I Need help, i have a project that specify OP AMP LMC6484AIMX this specific model is hard to find near here, i found LMC6484AIN, in datasheet is not cleary what these last letters represent, does anyone know ?
Probably does not exist anymore, in the BOM cross tool I see this
The IMX means industrial temp range (-40C to 85C) the MX means a PDSO14 package, not having the /NOPB means it is not RoHS compliant
The A usually means a tighter offset voltage test, and up above you see on of those at 1350uV in this search, vs 3000uV for non
If I hit view on the LMC6484AIMX line, actually there is stock for the NOBP with another part suggested suggested as well, Not sure how accurate this tool is.
Thank You, You answered my question and now i learn use BOM and cross reference tool
A-> VOS (offset voltage) @25C (Max): 1350 uV
without A -> VOS (offset voltage) @25C (Max):750 uV or other values
I -> is the letter to common temperature industrial
M or MX - > is to package/pins SOIC
N -> is to package/pins PDIP
Thank you again
