INA228-Q1: Need to measure Microampere current
Part Number: INA228-Q1
Other Parts Discussed in Thread: INA228, INA238
Hi Team,
Could you please confirm whether it is possible to measure current in the microampere range using the INA228/INA238?
We need to measure current ranging from 0 to 500 microamperes.
If the INA228/INA238 is not suitable for this measurement range, kindly advise on alternative solutions.
Virali Chhag
  • Hello Virali,
    Yes, this is possible, depending on the size of shunt resistor you can use. The INA228 will be a better choice though. I recommend using our error tool to compare each device for your specific system parameters:
    https://www.ti.com/tool/download/CS-AMPLIFIER-ERROR-TOOL
    (Note, the x axis scale does not auto update, so you will want to change the axis to see the current range you are looking at)
    When measuring this small of current, I recommend using a 10nF capacitor across the inputs of the device. Ideally a small size cap, placed close to the pins.
    Mitch
