AM335x MII interface with Lan8710i issue
Other Parts Discussed in Thread: AM3352
HI,
Dear Sir and Madam,
I am using LAN8710a  and AM3352 for one of our products ,which is starting for mass production,
but there is an issue or concern found , which is really needed to fix ASAP. the details are as follows.
Most time, it is working fine and stable, just sometimes especially when power on or  when unplug and plug back the RJ45 cable from the POE connector , the PHY dosen't work any more.I don't know if the PHY is damaged or some configuration is wrong , can you give me some advice ASAP? the schematic is as follows.
BTW, from EMC ,EMI and safety perspective,  how to improve my current design,  add more RC ?
also the 22R serial resisters is needed to change to 100R?  Can I leave the Pin18(nINT/TXER/TXD4) open ? what is the different between
config to nINT mode and TXER/TXD4 if I am using MII?
Appreciate for you reply ASAP!
Cheers,
Jason
