Other Parts Discussed in Thread: PGA280
Hi:
I plan to the PGA280 to read multiple(256) wide ranging voltages accross resistances of 1 ohm to 10Kohm (0.1mV to 5V). These would be at the inputs of several multiplexers. Will this create a problem for the PGA280? Does it expect a constant input impedance source? If so, then i'd need a buffer and which low noise/bias current amp would you recommend?
David
