Hi
I want to add to a pcb the IFA antenat so it will work with the cc2540 (the same as in the CC2540_MiniDK, any chance you
will put the CC2540_MiniDK in tideals)
after reading http://www.ti.com/lit/an/swra117d/swra117d.pdf I understand it should be designed very carefully
is therer all ready made eagle liberary for this antena (or even better for the entire CC2540_MiniDK)?
can I find the antena as eagle part?
if not is there any way to convert the DXF or gerber files you mentionsd in the pdf to Eagle format?
thanks
