Part Number: LM7171
Other Parts Discussed in Thread: OP07
Dear All,
I have been using a OP07E amplifier in a inverting amplifier configuration and I understood the response to an AC signal. However when I changed the amplifier to the LM7171 the response was incorrect and the amp started to overheat. I intended to use the LM7171 due to its higher unity gain bandwidth. I have attached a diagram showing the circuit I made. Why does the LM7171 overheat in this configuration? Does the high speed ampllifier work in a different manner to the OP07 amp range?
Kind regards,
