PROCESSOR-SDK-DRA8X-TDA4X: PSDKLA_07_00 - sdk_install.sh error and u-boot compilation error
Part Number: PROCESSOR-SDK-DRA8X-TDA4X
Hi
I have two issues with the new Linux SDK.
1. sdk_install.sh error
The execution of the script was successful but there were some errors.
I attached the log.
~/ti-processor-sdk-linux-automotive-j7-evm-07_00_00$ ./sdk-install.sh
/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00
Enter target directory for SDK (default: /usr/local/arago-2020.05): /home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/linux-devkit
You are about to install the SDK to "/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/linux-devkit". Proceed[Y/n]?Y
Extracting SDK...done
Setting it up...sed: can't read /home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/linux-devkit/sysroots/x86_64-arago-linux/usr/lib/python3.8/site-packages/setuptools/script: No such file or directory
sed: can't read (dev).tmpl: No such file or directory
sed: can't read /home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/linux-devkit/sysroots/x86_64-arago-linux/usr/lib/python3.8/site-packages/setuptools/command/launcher: No such file or directory
sed: can't read manifest.xml: No such file or directory
done
SDK has been successfully set up and is ready to be used.
Installation completed!
2. U-boot compilation errors
Compilation of u-boot using make u-boot command does not succeed.
I was able to fix the errors by changing the names of the gcc toolchain binaries in the linux-devkit/sysroots/x86_64-arago-linux/usr/bin directory.(I removed -none- from the binaries names)
I attached the log from the compilation.
Building U-boot for A53
make -j 4 -C /home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot-* CROSS_COMPILE=/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-none-linux-gnu- \
	 j721e_evm_a72_config O=/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot_build/a53
make[1]: Entering directory '/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot-2020.01+gitAUTOINC+f9b0d030d3-gf9b0d030d3'
make[2]: Entering directory '/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot_build/a53'
  GEN     ./Makefile
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/kconfig/conf.o
  LEX     scripts/kconfig/zconf.lex.c
  YACC    scripts/kconfig/zconf.tab.c
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
# configuration written to .config
make[2]: Leaving directory '/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot_build/a53'
make[1]: Leaving directory '/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot-2020.01+gitAUTOINC+f9b0d030d3-gf9b0d030d3'
	CONFIG_MKIMAGE_DTC_PATH=/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot_build/a53/scripts/dtc/dtc \
	ATF=/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/prebuilt-images/bl31.bin TEE=/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/prebuilt-images/bl32.bin \
  GEN     ./Makefile
scripts/kconfig/conf  --syncconfig Kconfig
  CHK     include/config.h
  UPD     include/config.h
  CFG     u-boot.cfg
  GEN     include/autoconf.mk.dep
  CFG     spl/u-boot.cfg
  GEN     spl/include/autoconf.mk
  CHK     include/config/uboot.release
  CHK     include/generated/timestamp_autogenerated.h
  GEN     ./Makefile
  UPD     include/generated/timestamp_autogenerated.h
  HOSTCC  scripts/dtc/dtc.o
  HOSTCC  scripts/dtc/flattree.o
  HOSTCC  scripts/dtc/fstree.o
  HOSTCC  scripts/dtc/data.o
  HOSTCC  scripts/dtc/livetree.o
  UPD     include/config/uboot.release
  HOSTCC  scripts/dtc/treesource.o
  HOSTCC  scripts/dtc/srcpos.o
  HOSTCC  scripts/dtc/checks.o
  HOSTCC  scripts/dtc/util.o
  LEX     scripts/dtc/dtc-lexer.lex.c
  YACC    scripts/dtc/dtc-parser.tab.h
  YACC    scripts/dtc/dtc-parser.tab.c
  HOSTCC  scripts/dtc/dtc-lexer.lex.o
  HOSTCC  scripts/dtc/dtc-parser.tab.o
  Using /home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot-2020.01+gitAUTOINC+f9b0d030d3-gf9b0d030d3 as source for U-Boot
  CHK     include/generated/version_autogenerated.h
  UPD     include/generated/version_autogenerated.h
  HOSTLD  scripts/dtc/dtc
  CC      lib/asm-offsets.s
  CC      arch/arm/lib/asm-offsets.s
  CHK     include/generated/asm-offsets.h
  UPD     include/generated/asm-offsets.h
  CHK     include/generated/generic-asm-offsets.h
  UPD     include/generated/generic-asm-offsets.h
  LDS     u-boot.lds
  WRAP    tools/lib/crc8.c
  HOSTCC  tools/gen_eth_addr
  HOSTCC  tools/gen_ethaddr_crc.o
  HOSTCC  tools/img2srec
  HOSTCC  tools/mkenvimage.o
  HOSTCC  tools/os_support.o
  WRAP    tools/lib/crc32.c
  HOSTCC  tools/aisimage.o
  HOSTCC  tools/atmelimage.o
  HOSTCC  tools/fit_common.o
  HOSTCC  tools/fit_image.o
  HOSTCC  tools/image-host.o
  WRAP    tools/common/image-fit.c
  WRAP    tools/common/bootm.c
  HOSTCC  tools/lib/crc32.o
  HOSTCC  tools/default_image.o
  WRAP    tools/lib/fdtdec_common.c
  WRAP    tools/lib/fdtdec.c
  WRAP    tools/common/image.c
  HOSTCC  tools/imagetool.o
  HOSTCC  tools/imximage.o
  HOSTCC  tools/imx8image.o
  HOSTCC  tools/imx8mimage.o
  HOSTCC  tools/kwbimage.o
  WRAP    tools/lib/md5.c
  HOSTCC  tools/lpc32xximage.o
  HOSTCC  tools/mxsimage.o
  HOSTCC  tools/omapimage.o
  HOSTCC  tools/pblimage.o
  HOSTCC  tools/pbl_crc32.o
  HOSTCC  tools/vybridimage.o
  HOSTCC  tools/stm32image.o
  WRAP    tools/lib/rc4.c
  HOSTCC  tools/rkcommon.o
  HOSTCC  tools/rkimage.o
  HOSTCC  tools/rksd.o
  HOSTCC  tools/rkspi.o
  HOSTCC  tools/socfpgaimage.o
  WRAP    tools/lib/crc16.c
  WRAP    tools/lib/sha1.c
  WRAP    tools/lib/sha256.c
  WRAP    tools/common/hash.c
  HOSTCC  tools/ublimage.o
  HOSTCC  tools/zynqimage.o
  HOSTCC  tools/zynqmpimage.o
  HOSTCC  tools/zynqmpbif.o
  HOSTCC  tools/libfdt/fdt.o
  HOSTCC  tools/libfdt/fdt_wip.o
  HOSTCC  tools/libfdt/fdt_sw.o
  HOSTCC  tools/libfdt/fdt_rw.o
  HOSTCC  tools/libfdt/fdt_strerror.o
  HOSTCC  tools/libfdt/fdt_addresses.o
  HOSTCC  tools/libfdt/fdt_empty_tree.o
  HOSTCC  tools/libfdt/fdt_overlay.o
  WRAP    tools/lib/libfdt/fdt_ro.c
  WRAP    tools/lib/libfdt/fdt_region.c
  HOSTCC  tools/gpimage.o
  HOSTCC  tools/gpimage-common.o
  HOSTCC  tools/mtk_image.o
  HOSTCC  tools/dumpimage.o
  HOSTCC  tools/common/image-fit.o
  HOSTCC  tools/common/bootm.o
  HOSTCC  tools/lib/fdtdec_common.o
  HOSTCC  tools/lib/fdtdec.o
  HOSTCC  tools/common/image.o
  HOSTCC  tools/lib/md5.o
  HOSTCC  tools/lib/rc4.o
  HOSTCC  tools/lib/crc16.o
  HOSTCC  tools/lib/sha1.o
  HOSTCC  tools/lib/sha256.o
  HOSTCC  tools/common/hash.o
  HOSTCC  tools/lib/libfdt/fdt_ro.o
  HOSTCC  tools/lib/libfdt/fdt_region.o
  HOSTCC  tools/mkimage.o
  HOSTCC  tools/proftool
  HOSTCC  tools/relocate-rela
  HOSTCC  tools/fdtgrep.o
  HOSTCC  tools/spl_size_limit
  HOSTCC  tools/lib/crc8.o
  HOSTLD  tools/mkenvimage
  HOSTLD  tools/dumpimage
  HOSTLD  tools/mkimage
  HOSTLD  tools/gen_ethaddr_crc
  HOSTLD  tools/fdtgrep
  LD      arch/arm/cpu/built-in.o
  CC      arch/arm/mach-k3/j721e_init.o
  CC      arch/arm/cpu/armv8/cpu.o
  CC      board/ti/common/board_detect.o
  AS      arch/arm/lib/crt0_64.o
  AS      arch/arm/lib/setjmp_aarch64.o
  AS      arch/arm/lib/relocate_64.o
  CC      arch/arm/lib/bootm-fdt.o
  CC      arch/arm/cpu/armv8/generic_timer.o
  CC      arch/arm/mach-k3/arm64-mmu.o
  CC      arch/arm/lib/bootm.o
  CC      arch/arm/cpu/armv8/cache_v8.o
  CC      arch/arm/mach-k3/common.o
  LD      board/ti/common/built-in.o
  AS      arch/arm/cpu/armv8/exceptions.o
  CC      arch/arm/cpu/armv8/exception_level.o
  CC      arch/arm/lib/image.o
  LD      arch/arm/mach-k3/built-in.o
  CC      board/ti/j721e/evm.o
  AS      arch/arm/cpu/armv8/cache.o
  AS      arch/arm/cpu/armv8/tlb.o
  CC      arch/arm/lib/sections.o
  AS      arch/arm/cpu/armv8/transition.o
  CC      arch/arm/lib/stack.o
  CC      arch/arm/lib/interrupts_64.o
  CC      arch/arm/cpu/armv8/fwcall.o
  CC      arch/arm/cpu/armv8/cpu-dt.o
  LD      board/ti/j721e/built-in.o
  AS      arch/arm/cpu/armv8/start.o
  LD      cmd/arm/built-in.o
  CC      cmd/boot.o
  CC      arch/arm/lib/cache.o
  LD      arch/arm/cpu/armv8/built-in.o
  CC      common/main.o
  CC      common/init/board_init.o
  CC      cmd/bootm.o
  CC      arch/arm/lib/psci-dt.o
  AR      arch/arm/lib/lib.a
  CC      common/exports.o
  LD      common/init/built-in.o
  AS      arch/arm/lib/crt0_aarch64_efi.o
  CC      common/hash.o
  CC      arch/arm/lib/reloc_aarch64_efi.o
  LD      arch/arm/lib/built-in.o
  CC      cmd/help.o
  CC      disk/part.o
  CC      cmd/version.o
  CC      common/cli_hush.o
  CC      cmd/blk_common.o
  LD      drivers/adc/built-in.o
  LD      drivers/ata/built-in.o
  LD      drivers/axi/built-in.o
  CC      drivers/block/blk-uclass.o
  CC      cmd/source.o
  CC      disk/part_dos.o
  CC      cmd/bdinfo.o
  CC      cmd/blkcache.o
  CC      disk/part_efi.o
  CC      drivers/block/blkcache.o
  CC      cmd/bootefi.o
  LD      drivers/block/built-in.o
  LD      drivers/cache/built-in.o
  LD      drivers/clk/analogbits/built-in.o
  LD      drivers/clk/imx/built-in.o
  CC      common/autoboot.o
  LD      drivers/clk/tegra/built-in.o
  CC      drivers/clk/clk-uclass.o
  CC      common/board_f.o
  CC      cmd/booti.o
  CC      cmd/console.o
  CC      drivers/clk/clk_fixed_rate.o
  CC      cmd/echo.o
  CC      common/board_r.o
  LD      disk/built-in.o
  CC      cmd/exit.o
  CC      drivers/clk/clk_fixed_factor.o
  CC      common/board_info.o
  CC      cmd/ext4.o
  CC      drivers/clk/clk-ti-sci.o
  CC      cmd/ext2.o
  CC      common/bootm.o
  CC      common/bootm_os.o
  CC      cmd/fat.o
  LD      drivers/clk/built-in.o
  CC      drivers/core/device.o
  CC      cmd/fdt.o
  CC      common/fdt_support.o
  CC      drivers/dma/ti/k3-udma.o
  CC      drivers/core/fdtaddr.o
  CC      drivers/core/lists.o
  CC      cmd/fs.o
  CC      cmd/gpio.o
  CC      common/miiphyutil.o
  CC      drivers/core/root.o
  CC      cmd/i2c.o
  CC      drivers/core/uclass.o
  CC      common/usb.o
  CC      drivers/core/util.o
  CC      cmd/itest.o
  CC      common/usb_hub.o
  CC      drivers/core/device-remove.o
  LD      drivers/dma/ti/built-in.o
  CC      drivers/dma/dma-uclass.o
  CC      cmd/load.o
  CC      drivers/core/simple-bus.o
  LD      drivers/dma/built-in.o
  CC      cmd/mem.o
  CC      common/usb_storage.o
  CC      drivers/core/dump.o
  CC      drivers/gpio/gpio-uclass.o
  CC      drivers/core/regmap.o
  CC      cmd/mii.o
  CC      drivers/core/syscon-uclass.o
  CC      common/flash.o
  CC      cmd/mdio.o
  CC      drivers/gpio/pca953x_gpio.o
  CC      drivers/core/of_extra.o
  CC      common/splash.o
  CC      common/menu.o
  CC      drivers/core/ofnode.o
  CC      cmd/misc.o
  CC      drivers/gpio/da8xx_gpio.o
  CC      cmd/mmc.o
  CC      common/cli_readline.o
  LD      drivers/gpio/built-in.o
  CC      cmd/mtd.o
  CC      drivers/core/read_extra.o
  CC      common/cli_simple.o
  LD      drivers/core/built-in.o
  CC      drivers/crypto/fsl/sec.o
  CC      common/console.o
  CC      cmd/legacy-mtd-utils.o
  LD      drivers/crypto/fsl/built-in.o
  LD      drivers/crypto/rsa_mod_exp/built-in.o
  LD      drivers/crypto/built-in.o
  CC      drivers/dfu/dfu.o
  CC      cmd/net.o
  CC      common/dlmalloc.o
  CC      cmd/part.o
  CC      drivers/i2c/i2c-uclass.o
  CC      cmd/pinmux.o
  CC      drivers/dfu/dfu_mmc.o
  CC      cmd/pxe.o
  CC      drivers/i2c/omap24xx_i2c.o
  CC      common/malloc_simple.o
  CC      cmd/pxe_utils.o
  CC      drivers/dfu/dfu_ram.o
  CC      common/image.o
  CC      drivers/dfu/dfu_sf.o
  LD      drivers/i2c/built-in.o
  CC      cmd/remoteproc.o
  LD      drivers/dfu/built-in.o
  CC      drivers/fastboot/fb_common.o
  CC      common/image-android.o
  CC      cmd/sf.o
  CC      cmd/scsi.o
  CC      drivers/fastboot/fb_getvar.o
  CC      common/image-fdt.o
  CC      cmd/disk.o
  CC      drivers/fastboot/fb_command.o
  CC      common/image-fit.o
  CC      cmd/sysboot.o
  CC      drivers/fastboot/fb_mmc.o
  CC      drivers/firmware/firmware-uclass.o
  CC      cmd/time.o
  CC      drivers/firmware/ti_sci.o
  CC      cmd/test.o
  LD      drivers/fastboot/built-in.o
  CC      common/memsize.o
  CC      cmd/ubi.o
  CC      drivers/input/key_matrix.o
  CC      common/stdio.o
  LD      drivers/input/built-in.o
  CC      common/cli.o
  CC      drivers/mailbox/mailbox-uclass.o
  CC      common/dfu.o
  CC      cmd/ubifs.o
  CC      drivers/mailbox/k3-sec-proxy.o
  CC      common/command.o
  CC      cmd/unzip.o
  CC      cmd/lzmadec.o
  LD      drivers/mailbox/built-in.o
  CC      common/s_record.o
  CC      cmd/ufs.o
  LD      drivers/memory/built-in.o
  CC      common/xyzModem.o
  LD      drivers/net/mscc_eswitch/built-in.o
  CC      drivers/net/ti/am65-cpsw-nuss.o
  CC      cmd/usb.o
  LD      common/built-in.o
  CC      drivers/misc/misc-uclass.o
  CC      drivers/net/ti/cpsw_mdio.o
  CC      cmd/fastboot.o
  LD      drivers/misc/built-in.o
  CC      cmd/usb_mass_storage.o
  LD      drivers/net/ti/built-in.o
  LD      drivers/net/built-in.o
  CC      cmd/ximg.o
  CC      drivers/net/phy/phy.o
  CC      cmd/dfu.o
  LD      drivers/power/built-in.o
  CC      cmd/gpt.o
  LD      drivers/firmware/built-in.o
  CC      drivers/mmc/mmc.o
  CC      drivers/mmc/mmc-uclass.o
  CC      cmd/nvedit.o
  CC      drivers/net/phy/dp83867.o
  CC      drivers/mmc/mmc_write.o
  LD      drivers/mtd/nand/built-in.o
  LD      drivers/mtd/onenand/built-in.o
  CC      drivers/mtd/spi/sf-uclass.o
  CC      drivers/net/phy/fixed.o
  CC      cmd/elf.o
  CC      drivers/mtd/spi/sf_probe.o
  LD      drivers/net/phy/built-in.o
  CC      drivers/mux/mux-uclass.o
  LD      cmd/built-in.o
  LD      drivers/power/battery/built-in.o
  CC      drivers/mtd/spi/spi-nor-ids.o
  CC      drivers/mmc/mmc_boot.o
  CC      drivers/mtd/ubi/attach.o
  CC      drivers/mux/mmio.o
  CC      drivers/mtd/spi/spi-nor-core.o
  CC      drivers/mmc/sdhci.o
  LD      drivers/mux/built-in.o
  CC      drivers/mtd/mtdcore.o
  CC      drivers/mmc/am654_sdhci.o
  CC      drivers/mtd/mtd_uboot.o
  CC      drivers/mtd/ubi/build.o
  LD      drivers/mmc/built-in.o
  CC      drivers/mtd/spi/sf_mtd.o
  CC      drivers/mtd/mtd-uclass.o
  CC      drivers/power/domain/power-domain-uclass.o
  LD      drivers/power/fuel_gauge/built-in.o
  CC      drivers/phy/cadence/phy-cadence-sierra.o
  LD      drivers/mtd/spi/spi-nor.o
  LD      drivers/mtd/spi/built-in.o
  LD      drivers/power/mfd/built-in.o
  LD      drivers/phy/allwinner/built-in.o
  CC      drivers/power/pmic/pmic-uclass.o
  CC      drivers/power/domain/ti-sci-power-domain.o
  LD      drivers/power/domain/built-in.o
  CC      drivers/power/pmic/palmas.o
  CC      drivers/mtd/ubi/vtbl.o
  CC      drivers/power/regulator/regulator-uclass.o
  LD      drivers/phy/cadence/built-in.o
  CC      drivers/phy/ti/phy-j721e-wiz.o
  LD      drivers/power/pmic/built-in.o
  CC      drivers/phy/phy-uclass.o
  CC      drivers/serial/serial-uclass.o
  CC      drivers/power/regulator/regulator_common.o
  LD      drivers/phy/ti/built-in.o
  LD      drivers/phy/built-in.o
  CC      drivers/mtd/ubi/vmt.o
  CC      drivers/power/regulator/fixed.o
  CC      drivers/spi/spi-uclass.o
  CC      drivers/serial/ns16550.o
  CC      drivers/power/regulator/gpio-regulator.o
  CC      drivers/serial/serial_omap.o
  CC      drivers/spi/spi-mem.o
  CC      drivers/power/regulator/palmas_regulator.o
  CC      drivers/mtd/ubi/upd.o
  LD      drivers/serial/built-in.o
  LD      drivers/phy/marvell/built-in.o
  CC      drivers/usb/cdns3/core.o
  CC      drivers/spi/cadence_qspi.o
  LD      drivers/power/regulator/built-in.o
  LD      drivers/pinctrl/broadcom/built-in.o
  LD      drivers/pinctrl/nxp/built-in.o
  CC      drivers/pinctrl/pinctrl-uclass.o
  CC      drivers/mtd/ubi/kapi.o
  CC      drivers/spi/cadence_qspi_apb.o
  CC      drivers/usb/cdns3/drd.o
  CC      drivers/pinctrl/pinctrl-single.o
  CC      drivers/usb/cdns3/gadget.o
  CC      drivers/mtd/ubi/eba.o
  LD      drivers/pinctrl/built-in.o
  CC      drivers/usb/common/common.o
  LD      drivers/usb/common/built-in.o
  LD      drivers/pwm/built-in.o
  LD      drivers/usb/dwc3/built-in.o
  CC      drivers/ram/ram-uclass.o
  LD      drivers/spi/built-in.o
  LD      drivers/usb/emul/built-in.o
  CC      drivers/remoteproc/rproc-uclass.o
  LD      drivers/ram/built-in.o
  LD      drivers/usb/eth/built-in.o
  CC      drivers/reset/reset-uclass.o
  CC      drivers/reset/reset-ti-sci.o
  CC      drivers/remoteproc/rproc-elf-loader.o
  CC      drivers/mtd/ubi/io.o
  LD      drivers/reset/built-in.o
  CC      drivers/rtc/rtc-lib.o
  CC      drivers/remoteproc/ti_k3_dsp_rproc.o
  LD      drivers/rtc/built-in.o
  CC      drivers/usb/gadget/epautoconf.o
  CC      drivers/usb/cdns3/ep0.o
  CC      drivers/remoteproc/ti_k3_r5f_rproc.o
  CC      drivers/usb/gadget/config.o
  CC      drivers/mtd/ubi/wl.o
  CC      drivers/usb/gadget/usbstring.o
  CC      drivers/usb/cdns3/host.o
  CC      drivers/usb/gadget/g_dnl.o
  CC      drivers/usb/cdns3/cdns3-ti.o
  LD      drivers/remoteproc/built-in.o
  CC      drivers/usb/gadget/f_dfu.o
  LD      drivers/usb/cdns3/cdns3.o
  LD      drivers/usb/cdns3/built-in.o
  CC      drivers/usb/gadget/f_mass_storage.o
  CC      drivers/mtd/ubi/crc32.o
  CC      drivers/usb/gadget/udc/udc-core.o
  CC      drivers/mtd/ubi/misc.o
  CC      drivers/usb/host/usb-uclass.o
  CC      drivers/mtd/ubi/debug.o
  CC      drivers/usb/gadget/udc/udc-uclass.o
  LD      drivers/usb/gadget/udc/built-in.o
  CC      drivers/usb/gadget/f_fastboot.o
  CC      drivers/usb/host/xhci.o
  LD      drivers/mtd/ubi/built-in.o
  CC      drivers/mtd/mtdpart.o
  CC      drivers/scsi/scsi-uclass.o
  LD      drivers/usb/gadget/built-in.o
  CC      drivers/scsi/scsi.o
  LD      drivers/smem/built-in.o
  LD      drivers/usb/musb-new/built-in.o
  CC      drivers/soc/ti/k3-navss-ringacc.o
  CC      drivers/mtd/cfi_flash.o
  CC      drivers/usb/host/xhci-mem.o
  LD      drivers/scsi/built-in.o
  LD      drivers/usb/musb/built-in.o
  LD      drivers/sound/built-in.o
  LD      drivers/usb/phy/built-in.o
  LD      drivers/usb/ulpi/built-in.o
  LD      drivers/spmi/built-in.o
  CC      env/common.o
  CC      env/env.o
  CC      drivers/usb/host/xhci-ring.o
  LD      drivers/soc/ti/built-in.o
  CC      drivers/soc/soc-uclass.o
  CC      env/attr.o
  CC      drivers/soc/soc_ti_k3.o
  CC      env/callback.o
  LD      drivers/soc/built-in.o
  CC      drivers/mtd/cfi_mtd.o
  LD      drivers/usb/host/built-in.o
  LD      drivers/thermal/built-in.o
  CC      drivers/mtd/hbmc-am654.o
  CC      drivers/sysreset/sysreset-uclass.o
  CC      env/flags.o
  CC      drivers/ufs/ufs.o
  LD      drivers/mtd/mtd.o
  CC      drivers/sysreset/sysreset-ti-sci.o
  LD      drivers/mtd/built-in.o
  CC      drivers/ufs/ufs-uclass.o
  CC      env/mmc.o
  LD      drivers/sysreset/built-in.o
  CC      drivers/ufs/cdns-platform.o
  LD      drivers/video/bridge/built-in.o
  LD      drivers/video/sunxi/built-in.o
  LD      drivers/video/built-in.o
  CC      drivers/ufs/ti-j721e-ufs.o
  LD      drivers/watchdog/built-in.o
  LD      env/built-in.o
  CC      fs/ext4/ext4fs.o
  CC      fs/fat/fat_write.o
  CC      fs/ubifs/ubifs.o
  CC      fs/ext4/ext4_common.o
  LD      drivers/ufs/built-in.o
  LD      drivers/built-in.o
  LD      lib/crypto/built-in.o
  CC      lib/efi_driver/efi_uclass.o
  CC      fs/ubifs/io.o
  CC      lib/efi_driver/efi_block_device.o
  LD      lib/efi_driver/built-in.o
  CC      lib/efi_loader/efi_bootmgr.o
  CC      fs/ubifs/super.o
  LD      fs/fat/built-in.o
  CC      fs/fs.o
  CC      lib/efi_loader/efi_boottime.o
  CC      fs/ext4/dev.o
  CC      fs/ext4/ext4_write.o
  CC      lib/libfdt/fdt.o
  CC      lib/libfdt/fdt_wip.o
  CC      fs/ubifs/sb.o
  CC      lib/libfdt/fdt_strerror.o
  CC      lib/libfdt/fdt_sw.o
  CC      fs/ext4/ext4_journal.o
  CC      fs/ubifs/master.o
  CC      lib/libfdt/fdt_rw.o
  CC      lib/efi_loader/efi_console.o
  CC      fs/ext4/crc16.o
  CC      fs/ubifs/lpt.o
  CC      lib/libfdt/fdt_empty_tree.o
  LD      fs/ext4/built-in.o
  CC      lib/libfdt/fdt_addresses.o
  CC      net/checksum.o
  CC      lib/libfdt/fdt_overlay.o
  CC      net/arp.o
  CC      lib/efi_loader/efi_device_path.o
  CC      net/bootp.o
  CC      lib/libfdt/fdt_ro.o
  CC      lib/efi_loader/efi_device_path_to_text.o
  CC      net/eth-uclass.o
  CC      fs/ubifs/lpt_commit.o
  CC      lib/libfdt/fdt_region.o
  CC      lib/efi_loader/efi_device_path_utilities.o
  CC      net/eth_common.o
  CC      lib/efi_loader/efi_file.o
  LD      lib/libfdt/built-in.o
  CC      fs/fs_internal.o
  CC      net/net.o
  CC      fs/ubifs/scan.o
  CC      net/nfs.o
  CC      lib/efi_loader/efi_hii.o
  CC      fs/ubifs/lprops.o
  CC      fs/ubifs/tnc.o
  CC      net/ping.o
  CC      net/tftp.o
  CC      lib/efi_loader/efi_hii_config.o
  CC      lib/efi_loader/efi_image_loader.o
  CC      fs/ubifs/tnc_misc.o
  LD      net/built-in.o
  CC      lib/lzma/LzmaDec.o
  CC      lib/efi_loader/efi_memory.o
  CC      lib/efi_loader/efi_root_node.o
  CC      lib/efi_loader/efi_runtime.o
  CC      lib/lzo/lzo1x_decompress.o
  CC      fs/ubifs/debug.o
  CC      lib/efi_loader/efi_setup.o
  LD      lib/lzo/built-in.o
  CC      fs/ubifs/crc16.o
  CC      lib/lzma/LzmaTools.o
  CC      lib/zlib/zlib.o
  CC      lib/efi_loader/efi_unicode_collation.o
  LD      lib/lzma/built-in.o
  CC      lib/efi_loader/efi_variable.o
  CC      fs/ubifs/budget.o
  CC      lib/efi_loader/efi_watchdog.o
  CC      lib/charset.o
  CC      lib/efi_loader/efi_disk.o
  CC      fs/ubifs/log.o
  CC      fs/ubifs/orphan.o
  CC      lib/efi_loader/efi_net.o
  CC      lib/efi_loader/efi_smbios.o
  LD      lib/zlib/built-in.o
  CC      lib/crc7.o
  CC      fs/ubifs/recovery.o
  CC      lib/crc8.o
  CC      lib/efi_loader/helloworld.o
  CC      fs/ubifs/replay.o
  CC      lib/crc16.o
  AS      lib/efi_loader/efi_crt0.o
  CC      lib/efi_loader/efi_reloc.o
  CC      lib/efi_loader/efi_freestanding.o
  CC      fs/ubifs/gc.o
  LD      lib/efi_loader/built-in.o
  LD      lib/efi_loader/helloworld_efi.so
  OBJCOPY lib/efi_loader/helloworld.efi
  CC      lib/fdtdec_common.o
  CC      lib/smbios.o
  CC      lib/image-sparse.o
  CC      lib/ldiv.o
  LD      fs/ubifs/built-in.o
  CC      lib/md5.o
  LD      fs/built-in.o
  CC      lib/net_utils.o
  CC      lib/rc4.o
  CC      lib/rbtree.o
  CC      lib/list_sort.o
  CC      lib/sha1.o
  CC      lib/sha256.o
  CC      lib/gunzip.o
  CC      lib/fdtdec.o
  CC      lib/qsort.o
  CC      lib/hashtable.o
  CC      lib/errno.o
  CC      lib/display_options.o
  CC      lib/crc32.o
  CC      lib/ctype.o
  CC      lib/div64.o
  CC      lib/hang.o
  CC      lib/linux_compat.o
  CC      lib/linux_string.o
  CC      lib/lmb.o
  CC      lib/membuff.o
  CC      lib/slre.o
  CC      lib/string.o
  CC      lib/tables_csum.o
  CC      lib/time.o
  CC      lib/hexdump.o
  CC      lib/rand.o
  CC      lib/uuid.o
  CC      lib/panic.o
  CC      lib/vsprintf.o
  CC      lib/strto.o
  CC      lib/date.o
  CC      lib/elf.o
  LD      lib/built-in.o
  CC      examples/standalone/hello_world.o
  CC      examples/standalone/stubs.o
  LD      examples/standalone/libstubs.o
  LD      examples/standalone/hello_world
  OBJCOPY examples/standalone/hello_world.bin
  OBJCOPY examples/standalone/hello_world.srec
  LD      u-boot
  OBJCOPY u-boot-nodtb.bin
  OBJCOPY u-boot.srec
  SYM     u-boot.sym
  DTC     arch/arm/dts/k3-j721e-common-proc-board.dtb
  DTC     arch/arm/dts/k3-j721e-tps65917-proc-board.dtb
start=$(/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-none-linux-gnu-nm u-boot | grep __rel_dyn_start | cut -f 1 -d ' '); end=$(/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-none-linux-gnu-nm u-boot | grep __rel_dyn_end | cut -f 1 -d ' '); tools/relocate-rela u-boot-nodtb.bin 0x80800000 $start $end
  DTC     arch/arm/dts/k3-j721e-r5-common-proc-board.dtb
  SHIPPED dts/dt.dtb
  FDTGREP dts/dt-spl.dtb
  MKIMAGE u-boot.img
  CAT     u-boot-dtb.bin
  COPY    u-boot.dtb
  MKIMAGE u-boot-dtb.img
  COPY    u-boot.bin
  LD      spl/arch/arm/cpu/built-in.o
  CC      spl/arch/arm/mach-k3/j721e_init.o
  AS      spl/arch/arm/lib/crt0_64.o
  CC      spl/arch/arm/cpu/armv8/cpu.o
  CC      spl/board/ti/j721e/evm.o
  AS      spl/arch/arm/lib/setjmp_aarch64.o
  CC      spl/arch/arm/lib/spl.o
  CC      spl/arch/arm/cpu/armv8/generic_timer.o
  CC      spl/arch/arm/lib/zimage.o
  CC      spl/arch/arm/mach-k3/arm64-mmu.o
  LD      spl/board/ti/j721e/built-in.o
  CC      spl/arch/arm/mach-k3/common.o
  CC      spl/arch/arm/cpu/armv8/cache_v8.o
  CC      spl/arch/arm/lib/bootm-fdt.o
  CC      spl/board/ti/common/board_detect.o
  CC      spl/arch/arm/lib/sections.o
  CC      spl/arch/arm/lib/stack.o
  LD      spl/arch/arm/mach-k3/built-in.o
  CC      spl/arch/arm/lib/interrupts_64.o
  CC      spl/common/spl/spl.o
  AS      spl/arch/arm/cpu/armv8/cache.o
  AS      spl/arch/arm/cpu/armv8/tlb.o
  AS      spl/arch/arm/cpu/armv8/transition.o
  LD      spl/board/ti/common/built-in.o
  CC      spl/arch/arm/cpu/armv8/fwcall.o
  CC      spl/arch/arm/cpu/armv8/cpu-dt.o
  CC      spl/arch/arm/lib/cache.o
  CC      spl/arch/arm/lib/psci-dt.o
  AS      spl/arch/arm/cpu/armv8/start.o
  CC      spl/common/spl/spl_fit.o
  LD      spl/arch/arm/cpu/armv8/built-in.o
  CC      spl/common/init/board_init.o
  CC      spl/common/dfu.o
  AR      spl/arch/arm/lib/lib.a
  AS      spl/arch/arm/lib/crt0_aarch64_efi.o
  CC      spl/arch/arm/lib/reloc_aarch64_efi.o
  LD      spl/common/init/built-in.o
  CC      spl/common/spl/spl_ymodem.o
  LD      spl/arch/arm/lib/built-in.o
  CC      spl/cmd/nvedit.o
  CC      spl/common/hash.o
  CC      spl/cmd/elf.o
  CC      spl/common/spl/spl_mmc.o
  CC      spl/common/spl/spl_fat.o
  LD      spl/cmd/built-in.o
  CC      spl/common/spl/spl_dfu.o
  CC      spl/common/xyzModem.o
  CC      spl/common/spl/spl_spi.o
  CC      spl/env/common.o
  CC      spl/common/spl/spl_ram.o
  CC      spl/lib/libfdt/fdt.o
  LD      spl/common/spl/built-in.o
  CC      spl/lib/sha1.o
  CC      spl/env/env.o
  CC      spl/common/common_fit.o
  CC      spl/lib/libfdt/fdt_wip.o
  CC      spl/common/fdt_support.o
  CC      spl/env/attr.o
  CC      spl/lib/libfdt/fdt_strerror.o
  CC      spl/lib/libfdt/fdt_sw.o
  CC      spl/env/flags.o
  CC      spl/env/callback.o
  CC      spl/lib/libfdt/fdt_rw.o
  CC      spl/env/mmc.o
  CC      spl/lib/sha256.o
  CC      spl/common/console.o
  LD      spl/env/built-in.o
  CC      spl/lib/libfdt/fdt_empty_tree.o
  CC      spl/disk/part.o
  CC      spl/lib/libfdt/fdt_addresses.o
  CC      spl/lib/libfdt/fdt_overlay.o
  CC      spl/common/dlmalloc.o
  CC      spl/disk/part_dos.o
  CC      spl/lib/libfdt/fdt_ro.o
  CC      spl/drivers/block/blk-uclass.o
  LD      spl/disk/built-in.o
  CC      spl/lib/fdtdec_common.o
  CC      spl/common/malloc_simple.o
  CC      spl/lib/fdtdec.o
  CC      spl/common/image.o
  CC      spl/lib/libfdt/fdt_region.o
  LD      spl/drivers/block/built-in.o
  LD      spl/drivers/clk/analogbits/built-in.o
  LD      spl/drivers/clk/imx/built-in.o
  LD      spl/drivers/clk/tegra/built-in.o
  CC      spl/drivers/clk/clk-uclass.o
  LD      spl/lib/libfdt/built-in.o
  CC      spl/lib/crc16.o
  CC      spl/common/image-android.o
  LD      spl/drivers/usb/dwc3/built-in.o
  CC      spl/lib/qsort.o
  CC      spl/drivers/clk/clk_fixed_rate.o
  CC      spl/lib/hashtable.o
  CC      spl/lib/errno.o
  CC      spl/common/image-fdt.o
  CC      spl/drivers/clk/clk_fixed_factor.o
  CC      spl/drivers/usb/cdns3/core.o
  CC      spl/drivers/clk/clk-ti-sci.o
  CC      spl/common/image-fit.o
  CC      spl/drivers/usb/cdns3/drd.o
  LD      spl/drivers/clk/built-in.o
  CC      spl/lib/display_options.o
  CC      spl/drivers/core/device.o
  CC      spl/drivers/usb/cdns3/gadget.o
  CC      spl/lib/crc32.o
  CC      spl/lib/ctype.o
  CC      spl/lib/div64.o
  CC      spl/lib/hang.o
  CC      spl/drivers/core/fdtaddr.o
  CC      spl/lib/linux_compat.o
  CC      spl/common/boot_fit.o
  CC      spl/drivers/core/lists.o
  CC      spl/lib/linux_string.o
  CC      spl/common/memsize.o
  CC      spl/lib/lmb.o
  CC      spl/drivers/core/root.o
  CC      spl/common/stdio.o
  CC      spl/lib/membuff.o
  CC      spl/common/cli.o
  CC      spl/drivers/core/uclass.o
  CC      spl/common/command.o
  CC      spl/lib/slre.o
  CC      spl/drivers/usb/cdns3/ep0.o
  CC      spl/drivers/core/util.o
  CC      spl/drivers/core/simple-bus.o
  CC      spl/common/s_record.o
  CC      spl/lib/string.o
  CC      spl/drivers/usb/cdns3/cdns3-ti.o
  CC      spl/drivers/core/dump.o
  LD      spl/common/built-in.o
  CC      spl/lib/tables_csum.o
  LD      spl/drivers/usb/cdns3/cdns3.o
  LD      spl/drivers/usb/cdns3/built-in.o
  CC      spl/lib/time.o
  CC      spl/drivers/core/regmap.o
  CC      spl/lib/hexdump.o
  LD      spl/dts/built-in.o
  CC      spl/lib/uuid.o
  CC      spl/lib/rand.o
  CC      spl/fs/fat/fat.o
  CC      spl/drivers/core/of_extra.o
  CC      spl/lib/panic.o
  CC      spl/lib/tiny-printf.o
  CC      spl/drivers/core/ofnode.o
  LDS     spl/u-boot-spl.lds
  CC      spl/lib/strto.o
  CC      spl/drivers/core/read_extra.o
  CC      spl/lib/date.o
  CC      spl/lib/elf.o
  CC      spl/fs/fs_internal.o
  LD      spl/fs/fat/built-in.o
/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot-2020.01+gitAUTOINC+f9b0d030d3-gf9b0d030d3/tools/k3_fit_atf.sh \
spl/dts/k3-j721e-common-proc-board.dtb spl/dts/k3-j721e-tps65917-proc-board.dtb > u-boot-spl-k3.its
  LD      spl/drivers/core/built-in.o
  CC      spl/drivers/dfu/dfu.o
  FDTGREP spl/dts/k3-j721e-common-proc-board.dtb
  FDTGREP spl/dts/k3-j721e-tps65917-proc-board.dtb
  CC      spl/drivers/dma/ti/k3-udma.o
  LD      spl/fs/built-in.o
  CC      spl/drivers/dma/dma-uclass.o
  LD      spl/lib/built-in.o
  MKIMAGE spl/u-boot-spl.multidtb.fit
  CC      spl/drivers/firmware/firmware-uclass.o
  CC      spl/drivers/firmware/ti_sci.o
  CC      spl/drivers/gpio/gpio-uclass.o
  CC      spl/drivers/dfu/dfu_ram.o
  LD      spl/drivers/dfu/built-in.o
  CC      spl/drivers/i2c/i2c-uclass.o
  CC      spl/drivers/gpio/pca953x_gpio.o
  CC      spl/drivers/i2c/omap24xx_i2c.o
  CC      spl/drivers/gpio/da8xx_gpio.o
  LD      spl/drivers/gpio/built-in.o
  CC      spl/drivers/mailbox/mailbox-uclass.o
  LD      spl/drivers/i2c/built-in.o
  CC      spl/drivers/misc/misc-uclass.o
  LD      spl/drivers/dma/ti/built-in.o
  CC      spl/drivers/mailbox/k3-sec-proxy.o
  LD      spl/drivers/dma/built-in.o
  CC      spl/drivers/mmc/mmc.o
  LD      spl/drivers/misc/built-in.o
  CC      spl/drivers/mmc/mmc-uclass.o
  LD      spl/drivers/mailbox/built-in.o
  CC      spl/drivers/mmc/mmc_boot.o
  CC      spl/drivers/mmc/sdhci.o
  CC      spl/drivers/mmc/am654_sdhci.o
  CC      spl/drivers/mtd/spi/sf-uclass.o
  LD      spl/drivers/mux/built-in.o
  LD      spl/drivers/firmware/built-in.o
  CC      spl/drivers/mtd/spi/sf_probe.o
  CC      spl/drivers/mtd/spi/spi-nor-ids.o
  LD      spl/drivers/mmc/built-in.o
  LD      spl/drivers/phy/cadence/built-in.o
  LD      spl/drivers/phy/ti/built-in.o
  CC      spl/drivers/phy/phy-uclass.o
  LD      spl/drivers/pinctrl/broadcom/built-in.o
  LD      spl/drivers/pinctrl/nxp/built-in.o
  CC      spl/drivers/pinctrl/pinctrl-uclass.o
  CC      spl/drivers/pinctrl/pinctrl-single.o
  CC      spl/drivers/mtd/spi/spi-nor-core.o
  LD      spl/drivers/phy/built-in.o
  LD      spl/drivers/power/built-in.o
  CC      spl/drivers/power/domain/power-domain-uclass.o
  CC      spl/drivers/power/pmic/pmic-uclass.o
  LD      spl/drivers/pinctrl/built-in.o
  CC      spl/drivers/power/domain/ti-sci-power-domain.o
  CC      spl/drivers/power/regulator/regulator-uclass.o
  LD      spl/drivers/power/domain/built-in.o
  CC      spl/drivers/power/pmic/palmas.o
  CC      spl/drivers/power/regulator/regulator_common.o
  LD      spl/drivers/power/pmic/built-in.o
  CC      spl/drivers/power/regulator/fixed.o
  CC      spl/drivers/ram/ram-uclass.o
  CC      spl/drivers/power/regulator/gpio-regulator.o
  CC      spl/drivers/power/regulator/palmas_regulator.o
  LD      spl/drivers/ram/built-in.o
  CC      spl/drivers/reset/reset-uclass.o
  CC      spl/drivers/serial/serial-uclass.o
  LD      spl/drivers/mtd/spi/spi-nor.o
  LD      spl/drivers/mtd/spi/built-in.o
  LD      spl/drivers/mtd/built-in.o
  CC      spl/drivers/reset/reset-ti-sci.o
  LD      spl/drivers/power/regulator/built-in.o
  CC      spl/drivers/soc/ti/k3-navss-ringacc.o
  CC      spl/drivers/serial/ns16550.o
  CC      spl/drivers/spi/spi-uclass.o
  LD      spl/drivers/reset/built-in.o
  CC      spl/drivers/soc/soc-uclass.o
  CC      spl/drivers/soc/soc_ti_k3.o
  CC      spl/drivers/serial/serial_omap.o
  CC      spl/drivers/spi/spi-mem.o
  CC      spl/drivers/sysreset/sysreset-uclass.o
  LD      spl/drivers/serial/built-in.o
  CC      spl/drivers/spi/cadence_qspi.o
  CC      spl/drivers/usb/common/common.o
  LD      spl/drivers/soc/ti/built-in.o
  LD      spl/drivers/soc/built-in.o
  CC      spl/drivers/sysreset/sysreset-ti-sci.o
  CC      spl/drivers/usb/gadget/epautoconf.o
  LD      spl/drivers/usb/common/built-in.o
  CC      spl/drivers/usb/gadget/config.o
  CC      spl/drivers/spi/cadence_qspi_apb.o
  LD      spl/drivers/sysreset/built-in.o
  CC      spl/drivers/usb/gadget/udc/udc-core.o
  CC      spl/drivers/usb/gadget/udc/udc-uclass.o
  CC      spl/drivers/usb/gadget/usbstring.o
  CC      spl/drivers/usb/gadget/g_dnl.o
  LD      spl/drivers/usb/gadget/udc/built-in.o
  CC      spl/drivers/usb/gadget/f_dfu.o
  LD      spl/drivers/spi/built-in.o
  LD      spl/drivers/usb/gadget/built-in.o
  LD      spl/drivers/built-in.o
  LD      spl/u-boot-spl
  OBJCOPY spl/u-boot-spl-nodtb.bin
  MKIMAGE tispl.bin
  CAT     spl/u-boot-spl-dtb.bin
  COPY    spl/u-boot-spl.bin
FIT description: Configuration to load ATF and SPL
Created:         Tue Jun 23 19:16:13 2020
 Image 0 (atf)
  Description:  ARM Trusted Firmware
  Type:         Firmware
  Compression:  uncompressed
  Data Size:    39896 Bytes = 38.96 KiB = 0.04 MiB
  Architecture: AArch64
  OS:           ARM Trusted Firmware
  Load Address: 0x70000000
 Image 1 (tee)
  Description:  OPTEE
  Type:         Trusted Execution Environment Image
  Data Size:    378648 Bytes = 369.77 KiB = 0.36 MiB
 Image 2 (spl)
  Description:  SPL (64-bit)
  Type:         Standalone Program
  Data Size:    245008 Bytes = 239.27 KiB = 0.23 MiB
  Load Address: 0x80080000
  Entry Point:  0x80080000
 Image 3 (k3-j721e-common-proc-board.dtb)
  Description:  k3-j721e-common-proc-board
  Type:         Flat Device Tree
  Data Size:    10489 Bytes = 10.24 KiB = 0.01 MiB
  Architecture: ARM
 Image 4 (k3-j721e-tps65917-proc-board.dtb)
  Description:  k3-j721e-tps65917-proc-board
  Data Size:    11502 Bytes = 11.23 KiB = 0.01 MiB
  Architecture: ARM
 Default Configuration: 'k3-j721e-common-proc-board.dtb'
 Configuration 0 (k3-j721e-common-proc-board.dtb)
  Kernel:       unavailable
  Firmware:     atf
  FDT:          k3-j721e-common-proc-board.dtb
  Loadables:    tee
                spl
 Configuration 1 (k3-j721e-tps65917-proc-board.dtb)
  Kernel:       unavailable
  Firmware:     atf
  FDT:          k3-j721e-tps65917-proc-board.dtb
  Loadables:    tee
                spl
  CFGCHK  u-boot.cfg
Building U-boot for R5
make -j 4 -C /home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot-* CROSS_COMPILE=/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- \
	 j721e_evm_r5_config O=/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot_build/r5
make[2]: Entering directory '/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot_build/r5'
  GEN     ./Makefile
make[2]: Leaving directory '/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot_build/r5'
make[2]: /home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-gcc: Command not found
/bin/sh: 1: /home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-gcc: not found
dirname: missing operand
Try 'dirname --help' for more information.
  GEN     ./Makefile
/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot-2020.01+gitAUTOINC+f9b0d030d3-gf9b0d030d3/scripts/binutils-version.sh: line 18: /home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf-as: No such file or directory
  CFG     u-boot.cfg
/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot-2020.01+gitAUTOINC+f9b0d030d3-gf9b0d030d3/scripts/Makefile.autoconf:77: recipe for target 'u-boot.cfg' failed
make[3]: *** [u-boot.cfg] Error 1
make[3]: *** Waiting for unfinished jobs....
/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot-2020.01+gitAUTOINC+f9b0d030d3-gf9b0d030d3/scripts/Makefile.autoconf:48: recipe for target 'include/autoconf.mk.dep' failed
make[3]: *** [include/autoconf.mk.dep] Error 1
  CFG     spl/u-boot.cfg
/home/adam/ti-processor-sdk-linux-automotive-j7-evm-07_00_00/board-support/u-boot-2020.01+gitAUTOINC+f9b0d030d3-gf9b0d030d3/scripts/Makefile.autoconf:80: recipe for target 'spl/u-boot.cfg' failed
make[3]: *** [spl/u-boot.cfg] Error 1
make[2]: *** No rule to make target 'include/config/auto.conf', needed by 'include/config/uboot.release'.  Stop.
Makefile:167: recipe for target 'sub-make' failed
make[1]: *** [sub-make] Error 2
Makefile:140: recipe for target 'u-boot-r5' failed
make: *** [u-boot-r5] Error 2
