AMC3301: VOLTAGE SENSE
Part Number: AMC3301
Other Parts Discussed in Thread: AMC3330
Hi
we are using the AMC3301 in our voltage sense application.
Our input voltage is 28V,and we have implemented a three resistor voltage divider the top and bottom resistor are 37.4KE and the middle resistor is 499E.
However during the simulation we are not getting the expected output.
  • Hi Maheswari,
    What application is this for?
    The way the input circuit is connected, there is ~14 volts on the INN/INP pins relative to the device ground (HGND).  HGND should be connected to INN, and your V1 supply ground and resistor chain should be relative to a separate ground node.
    Also, the AMC3301 is intended for current sensing applications.  You should use the AMC3330 instead, it has a higher input range and a higher input impedance.
    Thanks.
  • Hi Saleh Ahmad
    Thank you for the clarification.
    We are using this circuit to verify whether the 28 V DC from the battery is present and stable.
    Our intention was to use this IC for voltage-sensing purposes by scaling the 28 V input down to below 250 mV through the resistor divider.
    While simulating, I used a simple two-resistor divider with 77.123 kΩ and 499 Ω, and I was able to get the correct output. However, when I use the three-resistor divider configuration, I am facing this issue
  • Hi Maheswari,
    Yes, when moving to the 3-resistor divider, the device HGND shouldn't be shared with the V1 source ground.  HGND should instead be connected to the low side of the sense resistor as below:
    Thanks.
