Part Number: LM7171
I downloaded the spice model provided of the LM7171 and would like to make a simulation using this part in LTspice.
The model provided do not work with LTspice.
At first I had to modify a little bit the format of the file so that LTspice recognize the PIN names.
It allow me to run a simulation but the results are not possible. It show a huge current consumption from the positive voltage supply and the non inverting input (a hundred amp).
My circuit is a very simple follower one, any Opamp would work like a charm for that.
Hereafter an overview of the test simulation and the simulation file and library that I use.
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/14/LM7171-test-simulation.7z
Thank you in advance for your help.
