THS3202 model isn't working.
Other Parts Discussed in Thread: THS3202, TINA-TI
I'm using Altium in order to simulate this simple G = 2 non-inverting amplifier (the same that can be found in TSH3202EVM):
The output of the circuit above is this:
As can be seen, the output has 1 mVpp when the input is 60mVpp. This makes no sense. I'm using this simulation file:
* [Disclaimer] (C) Copyright 2003 Texas Instruments Incorporated. All rights
* reserved.
* Texas Instruments Incorporated hereby grants the user of this SPICE
* Macro-model a non-exclusive, nontransferable license to use this SPICE
* Macro-model under the following terms:
* Before using this SPICE Macro-model, the user should read this license. If
* the user does not accept these terms, the SPICE Macro-model should be
* returned to Texas Instruments within 30 days.
* The user is granted this license only to use the SPICE Macro-model and is
* not granted rights to sell, load, rent, lease or license the SPICE
* Macro-model in whole or in part, or in modified form to anyone other than
* user.
* User may modify the SPICE Macro-model to suit its specific applications but
* rights to derivative works and such modifications shall belong to Texas
* Instruments.
* This SPICE Macro-model is provided on an "AS IS" basis and Texas Instruments
* makes absolutely no warranty with respect to the information contained
* herein.
* TEXAS INSTRUMENTS DISCLAIMS AND CUSTOMER WAIVES ALL WARRANTIES, EXPRESS OR
* IMPLIED, INCLUDING WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR
* PURPOSE. The entire risk as to quality and performance is with the Customer.
* ACCORDINGLY, IN NO EVENT SHALL THE COMPANY BE LIABLE FOR ANY DAMAGES,
* WHETHER IN CONTRACT OR TORT,INCLUDING ANY LOST PROFITS OR OTHER INCIDENTAL,
* CONSEQUENTIAL, EXEMPLARY, OR PUNITIVE DAMAGES ARISING OUT OF THE USE OR
* APPLICATION OF THE SPICE Macro-model provided in this package.
* Further, Texas Instruments reserves the right to discontinue or make changes
* without notice to any product herein to improve reliability, function, or
* design.
* Texas Instruments does not convey any license under patent rights or any
* other intellectual property rights, including those of third parties.
.subckt ths3202 inp inn out vcc vee
.MODEL D_break D
+ RS=1.0000E-1
+ CJO=1.0000E-13
+ IS=100e-15
.MODEL pnp_is PNP
+ IS=10.000E-18
+ BF=124.36
+ VAF=100
+ IKF=.99789
+ ISE=10.000E-18
+ NE=1.3695
+ VAR=100
+ IKR=10.000E-3
+ ISC=10.000E-18
+ NK=1.8752
+ RE=1
+ RB=80
+ RC=10
+ CJE=12.000E-15
+ VJE=.9
+ MJE=.6
+ CJC=10.000E-15
+ MJC=.93
+ TF=8.0237E-12
+ XTF=12.990
+ VTF=12.704
+ ITF=.88449
+ TR=10.000E-9
+ KF=7e-14
+ AF=0.54
.MODEL npn_is NPN
+ IS=10.000E-18
+ BF=205.81
+ VAF=100
+ IKF=.99979
+ ISE=19.329E-18
+ NE=1.6102
+ VAR=100
+ IKR=20.000E-3
+ ISC=10.000E-18
+ NK=1.8762
+ RE=1
+ RB=100
+ RC=10
+ CJE=16.000E-15
+ VJE=1
+ MJE=.4
+ CJC=1.6000E-15
+ TF=5.5979E-12
+ XTF=97.940
+ VTF=28.359
+ ITF=2.2510
+ TR=10.000E-9
+ AF=0.54
+ KF=10.5e-14
.MODEL my_d D
+ IS=10.000E-18
+ RS=1.0000E-3
+ CJO=1.0000E-12
+ M=.3333
+ VJ=.75
+ ISR=100.00E-12
+ BV=100
+ IBV=100.00E-6
+ TT=5.0000E-9
* source THS3202
Q_Q1 VCC INP1 N00790 NPN_IS 32
R_R7 N03087 VCC 10
D_D2 N031571 N025972 MY_D 64
E_E4 N16469 N16504 0 N16382 1
Q_Q2 VEE INP1 N00761 PNP_IS 64
R_R8 VEE N03033 10
V_V9 N19555 VEE 1.3Vdc
**V_V2 HIZ N02762 -4.3Vdc
Q_Q5 N01212 N01212 A1 PNP_IS 32
L_L3 N03266 OUT 2.1n
V_V8 N19322 VCC -1.3Vdc
R_R21 0 N16008 123
R_R9 N03266 N031180 8.5
*R_R11 0 OUT 100
C_C1 eref HIZ 430f
R_R1 A1 A 200
R_R13 0 N09161 10
C_C6 0 N16008 1p
Q_Q7 N01642 N01642 B1 NPN_IS 32
C_C3 N09161 INN 700f
R_R10 N031571 N03266 8.5
G_G1 INN_int 0 N15578 0 4m
R_R3 B B1 200
C_C2 0 OUT 1p
R_R2 eref HIZ 300k
Q_Q3 N01212 N00761 INN_int NPN_IS 32
V_V7 INP N26257 -17mVdc
X_U6 B VEE HIZ VEE CSWIL PARAMS: IL=3000U
R_R22 N16382 0 1.4k
R_R20 0 N15578 1k
Q_Q4 N01642 N00790 INN_int PNP_IS 64
C_C7 N16382 0 700p
I_I1 VCC N00761 DC 325uAdc
E_E1 N03087 N025673 N02649 eref -1
L_L4 INN INN_int 1.15n
I_I2 N00790 VEE DC 325uAdc
L_L7 N25506 N16504 0.2n
D_D7 N19555 HIZ D_BREAK
E_E2 N025972 N03033 N02762 eref 1
R_R28 N26257 N25506 -49.8u
**V_V1 HIZ N02649 4.3Vdc
D_D1 N025673 N031180 MY_D 64
C_C5 0 N15578 1f
X_U5 VCC A VCC HIZ CSWIL PARAMS: IL=3000U
C_C8 0 N16504 10f
D_D6 HIZ N19322 D_BREAK
E_E3 INP1 N16469 N16008 0 1
E_E101 avg vee vcc vee 0.5
E_E102 eref 0 avg 0 1
E_E103 diff 0 vcc vee 0.5
E_E104 lshift 0 diff ddrop 1
V_V102 ddrop 0 0.7
E_E105 HIZ N02649 lshift 0 1
E_E106 HIZ N02762 lshift 0 -1
.ENDs ths3202
.SUBCKT cswil 1 2 3 4
+ PARAMS:
+ IL = 800u ;
v1 1 2 0
Gout 3 4 value={limit(I(v1),IL,-IL)} ;
.ENDS cswil
Can anyone help me?
  • It looks like your power supplies are hooked up backwards.
    -Luke
  • I've already verified that and the power supplies are ok:
    • pin 7 coneccted to model (vcc) hooked up to +7.5 V
    • pin 4 coneccted to model (vee) hooked up to -7.5 V
    Here a picture of the connections:
    Furthermore, I've tried changing the power supplies and it is still wrong.
  • Sergio,
    Testing the model in TINA, everything looks fine.
    I've attached the simulation file below.
    4278.THS3202 g=2.TSC
    This leads me to believe that something is not connected properly in your circuit.
    If I switch the power supply connections, the amplifier is off and you get a very attenuated signal like you are seeing.
    I would suggest that you verify all of the connections in your schematic, starting with the power supplies. They are listed as +7.5V and -7.5V, but check to make sure.
    Otherwise, TINA-TI is a free tool that we offer available at www.ti.com/tina-ti
    Let me know if this helps.
    Luke Lapointe
    High Speed Amplifiers
  • Hello Luke,
    I've checked all my conections and I've tried the same circuit using another operational model. All seems to be OK except when I execute THS3202 model.
    I've also installed  TINA-TI and the first thing I have notice is that the model in TINA-TI is not the same that I've downloaded from here. This makes me think that this model could be wrong.
    This is the model in TINA-TI:
    *|(C) Copyright Texas Instruments Incorporated 2007. All rights reserved. |
    *|This Model is designed as an aid for customers of Texas Instruments. |
    *|No warranties, either expressed or implied, with respect to this Model |
    *|or its fitness for a particular purpose is claimed by Texas Instruments |
    *|or the author. The Model is licensed solely on an "as is" basis. The |
    *|entire risk as to its quality and performance is with the customer. |
    .MODEL D_break D
    + RS=1.0000E-1
    + CJO=1.0000E-13
    + IS=100e-15
    .MODEL pnp_is PNP
    + IS=10.000E-18
    + BF=124.36
    + VAF=100
    + IKF=.99789
    + ISE=10.000E-18
    + NE=1.3695
    + VAR=100
    + IKR=10.000E-3
    + ISC=10.000E-18
    + NK=1.8752
    + RE=1
    + RB=80
    + RC=10
    + CJE=12.000E-15
    + VJE=.9
    + MJE=.6
    + CJC=10.000E-15
    + MJC=.93
    + TF=8.0237E-12
    + XTF=12.990
    + VTF=12.704
    + ITF=.88449
    + TR=10.000E-9
    + KF=7e-14
    + AF=0.54
    .MODEL npn_is NPN
    + IS=10.000E-18
    + BF=205.81
    + VAF=100
    + IKF=.99979
    + ISE=19.329E-18
    + NE=1.6102
    + VAR=100
    + IKR=20.000E-3
    + ISC=10.000E-18
    + NK=1.8762
    + RE=1
    + RB=100
    + RC=10
    + CJE=16.000E-15
    + VJE=1
    + MJE=.4
    + CJC=1.6000E-15
    + TF=5.5979E-12
    + XTF=97.940
    + VTF=28.359
    + ITF=2.2510
    + TR=10.000E-9
    + AF=0.54
    + KF=10.5e-14
    .MODEL my_d D
    + IS=10.000E-18
    + RS=1.0000E-3
    + CJO=1.0000E-12
    + M=.3333
    + VJ=.75
    + ISR=100.00E-12
    + BV=100
    + IBV=100.00E-6
    + TT=5.0000E-9
    * source ths3202
    R_R7 N03087 VCC 10
    R_R8 VEE N03033 10
    R_R21 0 N16008 123
    *R_R11 0 OUT 100
    C_C1 eref HIZ 430f
    R_R1 A1 A 200
    R_R13 0 N09161 10
    C_C6 0 N16008 1p
    R_R3 B B1 200
    C_C2 0 OUT 1p
    R_R2 eref HIZ 300k
    X_U6 B VEE HIZ VEE A1_3202 PARAMS: IL=3000U
    R_R22 N16382 0 1.4k
    R_R20 0 N15578 1k
    C_C7 N16382 0 700p
    C_C5 0 N15578 1f
    X_U5 VCC A VCC HIZ A1_3202 PARAMS: IL=3000U
    C_C8 0 N16504 10f
    V_V102 ddrop 0 0.7
    .ENDs ths3202
    I've tried to use this model in Altium (I must use altium in this project) but this error appears:
    "Class Document Source Message Time Date No.
    [Error] fast_timing XSpice No such subcircuit: a1_3202 20:25:54 14/05/2013 13"
    In reference at the two variables I've marked above. any ideas?
