Other Parts Discussed in Thread: AFE032
Hi All,
I intend to implement FCC/CENELENC/ARIB using AFE032 DAC mode,
there are couple questions, please kindly helps,
I following sequence to write samples to the DAC as AFE032 recommond
the parameters as following is current status
for FCC/ARIB sample frequency fs is 1.2MHz, then XCLK is 19.2MHz, SCLK is 19.2MHz,
1. set CS is low and Write the first 12-bit word to DIN
2. Set CS high to indicate that the sample is entered and Wait for at least four SCLK cycles
I am follow Table 10 in AFE032 datasheet. get the DAC_CLK is 4.8MHz and bypass block1,2,and 4, includes Block3 only.
does these configure correct setting?
(Q: Shall I set these REG_COEFF1_BLOCK_1/2_MS/LS~REG_COEFF7_BLOCK_1/2_MS/LS when I bypass block1 and 2?)
also for CENELENC sample frequency is 400KHz, then XCLK is 19.2MHz, SCLK is 19.2MHz,
2. Set CS high to indicate that the sample is entered and Wait for at least 32 SCLK cycles
and Digital filter as like FCC/ARIB
the other question, regards to DAC output (pin14)
I have 12bit samples, range [0x800~0x7ff]
I add bias(0x800) on each sample when I send sample through SPI to DAC mode,
I expected DAC out(pin 14) see range [-DAC_NRF~ +DCA_NRF], but Table 4 show it is not.
the last question is XCLK 19.2M Hz is not 50% duty cycle(Hign 46.6% and Low is 53.33%)
does it work fine on AFE032?
Best Regards
Tarzan
