• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Chargers Forum » Methods of circuit failure in BQ24450 circuit
Share
Battery Management
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
liam liam
Posted by liam liam
on Sep 21 2011 11:36 AM
Prodigy20 points
Hi there
I am using the BQ 24450 to charge a 6V lead acid battery from either a 10.8V OC, 5W solar panel or a 15V power supply. The battery will be connected 24 / 7. My calculations for the circuit at as follows.
Vfloat 6.731466 Volts
Vboost 7.079974 Volts
Vthreshold 5.143104 Volts
When connected to the power supply, the I limit jumper will take the current limit 2.2R path (low charge current). When connected from the solar panel, it will take the 0.33R current limit path.
The three MOSFETs are all P type FDD4243 from fairchild, with plenty of heatsinking for each. http://www.fairchildsemi.com/ds/FD/FDD4243.pdf
My question: what possible failure modes can you think of in the circuit below? (even if unlikely). Your input would be greatly appreciated.....
BQ24450
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Charles Mauney
    Posted by Charles Mauney
    on Sep 21 2011 13:44 PM
    Mastermind25835 points
    If the design is done properly (components are rated correctly and good theral management), then I do not think there will be a problem.
    1) I would check the temperature of the components in the worst case operating conditions.
    2) Sometimes circuits have trouble operating well at their boundires so I would see how the unit works with the input voltage down around the battery voltage.
    Report Abuse
    • Reply
  • liam liam
    Posted by liam liam
    on Sep 22 2011 06:07 AM
    Prodigy20 points
    Thank you for your reply.
    the MOSFET's are rated to 150 degrees celsius.
    Absolute worst case scenarios:
    From a power supply:
    - Input voltage: 15V, it's a regulated switch mode +/- 1% on the spec but lets say 5% so 15.75V
    - Current limit position will be using the 2.2R  current sense resistor. say it's 5% out, so 2.178R giving approx 115mA charge rate.
    - Battery is at 5.14V, the threshold.
    - Input diode (not shown on schematic) drops the current minimum of 0.3 under load
    ((15.75 - 0.3  - 5.14) = 10.31V drop worst case
    0.115 * 10.31V = 1.18565 watts of heat to dissipate - a relatively small amount.
    From a 10.8V solar panel 5 - 100000 W:
    - Input voltage: 10.8V Open circuit (lets use this figure for worst case)
    - Current limit will be using the 0.33R current sense resistor. say it's 5% out, so 0.3267R giving approx 0.765228 A charge rate ( you wouldn't get this from a 5W panel though)
    10.8V - 0.3 - 5.14 = 5.36V drop worst case
    0.765228 * 5.36 = 4.101622 W
    I don't think these numbers are that high given that the three mosfets are thermally well connected... I will calculate the temperature rise given the surface area shortly.
    In practice, with no airflow and 10.8V coming in I can't get it hotter than 70 degrees celsius at the hottest point. The BQ24450 has quite a lot of thermal isolation from this (is usually no more than 40 degrees celsius). That gives a lot of headroom for enclosure + ambient temperature.
    Regarding the second point: I have tested the circuit running across the whole voltage range and it appears to perform admirably.
    Report Abuse
    • Reply
  • Charles Mauney
    on Sep 22 2011 07:36 AM
    Looks like you did a good job.  Nothing beats good looking waveforms and components that do not get too hot.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
