Generally, when using differential signals as inputs, a bias voltage is required, such as a bias voltage of 0, in order to produce an output. Why does AMC1350 differential signal still have output without bias voltage?
The AMC1350's inputs accept voltages between −4 V and 4 V, relative to GND1 (see the VCM specification).
The AMC1350's output has a fixed bias of about 1.44 V (see the VCMout specification).
input not referred to ground, the input signal swings outside of the common-mode input voltage range!
