[FAQ] TDA4VM: Linux DTS DTB FAQs
Part Number: TDA4VM
I have the following questions:
  1. How to know which driver is probed with a particular Device tree node?
  2. How to know which CONFIG to be enabled to probe a particular Device tree node?
  3. How to get the DTS(device tree source) of a particular DTB(device tree binary)?
  • Answers to questions in the order:
      They key lies in the compatible string. For example ospi0 node:
       ospi0: spi@47040000 {
                              compatible = "ti,j721e-ospi", "ti,am654-ospi";
                              reg = <0x0 0x47040000 0x0 0x100>,
                                      <0x5 0x00000000 0x1 0x0000000>;
                              interrupts = <GIC_SPI 840 IRQ_TYPE_LEVEL_HIGH>;
                              cdns,fifo-depth = <256>;
      Search for compatible strings under drivers folder of Linux repository starting from first to last in order.
      Continuing with our ospi0 example:
      git grep ti,j721e-ospi drivers/
      No matches found so search for the next compatible.
      git grep ti,am654-ospi drivers/
      drivers/mtd/spi-nor/cadence-quadspi.c: .compatible = "ti,am654-ospi",
      Ospi0 probes the drivers/mtd/spi-nor/cadence-quadspi.c driver.
      Follow the steps for Q1 and once you know the driver name.
      Continuing with our ospi0 example.
      Couple of more steps to get to the CONFIG option:
      Driver: drivers/mtd/spi-nor/cadence-quadspi.c driver.
      Open the Makefile in the folder that has the driver.
      vi drivers/mtd/spi-nor/Makefile
      Search for cadence-quadspi.o (Driver name with object extension)
      obj-$(CONFIG_SPI_CADENCE_QUADSPI)       += cadence-quadspi.o
      CONFIG_SPI_CADENCE_QUADSPI option corresponds to ospi0 node.
      cd to the Linux repo.
      Example: Source for k3-am654-r5-base-board.dtb.
      scripts/dtc/dtc -I dtb -O dts  -o devicetree.dts arch/arm/dts/k3-am654-r5-base-board.dtb
      The source will be saved as devicetree.dts
    Keerthy
