Part Number: INA849
I am designing a amplifier circuit using INA849. The input to the INA849 is coming from hydrophone array of 96 channels as differential signal . It is given in the datasheet that there should be a input bias current return path. The screenshot of the data sheet part is attached below.
How to choose the resistor value and Inductor value for the same.?
Is the Inductor required for this? (Can i use only resistor? )
Will adding these input bias current return path resistor induce any noise to the signal chain?
What is the recommended value of resistor to be used?
The supply is +/-5V with ref as ground.
Thank you in advance
