Part Number: TMS320C6678
How to rebuild the IBL of Processor SDK 6.3 in Windows Environment?
Pre-requisite:
1. Download PROCESSOR-SDK-RTOS-C667x 06_03_00_106 at https://software-dl.ti.com/processor-sdk-rtos/esd/C667x/latest/index_FDS.html
[ For the detailed steps of 2,3,4 below, click here : faq
2. MINGW
2.1 MinGW project link: http://www.mingw.org/
2.1 MinGW installer can be obtained from the following link
While installing MinGW following options have to be chosen:
1. MinGw Compiler Suite
- C Compiler
2. MinGW Developer Toolkit
3) Required toolset
- TI CGEN compiler CGT_C6000_7.3.0
Download and install this Package : https://www.ti.com/tool/download/C6000-CGT
Please scroll and select the paraticular CGT version 7.3.0
4 ) Modify the "environment setup script", setupenvMsys.sh located at \ti\pdk_c667x_2_0_16\packages\ti\boot\ibl\src\make
Sample - modification according to the compiler path in the PC.
#!/bin/bash # Environment setup to be done if using MSYS Bash shell for build # Specify the base directory of the c6000 compiler with UNIX style path separator export C6X_BASE_DIR='"C:/ti/c6000_7.4.24"' export PATH=$PATH:C:/ti/c6000_7.4.24/bin # Don't modify the below variables. They are derived from the above definitions export TOOLSC6X=$C6X_BASE_DIR export TOOLSC6XDOS=$C6X_BASE_DIR
Build Instructions
1. Modify the environment setup script, setupenvMsys.sh to match the tool chain installation
directory.
2. Set the environment variables:
- On a MinGW-MSYS Bash shell "source setupenvMsys.sh"
For C6678, Supported ENDIAN are
- big
- little
3. commands to build IBL:
1. Change directory to ibl\src\make
2. make>make evm_c6678_i2c ENDIAN=little I2C_BUS_ADDR=0x51
After re-building the IBL, the output binaries will be found at \ti\pdk_c667x_2_0_16\packages\ti\boot\ibl\src\make\bin
i2crom_0x51_c6678_le.bin (CCS data format)
i2crom_0x51_c6678_le.dat (raw binary)
Alternatively, we will find the same instructions in the file, "build_instructions.txt" located at :"\ti\pdk_c667x_2_0_16\packages\ti\boot\ibl\doc"
C6x Bootloader Build Instructions
1) Supported EVM's:
- C6678 LC EVM
- C6670 LC EVM
- C6474 LC EVM
- C6474 Mezzanine EVM
- C6472 LC EVM
- C6457 LC EVM
- DSK6455 EVM
- C6657 LC EVM
- TCI6634K2K EVM
2) Supported ENDIAN
- big
- little
3) Required toolset
Requirements for building IBL on Windows:
For building on a Windows machine, a GNU development environment is
required. MinGW installation is required for this.
http://sourceforge.net/projects/mingw/files/Automated%20MinGW%20Installer/mingw-get-inst/mingw-get-inst-20110316/mingw-get-inst-20110316.exe/download
- C Compiler
4) Build Instructions
- Change directory to ibl\src\make
- Modify the environment setup script to match the tool chain installation
directory:
For building in MINGW-MSYS Bash shell modify setupenvMsys.sh
For building in Linux Bash shell modify setupenvLnx.sh
- Set the environment variables:
On a Linux Bash shell run "source setupenvLnx.sh"
- Following are the commands for building IBL:
For TCI6634K2K Low Cost EVM:
make evm_tci6634k2k_i2c ENDIAN=little I2C_BUS_ADDR=0x51
Output images:
IBL image: bin/i2crom_0x51_tci6634k2k_le.dat (CCS data format)
: bin/i2crom_0x51_tci6634k2k_le.bin (raw binary)
make evm_tci6634k2k_i2c ENDIAN=big I2C_BUS_ADDR=0x51
Output images:
IBL image: bin/i2crom_0x51_tci6634k2k_be.dat (CCS data format)
: bin/i2crom_0x51_tci6634k2k_be.bin (raw binary)
For C6657 Low Cost EVM:
make evm_c6657_i2c ENDIAN=little I2C_BUS_ADDR=0x51
Output images:
IBL image: bin/i2crom_0x51_c6657_le.dat (CCS data format)
: bin/i2crom_0x51_c6657_le.bin (raw binary)
make evm_c6657_i2c ENDIAN=big I2C_BUS_ADDR=0x51
Output images:
IBL image: bin/i2crom_0x51_c6657_be.dat (CCS data format)
: bin/i2crom_0x51_c6657_be.bin (raw binary)
For C6678 Low Cost EVM:
Output images:
IBL image: bin/i2crom_0x51_c6678_le.dat (CCS data format)
: bin/i2crom_0x51_c6678_le.bin (raw binary)
make evm_c6678_i2c ENDIAN=big I2C_BUS_ADDR=0x51
Output images:
IBL image: bin/i2crom_0x51_c6678_be.dat (CCS data format)
: bin/i2crom_0x51_c6678_be.bin (raw binary)
For C6670 Low Cost EVM:
make evm_c6670_i2c ENDIAN=little I2C_BUS_ADDR=0x51
Output images:
IBL image: bin/i2crom_0x51_c6670_le.dat (CCS data format)
: bin/i2crom_0x51_c6670_le.bin (raw binary)
make evm_c6670_i2c ENDIAN=big I2C_BUS_ADDR=0x51
Output images:
IBL image: bin/i2crom_0x51_c6670_be.dat (CCS data format)
: bin/i2crom_0x51_c6670_be.bin (raw binary)
For C6474 LC EVM
make evm_c6474l ENDIAN=little
Output images:
IBL image: bin/i2crom_0x50_c6474l_le.dat (CCS data format)
: bin/i2crom_0x50_c6474l_le.bin (raw binary)
make evm_c6474l ENDIAN=big
Output images:
IBL image: bin/i2crom_0x50_c6474l_be.dat (CCS data format)
: bin/i2crom_0x50_c6474l_be.bin (raw binary)
For C6474 Mezzanine EVM
make evm_c6474 ENDIAN=little
Output images:
IBL image: bin/i2crom_0x50_c6474_le.dat (CCS data format)
: bin/i2crom_0x50_c6474_le.bin (raw binary)
make evm_c6474 ENDIAN=big
Output images:
IBL image: bin/i2crom_0x50_c6474_be.dat (CCS data format)
: bin/i2crom_0x50_c6474_be.bin (raw binary)
For C6472 LC EVM
make evm_c6472 ENDIAN=little
Output images:
IBL image: bin/i2crom_0x50_c6472_le.dat (CCS data format)
: bin/i2crom_0x50_c6472_le.bin (raw binary)
make evm_c6472 ENDIAN=big
Output images:
IBL image: bin/i2crom_0x50_c6472_be.dat (CCS data format)
: bin/i2crom_0x50_c6472_be.bin (raw binary)
For C6457 LC EVM
make evm_c6457 ENDIAN=little
Output images:
IBL image: bin/i2crom_0x50_c6457_le.dat (CCS data format)
: bin/i2crom_0x50_c6457_le.bin (raw binary)
make evm_c6457 ENDIAN=big
Output images:
IBL image: bin/i2crom_0x50_c6457_be.dat (CCS data format)
: bin/i2crom_0x50_c6457_be.bin (raw binary)
For DSK 6455 EVM
make evm_c6455 ENDIAN=little
Output images:
IBL image: bin/i2crom_0x50_c6455_le.dat (CCS data format)
: bin/i2crom_0x50_c6455_le.bin (raw binary)
make evm_c6455 ENDIAN=big
Output images:
IBL image: bin/i2crom_0x50_c6455_be.dat (CCS data format)
: bin/i2crom_0x50_c6455_be.bin (raw binary)
Shankari G
