Other Parts Discussed in Thread: TPS23730
I have a technical question regarding EMC testing for a PoE design using the TPS23730EVM-093 evaluation module.
In my setup, power and data are delivered to the evaluation board via an Ethernet cable from a PoE injector. I have modified the TPS23730EVM-093 board to provide 60W at the output.
I am preparing for EMC tests, specifically surge and burst tests, and would like to understand the correct testing approach in this scenario:
- Should the 24V output be tested directly for surge/burst immunity?
- Or should I only test the shield of the Ethernet cable?
Your guidance on the correct procedure would be greatly appreciated.
