityManager( 180): Config changed: {1.0 0mcc0mnc en_US layoutdir=0 sw720dp w1280dp h672dp lrg long land ?uimode ?night -touch -keyb/v/h -nav/h s.2}
D/PermissionCache( 110): checking android.permission.ACCESS_SURFACE_FLINGER for uid=1000 => granted (488 us)
I/SystemServer( 180): Device Policy
I/ActivityManager( 180): Config changed: {1.0 0mcc0mnc en_US layoutdir=0 sw720dp w1280dp h672dp lrg long land ?uimode ?night -touch qwerty/v/v -nav/h s.3}
I/SystemServer( 180): Status Bar
I/SystemServer( 180): Clipboard Service
I/SystemServer( 180): NetworkManagement Service
I/SystemServer( 180): Text Service Manager Service
I/SystemServer( 180): NetworkStats Service
I/SystemServer( 180): NetworkPolicy Service
I/SystemServer( 180): Wi-Fi P2pService
I/SystemServer( 180): Wi-Fi Service
E/CommandListener( 107): Failed to open /proc/sys/net/ipv6/conf/wlan0/disable_ipv6: No such file or directory
E/WifiStateMachine( 180): Failed to disable IPv6: java.lang.IllegalStateException: Unable to communicate to native daemon for disabling ipv6
I/SystemServer( 180): Connectivity Service
D/ConnectivityService( 180): ConnectivityService starting up
D/NetworkManagementService( 180): Registering observer
E/MobileDataStateTracker( 180): default: Ignoring feature request because could not acquire PhoneService
E/MobileDataStateTracker( 180): default: Could not enable APN type "default"
I/WifiService( 180): WifiService starting up with Wi-Fi enabled
I/SystemServer( 180): Throttle Service
I/SystemServer( 180): Mount Service
D/MountService( 180): got storage path: /mnt/sdcard description: Internal Storage primary: true removable: false emulated: true mtpReserve: 0 allowMassStorage: false maxFileSize: 0
D/MountService( 180): using emulated external storage
I/SystemServer( 180): Notification Manager
D/dalvikvm( 180): GC_CONCURRENT freed 330K, 5% free 7857K/8263K, paused 2ms+3ms
I/SystemServer( 180): Device Storage Monitor
I/SystemServer( 180): starting SUPL Service (SystemServer)
D/VoldCmdListener( 102): volume list
I/SystemServer( 180): Location Manager
I/SystemServer( 180): Country Detector
I/SystemServer( 180): Search Service
I/SystemServer( 180): DropBox Service
I/SystemServer( 180): Wallpaper Service
I/SystemServer( 180): Audio Service
I/SystemServer( 180): Dock Observer
W/DockObserver( 180): This kernel does not have dock station support
I/SystemServer( 180): Wired Accessory Observer
I/SystemServer( 180): USB Service
I/SystemServer( 180): UI Mode Manager Service
I/SystemServer( 180): Backup Service
V/BackupManagerService( 180): Initializing package tracking
V/BackupManagerService( 180): No ancestral data
V/BackupManagerService( 180): addPackageParticipantsLocked: all
I/BackupManagerService( 180): New app android never backed up; scheduling
I/BackupManagerService( 180): New app com.android.browser never backed up; scheduling
I/BackupManagerService( 180): New app com.android.calendar never backed up; scheduling
I/BackupManagerService( 180): New app com.android.inputmethod.latin never backed up; scheduling
I/BackupManagerService( 180): New app com.android.nfc never backed up; scheduling
I/BackupManagerService( 180): New app com.android.providers.settings never backed up; scheduling
I/BackupManagerService( 180): New app com.android.providers.userdictionary never backed up; scheduling
I/BackupManagerService( 180): New app com.android.sharedstoragebackup never backed up; scheduling
V/BackupManagerService( 180): Registering transport android/com.android.internal.backup.LocalTransport = com.android.internal.backup.LocalTransport@4124f9f0
V/BackupManagerService( 180): Starting with transport android/com.android.internal.backup.LocalTransport
V/BackupManagerService( 180): Google transport not present
I/BackupManagerService( 180): Found stale backup journal, scheduling
I/BackupManagerService( 180): android
I/BackupManagerService( 180): com.android.browser
I/BackupManagerService( 180): com.android.calendar
I/BackupManagerService( 180): com.android.inputmethod.latin
I/BackupManagerService( 180): com.android.nfc
I/BackupManagerService( 180): com.android.providers.settings
I/BackupManagerService( 180): com.android.providers.userdictionary
I/BackupManagerService( 180): com.android.sharedstoragebackup
D/dalvikvm( 180): GC_CONCURRENT freed 293K, 5% free 7987K/8391K, paused 3ms+4ms
I/BackupManagerService( 180): Backup enabled => false
I/BackupManagerService( 180): Opting out of backup
I/SystemServer( 180): AppWidget Service
I/SystemServer( 180): Recognition Service
I/SystemServer( 180): DiskStats Service
I/SystemServer( 180): SamplingProfiler Service
I/SystemServer( 180): NetworkTimeUpdateService
I/WindowManager( 180): SAFE MODE not enabled
D/dalvikvm( 180): JIT started for system_server
D/PowerManagerService( 180): system ready!
I/Zygote ( 180): Process: zygote socket opened
I/ActivityManager( 180): System now ready
I/SystemServer( 180): Making services ready
D/SystemServer( 180): Starting service: Intent { cmp=com.android.systemui/.SystemUIService }
I/ActivityManager( 180): Start proc com.android.systemui for service com.android.systemui/.SystemUIService: pid=250 uid=1000 gids={1015, 3002, 3001, 3003}
D/NetworkManagementService( 180): enabling bandwidth control
D/SystemUIService( 250): loading: class com.android.systemui.statusbar.tablet.TabletStatusBar
D/SystemUIService( 250): running: com.android.systemui.statusbar.tablet.TabletStatusBar@410b7aa8
I/Display ( 250): Mirroring region is Rect(0, 0 - 1280, 720)
I/StatusBar.HeightReceiver( 250): Resizing status bar plugged=true height=48 old=0
I/ActivityManager( 180): Start proc android.process.media for broadcast com.android.providers.media/.UsbReceiver: pid=298 uid=10010 gids={1015, 1023, 1024, 2001, 3003, 3007}
I/ActivityManager( 180): Config changed: {1.0 0mcc0mnc en_US layoutdir=0 sw720dp w1280dp h672dp lrg long land -touch qwerty/v/v -nav/h s.4}
W/RecognitionManagerService( 180): no available voice recognition services found
D/dalvikvm( 250): GC_CONCURRENT freed 100K, 3% free 6782K/6983K, paused 2ms+2ms
I/ActivityThread( 298): Pub media: com.android.providers.media.MediaProvider
W/InputManagerService( 180): Ignoring setImeWindowStatus of uid 1000 token: null
D/CommandListener( 107): Setting iface cfg
D/CommandListener( 107): Trying to bring down wlan0
D/CommandListener( 107): broadcast flag ignored
D/CommandListener( 107): multicast flag ignored
D/NetworkManagementService( 180): rsp <213 00:d2:8b:43:9f:fd 0.0.0.0 0 [down broadcast multicast]>
D/NetworkManagementService( 180): flags <[down broadcast multicast]>
I/ActivityManager( 180): Start proc com.android.inputmethod.latin for service com.android.inputmethod.latin/.LatinIME: pid=315 uid=10034 gids={}
W/ThrottleService( 180): unable to find stats for iface rmnet0
I/ActivityManager( 180): Start proc com.android.phone for added application com.android.phone: pid=331 uid=1001 gids={3002, 3001, 3003, 1015}
I/ActivityManager( 180): Start proc com.android.nfc for added application com.android.nfc: pid=347 uid=1027 gids={3002, 3001}
I/ActivityManager( 180): START {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher/com.android.launcher2.Launcher} from pid 0
D/dalvikvm( 250): GC_CONCURRENT freed 25K, 3% free 7200K/7367K, paused 2ms+3ms
D/dalvikvm( 180): GC_CONCURRENT freed 301K, 5% free 8109K/8519K, paused 2ms+13ms
I/ActivityManager( 180): Start proc com.android.launcher for activity com.android.launcher/com.android.launcher2.Launcher: pid=362 uid=10015 gids={}
I/SystemServer( 180): Enabled StrictMode for system server main thread.
D/dalvikvm( 180): GREF has increased to 201
I/wpa_supplicant( 313): rfkill: Cannot open RFKILL control device
I/ActivityThread( 331): Pub mms: com.android.providers.telephony.MmsProvider
I/ActivityThread( 362): Pub com.android.launcher2.settings: com.android.launcher2.LauncherProvider
E/ActivityThread( 315): Failed to find provider info for com.android.inputmethod.latin.dictionarypack
I/ActivityManager( 180): Start proc android.process.acore for content provider com.android.providers.userdictionary/.UserDictionaryProvider: pid=390 uid=10008 gids={3003, 1015}
D/dalvikvm( 315): GC_CONCURRENT freed 157K, 4% free 6778K/7047K, paused 2ms+19ms
D/dalvikvm( 362): GC_CONCURRENT freed 235K, 5% free 6654K/6983K, paused 2ms+2ms
E/BinaryDictionaryGetter( 315): Could not find a dictionary pack
I/NfcService( 347): Starting NFC service
I/ActivityThread( 331): Pub sms: com.android.providers.telephony.SmsProvider
I/ActivityThread( 331): Pub telephony: com.android.providers.telephony.TelephonyProvider
W/TelephonyProvider( 331): onCreate: confFile=/system/etc/apns-conf.xml oldCheckSum=-1
I/ActivityThread( 331): Pub icc: com.android.phone.IccProvider
I/ActivityThread( 331): Pub mms-sms: com.android.providers.telephony.MmsSmsProvider
D/NFC JNI ( 347): NFC Service : loading JNI
I/ActivityThread( 390): Pub com.android.voicemail: com.android.providers.contacts.VoicemailContentProvider
I/RegisteredComponentCache( 347): ComponentInfo: ResolveInfo{410c4588 com.android.apps.tag.TagViewer p=0 o=0 m=0x108000}, techs: android.nfc.tech.Ndef,
I/Process ( 180): Sending signal. PID: 362 SIG: 3
I/dalvikvm( 362): threadid=3: reacting to signal 3
I/dalvikvm( 362): Wrote stack traces to '/data/anr/traces.txt'
I/StatusBarManagerService( 180): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@411a5438
D/SystemUIService( 250): loading: class com.android.systemui.power.PowerUI
D/SystemUIService( 250): running: com.android.systemui.power.PowerUI@411b4bd8
D/dalvikvm( 331): GC_CONCURRENT freed 222K, 5% free 6659K/6983K, paused 2ms+9ms
I/NfceeAccess( 347): read 3 signature(s) for NFCEE access
I/StatusBar.HeightReceiver( 250): Resizing status bar plugged=true height=48 old=48
D/dalvikvm( 250): GC_CONCURRENT freed 76K, 3% free 7591K/7751K, paused 2ms+2ms
I/ActivityThread( 390): Pub com.android.social: com.android.providers.contacts.SocialProvider
I/ActivityThread( 390): Pub applications: com.android.providers.applications.ApplicationsProvider
I/ActivityManager( 180): Start proc com.android.smspush for service com.android.smspush/.WapPushManager: pid=413 uid=10025 gids={}
D/dalvikvm( 347): GC_CONCURRENT freed 302K, 7% free 6620K/7047K, paused 4ms+3ms
D/dalvikvm( 180): GREF has increased to 301
D/WifiService( 180): New client listening to asynchronous messages
D/dalvikvm( 298): GC_CONCURRENT freed 295K, 6% free 6600K/6983K, paused 2ms+3ms
D/ ( 331): [ApnContext] set reason as dataEnabled, for type default,current state IDLE
D/ ( 331): [ApnContext] set reason as dataEnabled, for type mms,current state IDLE
D/ ( 331): [ApnContext] set reason as dataEnabled, for type supl,current state IDLE
D/ ( 331): [ApnContext] set reason as dataEnabled, for type hipri,current state IDLE
D/ ( 331): [ApnContext] set reason as dataEnabled, for type fota,current state IDLE
D/ ( 331): [ApnContext] set reason as dataEnabled, for type ims,current state IDLE
D/ ( 331): [ApnContext] set reason as dataEnabled, for type cbs,current state IDLE
D/NfcService( 347): checking on firmware download
D/NfcService( 347): NFC is on. Doing normal stuff
I/NfcService( 347): Enabling NFC
D/NFC JNI ( 347): Start Initialization
E/NFC JNI ( 347): phLibNfc_Mgt_ConfigureDriver() returned 0x0106[NFCSTATUS_INVALID_DEVICE]
E/NFC JNI ( 347): phLibNfc_Mgt_Initialize() returned 0x0001[NFCSTATUS_INVALID_PARAMETER]
D/NFC JNI ( 347): Download new Firmware
E/NFC JNI ( 347): phLibNfc_Mgt_IoCtl() (download) returned 0x0001[NFCSTATUS_INVALID_PARAMETER]
W/NFC JNI ( 347): Firmware update FAILED
I/ActivityThread( 298): Pub downloads: com.android.providers.downloads.DownloadProvider
E/NFC JNI ( 347): Unable to update firmware, giving up
D/CAT ( 331): CatService: Running CAT service. STK app installed:false
D/CAT ( 331): CatService: NEW sInstance
D/NFC JNI ( 347): Terminating client thread...
W/NfcService( 347): Error enabling NFC
D/dalvikvm( 390): GC_CONCURRENT freed 331K, 7% free 6590K/7047K, paused 2ms+2ms
D/CallManager( 331): registerPhone(GSM Handler (com.android.internal.telephony.PhoneProxy) {410e6320})
I/ActivityThread( 390): Pub contacts;com.android.contacts: com.android.providers.contacts.ContactsProvider2
I/ActivityThread( 298): Pub drm: com.android.providers.drm.DrmProvider
I/DownloadManager( 298): in removeSpuriousFiles
D/AudioSpeexSRC( 113): AudioResamplerSpeex::init() mChannelCount=2, mInSampleRate=44100, mSampleRate=44100, mQuality=2
D/AudioResampler( 113): static resampler for checkRate() allocated
W/ActivityManager( 180): Unable to start service Intent { act=com.android.ussd.IExtendedNetworkService }: not found
D/dalvikvm( 362): GC_CONCURRENT freed 125K, 4% free 6931K/7175K, paused 2ms+2ms
I/SearchManagerService( 180): Building list of searchable activities
I/ActivityThread( 390): Pub call_log: com.android.providers.contacts.CallLogProvider
I/ActivityThread( 390): Pub user_dictionary: com.android.providers.userdictionary.UserDictionaryProvider
D/dalvikvm( 180): GC_CONCURRENT freed 347K, 6% free 8258K/8711K, paused 6ms+5ms
D/dalvikvm( 180): GC_FOR_ALLOC freed 177K, 8% free 8264K/8903K, paused 59ms
I/dalvikvm-heap( 180): Grow heap (frag case) to 8.255MB for 116746-byte allocation
D/dalvikvm( 180): GC_FOR_ALLOC freed 90K, 9% free 8288K/9031K, paused 29ms
D/libEGL ( 250): loaded /system/lib/egl/libGLES_android.so
D/libEGL ( 250): loaded /vendor/lib/egl/libEGL_POWERVR_SGX540_120.so
D/libEGL ( 250): loaded /vendor/lib/egl/libGLESv1_CM_POWERVR_SGX540_120.so
D/libEGL ( 250): loaded /vendor/lib/egl/libGLESv2_POWERVR_SGX540_120.so
D/dalvikvm( 331): GC_CONCURRENT freed 287K, 6% free 6760K/7175K, paused 3ms+17ms
D/dalvikvm( 180): GC_FOR_ALLOC freed 60K, 8% free 8310K/9031K, paused 67ms
I/dalvikvm-heap( 180): Grow heap (frag case) to 8.356MB for 175114-byte allocation
D/OpenGLRenderer( 250): Enabling debug mode 0
D/dalvikvm( 180): GC_FOR_ALLOC freed 116K, 10% free 8365K/9223K, paused 45ms
I/wpa_supplicant( 313): wpa_driver_nl80211_driver_cmd: Unsupported command BTCOEXSCAN-STOP
I/ActivityManager( 180): Start proc com.android.settings for broadcast com.android.settings/.widget.SettingsAppWidgetProvider: pid=451 uid=1000 gids={1015, 3002, 3001, 3003}
D/libEGL ( 362): loaded /system/lib/egl/libGLES_android.so
D/libEGL ( 362): loaded /vendor/lib/egl/libEGL_POWERVR_SGX540_120.so
D/dalvikvm( 111): GC_EXPLICIT freed 34K, 5% free 6471K/6787K, paused 2ms+2ms
D/libEGL ( 362): loaded /vendor/lib/egl/libGLESv1_CM_POWERVR_SGX540_120.so
D/libEGL ( 362): loaded /vendor/lib/egl/libGLESv2_POWERVR_SGX540_120.so
D/dalvikvm( 111): GC_EXPLICIT freed <1K, 5% free 6471K/6787K, paused 2ms+2ms
D/dalvikvm( 180): GC_EXPLICIT freed 414K, 9% free 8462K/9223K, paused 3ms+15ms
D/Bluetooth HSHFP( 331): Starting BluetoothHeadsetService
D/dalvikvm( 111): GC_EXPLICIT freed <1K, 5% free 6471K/6787K, paused 1ms+2ms
I/DropBoxManagerService( 180): Cleaning temp file: /data/system/dropbox/drop23.tmp
I/wpa_supplicant( 313): wpa_driver_nl80211_driver_cmd: Unsupported command SCAN-ACTIVE
I/wpa_supplicant( 313): wpa_driver_nl80211_driver_cmd: Unsupported command SCAN-PASSIVE
D/OpenGLRenderer( 362): Enabling debug mode 0
I/bluedroid( 180): bt_enable: ret: 0, errno: 0
I/bluedroid( 180): Starting bluetoothd deamon
E/BluetoothEventLoop.cpp( 180): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
D/dalvikvm( 362): GC_CONCURRENT freed 281K, 5% free 7130K/7495K, paused 2ms+3ms
D/dalvikvm( 390): GC_CONCURRENT freed 185K, 5% free 6799K/7111K, paused 2ms+2ms
I/ActivityManager( 180): Displayed com.android.launcher/com.android.launcher2.Launcher: +2s403ms
D/LocalBluetoothProfileManager( 451): LocalBluetoothProfileManager construction complete
V/SipBroadcastReceiver( 331): start auto registration
E/BluetoothEventLoop.cpp( 180): get_adapter_path: D-Bus error: org.bluez.Error.NoSuchAdapter (No such adapter)
E/BluetoothEventLoop.cpp( 180): failure setting up Event Loop!
D/dalvikvm( 362): GC_FOR_ALLOC freed 28K, 5% free 7316K/7687K, paused 23ms
D/dalvikvm( 362): GC_FOR_ALLOC freed 5K, 6% free 7462K/7879K, paused 21ms
D/dalvikvm( 250): GC_FOR_ALLOC freed 55K, 2% free 7624K/7751K, paused 21ms
I/dalvikvm-heap( 250): Grow heap (frag case) to 16.885MB for 9830416-byte allocation
D/dalvikvm( 250): GC_CONCURRENT freed 9K, 2% free 17214K/17415K, paused 2ms+2ms
V/OtaStartupReceiver( 331): onReceive: intent action=android.intent.action.BOOT_COMPLETED mOtaspMode=-1
D/OtaStartupReceiver( 331): OTASP not supported, nothing to do.
D/PowerManagerService( 180): bootCompleted
V/DevicePolicyManagerService( 180): Sending password expiration notifications for action android.intent.action.BOOT_COMPLETED
W/MountService( 180): Duplicate state transition (mounted -> mounted) for /mnt/sdcard
D/MountService( 180): sendStorageIntent Intent { act=android.intent.action.MEDIA_MOUNTED dat=file:///mnt/sdcard (has extras) }
I/ActivityManager( 180): Start proc com.android.contacts for broadcast com.android.contacts/.calllog.CallLogReceiver: pid=472 uid=10008 gids={3003, 1015}
V/WiredAccessoryObserver( 180): init()
I/AudioPlayer( 113): TimeInterpolator::seek(media_time=46438)
D/dalvikvm( 250): GC_FOR_ALLOC freed 0K, 2% free 17214K/17415K, paused 17ms
I/dalvikvm-heap( 250): Grow heap (frag case) to 26.593MB for 10188816-byte allocation
D/dalvikvm( 250): GC_CONCURRENT freed 0K, 1% free 27164K/27399K, paused 2ms+3ms
D/dalvikvm( 180): GC_CONCURRENT freed 607K, 10% free 8367K/9223K, paused 4ms+5ms
V/WiredAccessoryObserver( 180): newState = 16, headsetState = 16,mHeadsetState = 0
V/AudioService( 180): Broadcast Receiver: Got ACTION_HDMI_AUDIO_PLUG, state = 1
V/WiredAccessoryObserver( 180): Intent.ACTION_USB_HEADSET_PLUG: state: 1 name: hdmi
D/dalvikvm( 362): GC_CONCURRENT freed 72K, 4% free 7814K/8071K, paused 2ms+2ms
I/AudioPlayer( 113): TimeInterpolator::seek(media_time=116095)
I/AudioPlayer( 113): TimeInterpolator::seek(media_time=301847)
E/BluetoothService.cpp( 180): setBluetoothTetheringNative true
D/BluetoothAdapterStateMachine( 180): WarmUp process message: 101
D/BluetoothEventLoop( 180): Property Changed: UUIDs : 8
D/BluetoothEventLoop( 180): Property Changed: UUIDs : 9
D/BluetoothEventLoop( 180): Property Changed: UUIDs : 10
D/BluetoothEventLoop( 180): Property Changed: UUIDs : 11
D/BluetoothEventLoop( 180): Property Changed: Pairable : false
D/BluetoothEventLoop( 180): Property Changed: Powered : false
D/BluetoothAdapterStateMachine( 180): WarmUp process message: 54
D/BluetoothEventLoop( 180): Property Changed: UUIDs : 12
D/BluetoothAdapterStateMachine( 180): WarmUp process message: 51
D/BluetoothAdapterStateMachine( 180): HotOff process message: 101
I/AudioPlayer( 113): TimeInterpolator::seek(media_time=185752)
I/AudioPlayer( 113): TimeInterpolator state FIRST_ROLLING -> ROLLING (input: COUNTDOWN_0)
I/AudioPlayer( 113): @countdown end e=24414 (resetting to 0)
I/AudioPlayer( 113): TimeInterpolator state ROLLING -> STOPPED (input: STOP)
I/AudioPlayer( 113): TimeInterpolator::seek(media_time=371504)
I/SurfaceFlinger( 110): Boot is finished (21173 ms)
D/dalvikvm( 362): GC_CONCURRENT freed 277K, 5% free 8006K/8391K, paused 2ms+24ms
W/ProcessStats( 180): Skipping unknown process pid 511
I/RecoverySystem( 180): No recovery log file
D/AccountTypeManager( 472): Registering external account type=com.skype.contacts.sync, packageName=com.skype.raider
W/ResourceType( 472): getEntry failing because entryIndex 1377 is beyond type entryCount 189
W/ResourceType( 472): Failure getting entry for 0x7f020561 (t=1 e=1377) in package 0 (error -2147483647)
W/ResourceType( 472): getEntry failing because entryIndex 1378 is beyond type entryCount 189
W/ResourceType( 472): Failure getting entry for 0x7f020562 (t=1 e=1378) in package 0 (error -2147483647)
W/ResourceType( 472): getEntry failing because entryIndex 1379 is beyond type entryCount 189
W/ResourceType( 472): Failure getting entry for 0x7f020563 (t=1 e=1379) in package 0 (error -2147483647)
W/ResourceType( 472): getEntry failing because entryIndex 1778 is beyond type entryCount 189
W/ResourceType( 472): Failure getting entry for 0x7f0206f2 (t=1 e=1778) in package 0 (error -2147483647)
I/ActivityManager( 180): Start proc com.android.email for broadcast com.android.email/.service.EmailBroadcastReceiver: pid=519 uid=10018 gids={3003, 1015}
I/BootReceiver( 180): Copying /data/tombstones/tombstone_09 to DropBox (SYSTEM_TOMBSTONE)
I/AccountTypeManager( 472): Loaded meta-data for 2 account types, 1 accounts in 113ms(wall) 17ms(cpu)
E/DefaultVoicemailNotifier( 472): No voicemails to notify about: clear the notification.
D/dalvikvm( 180): GC_CONCURRENT freed 290K, 8% free 8513K/9223K, paused 3ms+10ms
I/ActivityThread( 519): Pub com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
I/ActivityThread( 519): Pub com.android.email.attachmentprovider: com.android.email.provider.AttachmentProvider
I/ActivityManager( 180): Start proc com.android.exchange for service com.android.exchange/.ExchangeService: pid=537 uid=10030 gids={3003, 1015}
I/ActivityManager( 180): Start proc com.android.deskclock for broadcast com.android.deskclock/.AlarmInitReceiver: pid=550 uid=10021 gids={}
I/ActivityThread( 537): Pub com.android.exchange.directory.provider: com.android.exchange.provider.ExchangeDirectoryProvider
D/BluetoothEventLoop( 180): Property Changed: Powered : true
D/BluetoothAdapterStateMachine( 180): Switching process message: 54
D/BluetoothEventLoop( 180): Property Changed: Pairable : true
I/ActivityThread( 550): Pub com.android.deskclock: com.android.deskclock.AlarmProvider
D/Eas Debug( 537): Logging:
D/dalvikvm( 180): GREF has increased to 401
D/ExchangeService( 537): !!! EAS ExchangeService, onCreate
D/BluetoothEventLoop( 180): Property Changed: Class : 5898764
D/BluetoothEventLoop( 180): Property Changed: Discoverable : false
D/BluetoothAdapterStateMachine( 180): Switching process message: 53
D/ExchangeService( 537): !!! EAS ExchangeService, onStartCommand, startingUp = false, running = false
D/BluetoothAdapterStateMachine( 180): Bluetooth state 11 -> 12
V/BluetoothEventManager( 451): Received android.bluetooth.adapter.action.STATE_CHANGED
D/LocalBluetoothProfileManager( 451): Adding local A2DP profile
D/LocalBluetoothProfileManager( 451): Adding local HEADSET profile
D/LocalBluetoothProfileManager( 451): Adding local OPP profile
V/AlarmClock( 550): AlarmInitReceiver finished
W/ActivityManager( 180): Permission Denial: receiving Intent { act=android.intent.action.BOOT_COMPLETED flg=0x10 } to com.android.musicfx requires android.permission.RECEIVE_BOOT_COMPLETED due to sender null (uid 1000)
D/ExchangeService( 537): !!! EAS ExchangeService, onStartCommand, startingUp = true, running = false
D/ExchangeService( 537): Received deviceId from Email app: android946684886391
D/ExchangeService( 537): Reconciling accounts...
I/ActivityManager( 180): Start proc com.android.providers.calendar for broadcast com.android.providers.calendar/.CalendarReceiver: pid=591 uid=10033 gids={3003, 1015}
I/ActivityThread( 591): Pub com.android.calendar: com.android.providers.calendar.CalendarProvider2
W/ActivityManager( 180): Permission Denial: receiving Intent { act=android.intent.action.BOOT_COMPLETED flg=0x10 } to com.skype.raider requires android.permission.RECEIVE_BOOT_COMPLETED due to sender null (uid 1000)
D/MediaScannerReceiver( 298): action: android.intent.action.MEDIA_MOUNTED path: /mnt/sdcard
D/dalvikvm( 180): GC_CONCURRENT freed 572K, 9% free 8441K/9223K, paused 2ms+3ms
D/DockEventReceiver( 451): finishStartingService: stopping service
I/ActivityManager( 180): Start proc com.android.bluetooth for broadcast com.android.bluetooth/.pbap.BluetoothPbapReceiver: pid=609 uid=10024 gids={3003, 3002, 3001, 1015}
I/ActivityThread( 609): Pub com.android.bluetooth.opp: com.android.bluetooth.opp.BluetoothOppProvider
D/dalvikvm( 519): GC_CONCURRENT freed 236K, 6% free 6683K/7047K, paused 3ms+2ms
I/BtOppRfcommListener( 609): Accept thread started on channel 12
I/CalendarProvider2( 591): Sending notification intent: Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar }
W/ContentResolver( 591): Failed to get type for: content://com.android.calendar (Unknown URL content://com.android.calendar)
I/ActivityManager( 180): Start proc com.android.calendar for broadcast com.android.calendar/.widget.CalendarAppWidgetService$CalendarFactory: pid=631 uid=10016 gids={3003}
I/ActivityThread( 631): Pub com.android.calendar.CalendarRecentSuggestionsProvider: com.android.calendar.CalendarRecentSuggestionsProvider
D/InputEventConsistencyVerifier( 362): KeyEvent: ACTION_UP but key was not down.
D/InputEventConsistencyVerifier( 362): in com.android.internal.policy.impl.PhoneWindow$DecorView@410b19c0
D/InputEventConsistencyVerifier( 362): 0: sent at 33525000000, KeyEvent { action=ACTION_UP, keyCode=KEYCODE_DPAD_UP, scanCode=103, metaState=0, flags=0x8, repeatCount=0, eventTime=33525, downTime=33373, deviceId=3, source=0x101 }
D/dalvikvm( 362): GREF has increased to 201
D/InputEventConsistencyVerifier( 362): in com.android.launcher2.HolographicImageView@41093220
D/InputEventConsistencyVerifier( 362): 0: sent at 33981000000, KeyEvent { action=ACTION_UP, keyCode=KEYCODE_DPAD_RIGHT, scanCode=106, metaState=0, flags=0x8, repeatCount=0, eventTime=33981, downTime=33813, deviceId=3, source=0x101 }
E/Ethernet( 180): DHCP request error:Timed out waiting for dhcpcd to start
D/dalvikvm( 362): GC_CONCURRENT freed 229K, 4% free 8258K/8583K, paused 2ms+4ms
D/dalvikvm( 362): GC_FOR_ALLOC freed 38K, 4% free 8534K/8839K, paused 20ms
D/dalvikvm( 362): GC_FOR_ALLOC freed 307K, 7% free 8452K/9031K, paused 21ms
I/dalvikvm-heap( 362): Grow heap (frag case) to 8.711MB for 411152-byte allocation
D/dalvikvm( 362): GC_FOR_ALLOC freed 2K, 7% free 8851K/9479K, paused 37ms
D/InputEventConsistencyVerifier( 362): in android.widget.FrameLayout@411033e0
D/InputEventConsistencyVerifier( 362): 0: sent at 35549000000, KeyEvent { action=ACTION_UP, keyCode=KEYCODE_DPAD_DOWN, scanCode=108, metaState=0, flags=0x8, repeatCount=0, eventTime=35549, downTime=35373, deviceId=3, source=0x101 }
D/dalvikvm( 362): GC_FOR_ALLOC freed 647K, 10% free 8730K/9607K, paused 45ms
I/dalvikvm-heap( 362): Grow heap (frag case) to 9.818MB for 1286224-byte allocation
D/dalvikvm( 362): GC_FOR_ALLOC freed 4K, 9% free 9982K/10887K, paused 46ms
D/dalvikvm( 362): GC_CONCURRENT freed 0K, 9% free 9982K/10887K, paused 2ms+2ms
D/InputEventConsistencyVerifier( 362): in com.android.launcher2.PagedViewIcon@412532d8
D/InputEventConsistencyVerifier( 362): 0: sent at 36005000000, KeyEvent { action=ACTION_UP, keyCode=KEYCODE_DPAD_DOWN, scanCode=108, metaState=0, flags=0x8, repeatCount=0, eventTime=36005, downTime=35869, deviceId=3, source=0x101 }
D/dalvikvm( 362): GC_FOR_ALLOC freed 1829K, 20% free 9051K/11207K, paused 23ms
D/InputEventConsistencyVerifier( 362): in com.android.launcher2.PagedViewIcon@41254290
D/InputEventConsistencyVerifier( 362): 0: sent at 36405000000, KeyEvent { action=ACTION_UP, keyCode=KEYCODE_DPAD_RIGHT, scanCode=106, metaState=0, flags=0x8, repeatCount=0, eventTime=36405, downTime=36285, deviceId=3, source=0x101 }
D/dalvikvm( 591): GC_CONCURRENT freed 330K, 7% free 6608K/7047K, paused 3ms+5ms
D/InputEventConsistencyVerifier( 362): in com.android.launcher2.PagedViewIcon@41255248
D/InputEventConsistencyVerifier( 362): 0: sent at 36597000000, KeyEvent { action=ACTION_UP, keyCode=KEYCODE_DPAD_RIGHT, scanCode=106, metaState=0, flags=0x8, repeatCount=0, eventTime=36597, downTime=36493, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 362): in com.android.launcher2.PagedViewIcon@41256200
D/InputEventConsistencyVerifier( 362): 0: sent at 36837000000, KeyEvent { action=ACTION_UP, keyCode=KEYCODE_DPAD_RIGHT, scanCode=106, metaState=0, flags=0x8, repeatCount=0, eventTime=36837, downTime=36709, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 362): in com.android.launcher2.PagedViewIcon@412571b8
D/InputEventConsistencyVerifier( 362): 0: sent at 37125000000, KeyEvent { action=ACTION_UP, keyCode=KEYCODE_DPAD_RIGHT, scanCode=106, metaState=0, flags=0x8, repeatCount=0, eventTime=37125, downTime=36981, deviceId=3, source=0x101 }
I/ActivityManager( 180): START {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.gallery3d/.app.Gallery} from pid 362
D/PermissionCache( 110): checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (1525 us)
I/ActivityManager( 180): Start proc com.android.gallery3d for activity com.android.gallery3d/.app.Gallery: pid=655 uid=10002 gids={3003, 1015, 1023}
D/dalvikvm( 180): GC_CONCURRENT freed 297K, 7% free 8626K/9223K, paused 3ms+4ms
D/OpenGLRenderer( 362): Flushing caches (mode 1)
D/OpenGLRenderer( 362): Flushing caches (mode 0)
I/ActivityThread( 655): Pub com.android.gallery3d.provider: com.android.gallery3d.provider.GalleryProvider
V/StateManager( 655): startState class com.android.gallery3d.app.AlbumSetPage
W/InputManagerService( 180): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@4114bd28 (uid=10015 pid=362)
D/dalvikvm( 655): GC_CONCURRENT freed 195K, 5% free 6720K/7047K, paused 5ms+4ms
V/GalleryActionBar( 655): showClusterMenu: runner=com.android.gallery3d.app.AlbumSetPage@410d4240
V/MtpDeviceSet( 655): loadDevices: [], size=0
D/Gallery.MultiSetSync( 655): onSyncDone: MTP devices #pending=2
D/Gallery.MultiSetSync( 655): request sync: MTP devices
D/Gallery.MultiSetSync( 655): onSyncDone: Local albums #pending=1
D/Gallery.MultiSetSync( 655): request sync: Local albums
D/Gallery.MultiSetSync( 655): onSyncDone: picasa #pending=0
D/Gallery.MultiSetSync( 655): request sync: picasa
D/libEGL ( 655): loaded /system/lib/egl/libGLES_android.so
D/libEGL ( 655): loaded /vendor/lib/egl/libEGL_POWERVR_SGX540_120.so
D/libEGL ( 655): loaded /vendor/lib/egl/libGLESv1_CM_POWERVR_SGX540_120.so
D/libEGL ( 655): loaded /vendor/lib/egl/libGLESv2_POWERVR_SGX540_120.so
I/Process ( 180): Sending signal. PID: 655 SIG: 3
I/dalvikvm( 655): threadid=3: reacting to signal 3
I/dalvikvm( 655): Wrote stack traces to '/data/anr/traces.txt'
D/OpenGLRenderer( 655): Enabling debug mode 0
I/GalleryEGLConfigChooser( 655): Config chosen: R5 G6 B5 A0 D24 S8 ID9 CAVEAT12344
I/ActivityManager( 180): Displayed com.android.gallery3d/.app.Gallery: +868ms
I/GLRootView( 655): onSurfaceChanged: 1280x672, gl10: com.google.android.gles_jni.GLImpl@410dd628
I/GLRootView( 655): layout content pane 1280x672
D/dalvikvm( 180): GC_EXPLICIT freed 91K, 7% free 8588K/9223K, paused 3ms+5ms
D/dalvikvm( 298): GC_CONCURRENT freed 388K, 7% free 6674K/7175K, paused 3ms+3ms
D/dalvikvm( 655): GC_CONCURRENT freed 193K, 4% free 6962K/7239K, paused 3ms+3ms
I/SampleTable( 113): There are reordered frames present.
E/MetadataRetrieverClient( 113): failed to extract an album art
E/MediaMetadataRetrieverJNI( 655): getEmbeddedPicture: Call to getEmbeddedPicture failed.
I/OMXCodec( 113): [OMX.google.h264.decoder] AVC profile = 100 (High), level = 31
I/OMXCodec( 113): [OMX.google.h264.decoder] video dimensions are 320 x 240
I/OMXCodec( 113): [OMX.google.h264.decoder] Crop rect is 320 x 240 @ (0, 0)
E/SoftAVC ( 113): Decoder failed: -2
E/OMXCodec( 113): [OMX.google.h264.decoder] ERROR(0x80001001, -1007)
V/StateManager( 655): startStateForResult class com.android.gallery3d.app.AlbumPage, 1
D/AlbumPage( 655): onSyncDone: Trailers result=0
V/StateManager( 655): startStateForResult class com.android.gallery3d.app.PhotoPage, 2
D/dalvikvm( 655): GC_CONCURRENT freed 293K, 6% free 7075K/7495K, paused 6ms+3ms
D/DOMX ( 113): hardware/ti/domx/domx/omx_rpc/src/omx_rpc.c:140 RPC_InstanceInit()
D/DOMX ( 113): ERROR: Can't open device, errorno from open = 2
D/DOMX ( 113): hardware/ti/domx/domx/omx_rpc/src/omx_rpc_stub.c:200 RPC_GetHandle()
D/DOMX ( 113): ERROR: DOMX Write failed 0xffffffff -1
D/DOMX ( 113): ERROR: failed check:status >= 0 && errno != ENXIO - returning error: 0x81009 - Write failed due ducati in faulty state
D/DOMX ( 113): hardware/ti/domx/domx/omx_proxy_common/src/omx_proxy_common.c:2230 OMX_ProxyCommonInit()
D/DOMX ( 113): ERROR: RPC function returned error 0x81009
D/DOMX ( 113): ERROR: failed check:(eError == OMX_ErrorNone) - returning error: 0x80001009 - Error returned from OMX API in ducati
D/DOMX ( 113): hardware/ti/domx/domx/omx_rpc/src/omx_rpc.c:261 RPC_InstanceDeInit()
D/DOMX ( 113): ERROR: Close failed on omx fd
D/DOMX ( 113): hardware/ti/domx/omx_proxy_component/omx_video_dec/src/omx_proxy_videodec.c:227 OMX_ProxyViddecInit()
D/DOMX ( 113): ERROR: failed check:eError == OMX_ErrorNone - returning error: 0x80001009 - Proxy common init returned error
I/OMXCodec( 113): [OMX.google.h264.decoder] AVC profile = 100 (High), level = 40
E/MetadataRetrieverClient( 113): failed to capture a video frame
E/MediaMetadataRetrieverJNI( 655): getFrameAtTime: videoFrame is a NULL pointer
D/InputEventConsistencyVerifier( 655): KeyEvent: ACTION_DOWN but key is already down and this event is not a key repeat.
D/InputEventConsistencyVerifier( 655): in Handler (android.view.ViewRootImpl) {410b0bb0}
D/InputEventConsistencyVerifier( 655): 0: sent at 77484000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77484, downTime=77484, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): -- recent events --
D/InputEventConsistencyVerifier( 655): 1: sent at 77238000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77238, downTime=77238, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77238000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77238, downTime=77238, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 40694610000, MotionEvent { action=ACTION_HOVER_MOVE, id[0]=0, x[0]=730.87744, y[0]=259.36847, toolType[0]=TOOL_TYPE_MOUSE, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerC}
D/InputEventConsistencyVerifier( 655): 4: sent at 40694610000, MotionEvent { action=ACTION_HOVER_ENTER, id[0]=0, x[0]=730.87744, y[0]=259.36847, toolType[0]=TOOL_TYPE_MOUSE, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointer}
D/InputEventConsistencyVerifier( 655): 5: sent at 40694610000, MotionEvent { action=ACTION_UP, id[0]=0, x[0]=730.87744, y[0]=259.36847, toolType[0]=TOOL_TYPE_MOUSE, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, }
D/InputEventConsistencyVerifier( 655): 0: sent at 77484000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77484, downTime=77484, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77484000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77484, downTime=77484, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77238000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77238, downTime=77238, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77238000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77238, downTime=77238, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 40694610000, MotionEvent { action=ACTION_HOVER_MOVE, id[0]=0, x[0]=730.87744, y[0]=259.36847, toolType[0]=TOOL_TYPE_MOUSE, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerC}
D/InputEventConsistencyVerifier( 655): 5: sent at 40694610000, MotionEvent { action=ACTION_HOVER_ENTER, id[0]=0, x[0]=730.87744, y[0]=259.36847, toolType[0]=TOOL_TYPE_MOUSE, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointer}
D/InputEventConsistencyVerifier( 655): 0: sent at 77523000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77523, downTime=77523, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77484000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77484, downTime=77484, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77484000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77484, downTime=77484, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77238000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77238, downTime=77238, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77238000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77238, downTime=77238, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 40694610000, MotionEvent { action=ACTION_HOVER_MOVE, id[0]=0, x[0]=730.87744, y[0]=259.36847, toolType[0]=TOOL_TYPE_MOUSE, buttonState=0, metaState=0, flags=0x0, edgeFlags=0x0, pointerC}
D/InputEventConsistencyVerifier( 655): 0: sent at 77523000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77523, downTime=77523, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77523000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77523, downTime=77523, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77484000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77484, downTime=77484, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77484000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77484, downTime=77484, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77238000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77238, downTime=77238, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77238000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77238, downTime=77238, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 0: sent at 77562000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77562, downTime=77562, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77523000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77523, downTime=77523, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77523000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77523, downTime=77523, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77484000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77484, downTime=77484, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77484000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77484, downTime=77484, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77238000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77238, downTime=77238, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 0: sent at 77562000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77562, downTime=77562, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77562000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77562, downTime=77562, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77523000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77523, downTime=77523, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77523000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77523, downTime=77523, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77484000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77484, downTime=77484, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77484000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77484, downTime=77484, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 0: sent at 77601000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77601, downTime=77601, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77562000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77562, downTime=77562, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77562000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77562, downTime=77562, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77523000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77523, downTime=77523, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77523000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77523, downTime=77523, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77484000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77484, downTime=77484, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 0: sent at 77601000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77601, downTime=77601, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77601000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77601, downTime=77601, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77562000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77562, downTime=77562, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77562000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77562, downTime=77562, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77523000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77523, downTime=77523, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77523000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77523, downTime=77523, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 0: sent at 77640000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77640, downTime=77640, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77601000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77601, downTime=77601, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77601000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77601, downTime=77601, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77562000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77562, downTime=77562, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77562000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77562, downTime=77562, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77523000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77523, downTime=77523, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 0: sent at 77640000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77640, downTime=77640, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77640000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77640, downTime=77640, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77601000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77601, downTime=77601, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77601000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77601, downTime=77601, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77562000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77562, downTime=77562, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77562000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77562, downTime=77562, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 0: sent at 77679000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77679, downTime=77679, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77640000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77640, downTime=77640, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77640000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77640, downTime=77640, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77601000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77601, downTime=77601, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77601000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77601, downTime=77601, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77562000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77562, downTime=77562, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 0: sent at 77679000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77679, downTime=77679, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77679000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77679, downTime=77679, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77640000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77640, downTime=77640, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77640000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77640, downTime=77640, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77601000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77601, downTime=77601, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77601000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77601, downTime=77601, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 0: sent at 77718000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77718, downTime=77718, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77679000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77679, downTime=77679, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77679000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77679, downTime=77679, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77640000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77640, downTime=77640, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77640000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77640, downTime=77640, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77601000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77601, downTime=77601, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 0: sent at 77718000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77718, downTime=77718, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77718000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77718, downTime=77718, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77679000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77679, downTime=77679, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77679000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77679, downTime=77679, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77640000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77640, downTime=77640, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77640000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77640, downTime=77640, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 0: sent at 77757000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77757, downTime=77757, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77718000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77718, downTime=77718, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77718000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77718, downTime=77718, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77679000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77679, downTime=77679, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77679000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77679, downTime=77679, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77640000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77640, downTime=77640, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 0: sent at 77757000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77757, downTime=77757, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77757000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77757, downTime=77757, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77718000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77718, downTime=77718, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77718000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77718, downTime=77718, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77679000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77679, downTime=77679, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77679000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77679, downTime=77679, deviceId=3, source=0x101 }
I/ActivityManager( 180): START {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.android.launcher/com.android.launcher2.Launcher} from pid 180
D/InputEventConsistencyVerifier( 655): 0: sent at 77797000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77797, downTime=77797, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77757000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77757, downTime=77757, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77757000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77757, downTime=77757, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77718000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77718, downTime=77718, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77718000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77718, downTime=77718, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77679000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77679, downTime=77679, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 0: sent at 77797000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77797, downTime=77797, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77797000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77797, downTime=77797, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77757000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77757, downTime=77757, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77757000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77757, downTime=77757, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77718000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77718, downTime=77718, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77718000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77718, downTime=77718, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 0: sent at 77835000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77835, downTime=77835, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77797000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77797, downTime=77797, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77797000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77797, downTime=77797, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77757000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77757, downTime=77757, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77757000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77757, downTime=77757, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77718000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77718, downTime=77718, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 0: sent at 77835000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x8, repeatCount=0, eventTime=77835, downTime=77835, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 1: sent at 77835000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77835, downTime=77835, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 2: sent at 77797000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77797, downTime=77797, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 3: sent at 77797000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77797, downTime=77797, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 4: sent at 77757000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_BACK, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77757, downTime=77757, deviceId=3, source=0x101 }
D/InputEventConsistencyVerifier( 655): 5: sent at 77757000000, KeyEvent { action=ACTION_DOWN, keyCode=KEYCODE_ESCAPE, scanCode=1, metaState=0, flags=0x80000008, repeatCount=0, eventTime=77757, downTime=77757, deviceId=3, source=0x101 }
D/OpenGLRenderer( 655): Flushing caches (mode 1)
D/OpenGLRenderer( 655): Flushing caches (mode 0)
V/StateManager( 655): saveState
V/StateManager( 655): saveState class com.android.gallery3d.app.AlbumSetPage
V/StateManager( 655): saveState class com.android.gallery3d.app.AlbumPage
V/StateManager( 655): saveState class com.android.gallery3d.app.PhotoPage
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2#
bash-3.2# cd /sys/kernel/
debug/ ipv4/ notes uevent_helper
fscaps mm/ slab/ uevent_seqnum
bash-3.2# cd /sys/kernel/debug/
abe_port/ extfrag/ omap4-abe/ sched_features
asoc/ gpio omap_mux/ smartreflex/
bdi/ hid/ omapdss/ ti-st/
binder/ ieee80211/ pm_debug/ tiler/
bluetooth/ ion/ prcm tput
caif_sk/ memblock/ prcm-on usb/
clock/ mmc0/ regulator/ voltage/
dsscomp/ mmc1/ remoteproc/ vram
dvfs/ musb/ rpmsg_resmgr/ wakeup_sources
bash-3.2# cd /sys/kernel/debug/remoteproc/omap-rproc.
omap-rproc.0/ omap-rproc.1/
bash-3.2# find
./omap-rproc.1
./omap-rproc.1/core
./omap-rproc.1/cdump1
./omap-rproc.1/cdump0
./omap-rproc.1/trace1_last
./omap-rproc.1/trace0_last
./omap-rproc.1/version
./omap-rproc.1/name
./omap-rproc.0
./omap-rproc.0/name
bash-3.2# cat omap-rproc.1/*
[ 166.821044] Unable to handle kernel paging request at virtual address b3380aaa
[ 166.829528] pgd = c5818000
[ 166.832672] [b3380aaa] *pgd=00000000
[ 166.837005] Internal error: Oops: 5 [#1] PREEMPT SMP
[ 166.842559] Modules linked in: wl12xx_sdio wl12xx mac80211 cfg80211 omaplfb_sgx540_120 pvrsrvkm_sgx540_120 compat
[ 166.855743] CPU: 1 Not tainted (3.0.21-00003-OMAP-Android+ #45)
[ 166.862762] PC is at rproc_format_trace_buf+0x70/0x1ac
[ 166.868713] LR is at cdump0_rproc_read+0x30/0x38
[ 166.873901] pc : [<c0431ca0>] lr : [<c0431e44>] psr: 00000113
[ 166.873901] sp : c5801ef8 ip : c5801f28 fp : c5801f24
[ 166.886871] r10: c0a90ddc r9 : 00000000 r8 : eaaaaaaa
[ 166.892883] r7 : bef149b8 r6 : 00001000 r5 : c5801f70 r4 : c88d6000
[ 166.900146] r3 : 000001f8 r2 : 00000000 r1 : ffffffff r0 : eaaaaaaa
[ 166.907562] Flags: nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 166.915649] Control: 10c5387d Table: 8581804a DAC: 00000015
[ 166.922058]
[ 166.922058] PC: 0xc0431c20:
[ 166.927062] 1c20 e1a00007 ebf46e16 e24bd01c e89da8f0 e1a0c00d e92dddf0 e24cb004 e24dd008
[ 166.938201] 1c40 e2534000 e1a07000 e1a06001 e1a05002 e1c200d0 03e00004 e59b3004 1a000001
[ 166.949310] 1c60 e24bd024 e89dadf0 e3530007 93e00015 9afffffa e300addc e34ca0a9 e2433008
[ 166.960418] 1c80 e59a2004 e7948003 e3520000 1a000017 e1902001 0a000043 e1530008 da00000e
[ 166.971343] 1ca0 e7d41008 e0842008 e3510000 0a00000a e1e0c008 e08c0003 e3100001 e1a0c008
[ 166.982482] 1cc0 0a000021 e5f20001 e288c001 e3500000 1a00001d e15c0008 ca000036 e3a03001
[ 166.993621] 1ce0 e3a02000 e58a3004 e3a03000 e1c520f0 e3580000 da00000b e5d42000 e3520000
[ 167.004547] 1d00 0a000008 e3180001 e3a0c000 1a000019 e3a0c001 e7d4100c e3510000 1a000015
[ 167.015472]
[ 167.015502] LR: 0xc0431dc4:
[ 167.020690] 1dc4 e1a03004 e58dc000 ebf46dac e3500000 1affffa1 eaffffbf e1a0c00d e92dd800
[ 167.031616] 1de4 e24cb004 e24dd008 e590e098 e1a00001 e1a01002 e1a02003 e59ec26c e59e3264
[ 167.042724] 1e04 e58dc000 ebffff88 e24bd00c e89da800 e1a0c00d e92dd800 e24cb004 e24dd008
[ 167.053833] 1e24 e590e098 e1a00001 e1a01002 e1a02003 e59ec268 e59e3260 e58dc000 ebffff7a
[ 167.064788] 1e44 e24bd00c e89da800 e1a0c00d e92dd800 e24cb004 e24dd008 e590e098 e1a00001
[ 167.075714] 1e64 e1a01002 e1a02003 e59ec25c e59e324c e58dc000 ebffff6c e24bd00c e89da800
[ 167.086822] 1e84 e1a0c00d e92dd800 e24cb004 e24dd008 e590e098 e1a00001 e1a01002 e1a02003
[ 167.097961] 1ea4 e59ec254 e59e3244 e58dc000 ebffff5e e24bd00c e89da800 e1a0c00d e92dd800
[ 167.108886]
[ 167.108886] SP: 0xc5801e78:
[ 167.114074] 1e78 c5801e9c c5801e88 c0618b0c c0267964 c7339560 c7339548 ffffffff c5801ee4
[ 167.125030] 1e98 00001000 bef149b8 c5801f24 c5801eb0 c005496c c004e528 eaaaaaaa ffffffff
[ 167.135955] 1eb8 00000000 000001f8 c88d6000 c5801f70 00001000 bef149b8 eaaaaaaa 00000000
[ 167.147064] 1ed8 c0a90ddc c5801f24 c5801f28 c5801ef8 c0431e44 c0431ca0 00000113 ffffffff
[ 167.158203] 1ef8 c5801fac c5801f08 c646b600 00001000 bef149b8 c5801f70 00000000 00000000
[ 167.169128] 1f18 c5801f3c c5801f28 c0431e44 c0431c3c 00000200 00000000 c5801f6c c5801f40
[ 167.180236] 1f38 c012b500 c0431e20 c5800000 c646b608 c5801f94 c646b600 bef149b8 00001000
[ 167.191192] 1f58 00000003 00000000 c5801fa4 c5801f70 c012b660 c012b458 eaaaaaaa ffffffff
[ 167.202301]
[ 167.202331] IP: 0xc5801ea8:
[ 167.207336] 1ea8 c005496c c004e528 eaaaaaaa ffffffff 00000000 000001f8 c88d6000 c5801f70
[ 167.218444] 1ec8 00001000 bef149b8 eaaaaaaa 00000000 c0a90ddc c5801f24 c5801f28 c5801ef8
[ 167.229370] 1ee8 c0431e44 c0431ca0 00000113 ffffffff c5801fac c5801f08 c646b600 00001000
[ 167.240478] 1f08 bef149b8 c5801f70 00000000 00000000 c5801f3c c5801f28 c0431e44 c0431c3c
[ 167.251434] 1f28 00000200 00000000 c5801f6c c5801f40 c012b500 c0431e20 c5800000 c646b608
[ 167.262542] 1f48 c5801f94 c646b600 bef149b8 00001000 00000003 00000000 c5801fa4 c5801f70
[ 167.273468] 1f68 c012b660 c012b458 eaaaaaaa ffffffff bef15c8a 00000000 c00550a8 00001000
[ 167.284545] 1f88 00000004 bef149b8 c00550a8 c5800000 00000000 c5801fa8 c0054f00 c012b628
[ 167.295654]
[ 167.295684] FP: 0xc5801ea4:
[ 167.300689] 1ea4 c5801eb0 c005496c c004e528 eaaaaaaa ffffffff 00000000 000001f8 c88d6000
[ 167.311645] 1ec4 c5801f70 00001000 bef149b8 eaaaaaaa 00000000 c0a90ddc c5801f24 c5801f28
[ 167.322753] 1ee4 c5801ef8 c0431e44 c0431ca0 00000113 ffffffff c5801fac c5801f08 c646b600
[ 167.333679] 1f04 00001000 bef149b8 c5801f70 00000000 00000000 c5801f3c c5801f28 c0431e44
[ 167.344787] 1f24 c0431c3c 00000200 00000000 c5801f6c c5801f40 c012b500 c0431e20 c5800000
[ 167.355926] 1f44 c646b608 c5801f94 c646b600 bef149b8 00001000 00000003 00000000 c5801fa4
[ 167.366851] 1f64 c5801f70 c012b660 c012b458 eaaaaaaa ffffffff bef15c8a 00000000 c00550a8
[ 167.377960] 1f84 00001000 00000004 bef149b8 c00550a8 c5800000 00000000 c5801fa8 c0054f00
[ 167.389068]
[ 167.389068] R0: 0xeaaaaa2a:
[ 167.394073] aa28 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.405181] aa48 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.416259] aa68 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.427215] aa88 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.438293] aaa8 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.449401] aac8 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.460510] aae8 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.471466] ab08 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.482574] ab28 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.493682]
[ 167.493713] R4: 0xc88d5f80:
[ 167.498718] 5f80 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.509826] 5fa0 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.520935] 5fc0 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.531890] 5fe0 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.543029] 6000 aaaaaaaa a2aaaaaa aaaaaaaa aaaaaaa6 aaaaaaaa aaa2baa3 aaaaa2aa aaaaaaaa
[ 167.554138] 6020 aaaa8aba aaa2aaaa baaaaaaa e9abaaaa eaa4aaaa aaaaaaa8 eeaaaaa3 aaaaaaa8
[ 167.565063] 6040 aaaaaaba aababeba aaaaaaaa 8aaaaae8 aa8aaafa 0aaaaabe aaeafaaa aaaaeaaa
[ 167.575988] 6060 aaaa6aaa eaaaeea8 aaa2aaae aaaaaaa8 eaabaaa2 aaaaaaaa aaaaabaa aaaaacba
[ 167.587097]
[ 167.587097] R5: 0xc5801ef0:
[ 167.592132] 1ef0 00000113 ffffffff c5801fac c5801f08 c646b600 00001000 bef149b8 c5801f70
[ 167.603240] 1f10 00000000 00000000 c5801f3c c5801f28 c0431e44 c0431c3c 00000200 00000000
[ 167.614318] 1f30 c5801f6c c5801f40 c012b500 c0431e20 c5800000 c646b608 c5801f94 c646b600
[ 167.625274] 1f50 bef149b8 00001000 00000003 00000000 c5801fa4 c5801f70 c012b660 c012b458
[ 167.636230] 1f70 eaaaaaaa ffffffff bef15c8a 00000000 c00550a8 00001000 00000004 bef149b8
[ 167.647338] 1f90 c00550a8 c5800000 00000000 c5801fa8 c0054f00 c012b628 00001000 00000004
[ 167.658447] 1fb0 00000004 bef149b8 00001000 00183024 00001000 00000004 bef149b8 00000003
[ 167.669403] 1fd0 00000000 00000000 00000004 00000001 019b34c0 bef149a0 0001ef48 00008e6c
[ 167.680511]
[ 167.680511] R8: 0xeaaaaa2a:
[ 167.685699] aa28 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.696624] aa48 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.707763] aa68 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.718872] aa88 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.729797] aaa8 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.740905] aac8 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.752044] aae8 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.763153] ab08 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.774108] ab28 ******** ******** ******** ******** ******** ******** ******** ********
[ 167.785217]
[ 167.785217] R10: 0xc0a90d5c:
[ 167.790313] 0d5c c0a90d58 c042e8d8 00000300 c0a90d68 c0a90d68 c042e960 00000000 00000000
[ 167.801452] 0d7c 00000000 c096da00 00000000 00000000 ffffffff 00000300 c0a90d94 c0a90d94
[ 167.812561] 0d9c c042e8a4 00000300 c0a90da4 c0a90da4 c042e994 00000000 00000000 00000000
[ 167.823669] 0dbc c096da00 00000000 00000000 ffffffff c7bc2200 c7bc5aa0 0f600000 c7a35dc0
[ 167.834625] 0ddc c7406630 00000000 c7423ea0 c78ce7c0 00000000 00000000 c703bd80 c703bea0
[ 167.845703] 0dfc c703bfc0 c71a30e0 c71a3200 c71a3320 c71a3440 c71a3560 c71a3680 c71a37a0
[ 167.856842] 0e1c c71a38c0 c71a39e0 c71a3b00 c71a3c20 c71a3d40 c71a3e60 c71a3f80 c71a6280
[ 167.867767] 0e3c c71a63a0 c71a64c0 c71a65e0 c71a6700 c71a6820 c71a6940 c71a6a60 c71a6b80
[ 167.878723] Process cat (pid: 699, stack limit = 0xc58002f8)
[ 167.885223] Stack: (0xc5801ef8 to 0xc5802000)
[ 167.890136] 1ee0: c5801fac c5801f08
[ 167.899353] 1f00: c646b600 00001000 bef149b8 c5801f70 00000000 00000000 c5801f3c c5801f28
[ 167.908569] 1f20: c0431e44 c0431c3c 00000200 00000000 c5801f6c c5801f40 c012b500 c0431e20
[ 167.917602] 1f40: c5800000 c646b608 c5801f94 c646b600 bef149b8 00001000 00000003 00000000
[ 167.926818] 1f60: c5801fa4 c5801f70 c012b660 c012b458 eaaaaaaa ffffffff bef15c8a 00000000
[ 167.936035] 1f80: c00550a8 00001000 00000004 bef149b8 c00550a8 c5800000 00000000 c5801fa8
[ 167.945251] 1fa0: c0054f00 c012b628 00001000 00000004 00000004 bef149b8 00001000 00183024
[ 167.954315] 1fc0: 00001000 00000004 bef149b8 00000003 00000000 00000000 00000004 00000001
[ 167.963531] 1fe0: 019b34c0 bef149a0 0001ef48 00008e6c 60000110 00000004 9aa28000 9aa29000
[ 167.972717] Backtrace:
[ 167.975830] [<c0431c30>] (rproc_format_trace_buf+0x0/0x1ac) from [<c0431e44>] (cdump0_rproc_read+0x30/0x38)
[ 167.986755] [<c0431e14>] (cdump0_rproc_read+0x0/0x38) from [<c012b500>] (vfs_read+0xb4/0x138)
[ 167.996337] [<c012b44c>] (vfs_read+0x0/0x138) from [<c012b660>] (sys_read+0x44/0x74)
[ 168.004882] r8:00000000 r7:00000003 r6:00001000 r5:bef149b8 r4:c646b600
[ 168.013610] [<c012b61c>] (sys_read+0x0/0x74) from [<c0054f00>] (ret_fast_syscall+0x0/0x30)
[ 168.022888] r9:c5800000 r8:c00550a8 r6:bef149b8 r5:00000004 r4:00001000
[ 168.031433] Code: e1902001 0a000043 e1530008 da00000e (e7d41008)
[ 168.039733] ---[ end trace 15d46b12c9a0668e ]---
[ 168.045104] Kernel panic - not syncing: Fatal exception
[ 168.050750] Backtrace:
[ 168.053466] [<c0059224>] (dump_backtrace+0x0/0x110) from [<c0615254>] (dump_stack+0x18/0x1c)
[ 168.062469] r6:c5800028 r5:00000000 r4:c086cf28 r3:c5800000
[ 168.068817] [<c061523c>] (dump_stack+0x0/0x1c) from [<c06152e8>] (panic+0x90/0x1bc)
[ 168.076995] [<c0615258>] (panic+0x0/0x1bc) from [<c005978c>] (die+0x1c4/0x1d4)
[ 168.084686] r3:00000000 r2:c086cf38 r1:c5800000 r0:c07414b0
[ 168.091064] r7:00000005
[ 168.093872] [<c00595c8>] (die+0x0/0x1d4) from [<c005d9cc>] (__do_kernel_fault+0x7c/0x8c)
[ 168.102508] r8:c7339500 r7:00000005 r6:00000000 r5:b3380aaa r4:c5801eb0
[ 168.110015] [<c005d950>] (__do_kernel_fault+0x0/0x8c) from [<c005db1c>] (do_page_fault+0x140/0x1f4)
[ 168.119659] r8:c5801eb0 r7:00000005 r6:00010000 r5:b3380aaa r4:c7339500
[ 168.126892] r3:c5801eb0
[ 168.129882] [<c005d9dc>] (do_page_fault+0x0/0x1f4) from [<c005dce8>] (do_translation_fault+0xa4/0xa8)
[ 168.139739] [<c005dc44>] (do_translation_fault+0x0/0xa8) from [<c004e558>] (do_DataAbort+0x3c/0xa4)
[ 168.149383] r7:c5801eb0 r6:b3380aaa r5:c08027c8 r4:00000005
[ 168.155700] [<c004e51c>] (do_DataAbort+0x0/0xa4) from [<c005496c>] (__dabt_svc+0x4c/0x60)
[ 168.164428] Exception stack(0xc5801eb0 to 0xc5801ef8)
[ 168.169830] 1ea0: eaaaaaaa ffffffff 00000000 000001f8
[ 168.178588] 1ec0: c88d6000 c5801f70 00001000 bef149b8 eaaaaaaa 00000000 c0a90ddc c5801f24
[ 168.187316] 1ee0: c5801f28 c5801ef8 c0431e44 c0431ca0 00000113 ffffffff
[ 168.194335] r7:bef149b8 r6:00001000 r5:c5801ee4 r4:ffffffff
[ 168.200744] [<c0431c30>] (rproc_format_trace_buf+0x0/0x1ac) from [<c0431e44>] (cdump0_rproc_read+0x30/0x38)
[ 168.211151] [<c0431e14>] (cdump0_rproc_read+0x0/0x38) from [<c012b500>] (vfs_read+0xb4/0x138)
[ 168.220214] [<c012b44c>] (vfs_read+0x0/0x138) from [<c012b660>] (sys_read+0x44/0x74)
[ 168.228485] r8:00000000 r7:00000003 r6:00001000 r5:bef149b8 r4:c646b600
[ 168.236053] [<c012b61c>] (sys_read+0x0/0x74) from [<c0054f00>] (ret_fast_syscall+0x0/0x30)
[ 168.244842] r9:c5800000 r8:c00550a8 r6:bef149b8 r5:00000004 r4:00001000
[ 168.252410] CPU0: stopping
[ 168.255310] Backtrace:
[ 168.258087] [<c0059224>] (dump_backtrace+0x0/0x110) from [<c0615254>] (dump_stack+0x18/0x1c)
[ 168.267028] r6:c07e8000 r5:c004ceb0 r4:c07fa280 r3:c07e8000
[ 168.273406] [<c061523c>] (dump_stack+0x0/0x1c) from [<c004e3dc>] (do_IPI+0x180/0x198)
[ 168.281707] [<c004e25c>] (do_IPI+0x0/0x198) from [<c00549c8>] (__irq_svc+0x48/0xe0)
[ 168.289886] Exception stack(0xc07e9ee8 to 0xc07e9f30)
[ 168.295318] 9ee0: c07e9f30 00000000 2c1bcc9b 00000027 c12a7100 c07e9f30
[ 168.303985] 9f00: 2c048424 00000027 2c1bcc9b 00000027 00000000 c07e9f64 4a22069b c07e9f30
[ 168.312713] 9f20: 00000000 c0071b60 20000113 ffffffff
[ 168.318084] [<c0071b20>] (omap4_enter_idle_wfi+0x0/0x108) from [<c03f1c80>] (cpuidle_idle_call+0xb0/0x128)
[ 168.328369] r9:c0071b20 r8:8000406a r7:c08022e4 r6:c12a7110 r5:c0990044
[ 168.335662] r4:c12a7100
[ 168.338623] [<c03f1bd0>] (cpuidle_idle_call+0x0/0x128) from [<c00567ec>] (cpu_idle+0xd0/0x104)
[ 168.347808] r9:411fc093 r8:8000406a r6:c062081c r5:c086a164 r4:c07e8000
[ 168.355010] r3:00000000
[ 168.358001] [<c005671c>] (cpu_idle+0x0/0x104) from [<c06056b0>] (rest_init+0xa0/0xa4)
[ 168.366302] r7:00000000 r6:c0040b3c r5:00000002 r4:c07e8000
[ 168.372680] [<c0605610>] (rest_init+0x0/0xa4) from [<c00089cc>] (start_kernel+0x2f8/0x304)
[ 168.381500] r5:c086a0a0 r4:c07fa400
[ 168.385498] [<c00086d4>] (start_kernel+0x0/0x304) from [<8000803c>] (0x8000803c)
[ 168.393402] Rebooting in 5 seconds..
  • Hello Gregoire,
    The 4AI Android releases come with pre-build Ducati binaries. Can you make sure that you are using the latest Ducati binaries from this releases? The latest release notes are here: http://omappedia.com/wiki/4AI.1.6_OMAP4_Icecream_Sandwich_Release_Notes
    Pre-build binaries for Blaze and Blaze tablet are posted here: http://omappedia.com/wiki/Android:_Working_with_pre-built_binaries
    The errors you are getting point come from IPC (RPMsg), and may come from mismatched components, or some other integration issue on your platform.
    Magdalena
    Thanks for the reply. I appreciate that. es, I'm sure, and I have tried like 1000 times... But it's always possible that I have done a mistake. That being said, take a look at:
    http://omapzoom.org/?p=device/ti/proprietary-open.git;a=history;f=omap4/ducati_blaze_tablet.tgz;h=689083e76e520ac2bd0ac1b57100f67436c85e8d;hb=ics-mr1-release
    The blaze tablet Ducati binaries haven't changed from 1.0 to 1.6. I have 5756300 bytes with md5sum: f471440df85fb7b1a9360de321322c04 system/vendor/firmware/ducati-m3.bin Please let me know if you see a more recent Ducati file.
    I have managed to remove the kernel error message above by "un-applying" five patches that have been committed between the kernel corresponding to 4AI.1.0 to 4AI.1.5 around the file arch/arm/mach-omap2/remoteproc.c. But it's still not working and I still get the error in frameworks.
    Also, I have managed to have kernel-4AI.1.5 on my 4AI.1.0 build and Ducati is not working. I do continue to believe that it's a problem in kernel (or perhaps in x-loader). Also 1.5 or 1.6 seems to be the same for Ducati and another third party has reported to me a similar problem with 1.6.. So it's not a problem of "you haven't upgraded to the latest".
    I'm wondering if 4AI.1.6 has really been tested on OMAP4430? How can I provide more information about what's going on around Ducati? I really need to find a fix...
    Grégoire
  • Grégoire,
    Do you have a Blaze or a Blaze tablet handy? If so, could you please try the pre-built binaries (link in my previous post), for reference? As you can see, there are binaries available for 4430 as well so yes, we do sanity testing on all OMAP4 devices.
    I will need to check the exact versions of Ducati, but I'm pretty sure that Ducati has changed from 4AI.1.0 to 4AI.1.6. From your description of hte problem I believe that the root cause is still mixing and matching versions of various components.
    Magdalena
    No, I don't have a blaze tablet handy. Yes, I saw and read carefully the other post mentioned at the top of mine.
    I know that blaze Ducati is different from blaze_tablet Ducati. But I didn't seen any difference for Ducati between 1.0 and 1.5 in blaze-tablet. I would be so delighted to be proved that I'm wrong!!! Take a look at the manifest of 1.0 and 1.5 (or 1.6), it leads to the same blaze-tablet Ducati from proprietary-open.git. If you have the binaries of 4.AI.1.6 blaze-tablet, please provide the md5sum of ducati-m3.bin so we can compare to what is on git. Perhaps it has not been updated on the repository.
    Grégoire
  • Gregoire:
         If you want a working version of ducati binary please download it form:
        As Magdalena already mentioned. For ducati binary at omapzoom is not working and has not been updated.
    Rodrigo
  • The good news is that it's working now with those binaries :-) Many thanks.
    The bad news is that TI is killing us . :-( We have spent a *lot* of time on this... Perhaps you should put a note in the git repository proprietary-open...
    Grégoire
  • Gregoire:
          If you look for this string at release notes "Appropriate Ducati binary can be found on Android: Working with pre-built binaries page"
    http://omappedia.com/wiki/4AI.1.5_OMAP4_Icecream_Sandwich_Release_Notes
    http://omappedia.com/wiki/4AI.1.4-P1_OMAP4_Icecream_Sandwich_Release_Notes
        I will modify those to make it more visible.
    Rodrigo
