Other Parts Discussed in Thread: INA826, TLC2252, OPA2191, OPA2187
Dear support forum,
I'm looking for a dual low power op amp powered by +/-5V sources, Iq current 50µA max. This op amp is intended to drive the REF pin of INA826 instrumentation amplifier. From op amp search table I found OPA2244. I have a few questions about the datasheet and the simulation model.
- GBW is specified at 430kHz (p.3 and p.4). Aol curve p.6 seems to cross 0dB between 200kHz and 400kHz. I tried the simulation model and GBW is about 310kHz (cf. OPA2244_aol.TSC attached to this message). Do you have any idea about the difference?
- Simulated phase plot does not seem to correlate with the curve given in the datasheet (p.6). What I'm missing in the simulation file?
- Do you know if OPA2244 is suitable for new design? Is there any newer ref with similar specifications?
Thank you for your help. Best regards,
Benoît,
