Part Number: TDA4VM
There is some issue in my ethernet link. I wanted to do a sanity check using MAC loopback and see if the MAC is working well or not. Is there an easy way to do this?
Part Number: TDA4VM
devmem2 $addrdevmem2 $addr w $value#!/bin/bash my_ip_addr=192.168.1.46 server_ip_addr=192.168.1.100 mac_addr=0x0C023330 IF_NAME=eth2 echo "======= $IF_NAME stats =======" ethtool -S $IF_NAME | grep good echo "**************************" echo "Setting CPSW in Loopback" echo "**************************" var=$(( 16#$(devmem2 $mac_addr | tail -n1 -c9) )) devmem2 $mac_addr w `expr $var + 2` devmem2 $mac_addr echo "" echo "Running Ping ..." ping -c 5 $server_ip_addr echo "" echo "======= $IF_NAME stats =======" ethtool -S $IF_NAME | grep good echo "**************************" echo "Removing CPSW Loopback" echo "**************************" devmem2 $mac_addr w $var
If you see the MAC loopback test passing, then you should next do a phy loopback test.
Please refer this FAQ for more details on how to read statistics for CPSW
Tanmay
