I'm trying to build a 100kHz sine-to-square converter by implementing zero crossing detector circuit using comparator.
I used following circuit in LM311 manual
I get the following response:
I also tried this circuit
and I get this response:
Both circuit are recommended in TI manual: http://www.ti.com/lit/ds/symlink/lm311-n.pdf
I can understand that LM311 is slow and it has long propagation delay. But I don't understand where does the asymmetry come into play. Is there a mistake in the circuit? I'm using +/-5V supply voltage, except for the -10V in the first circuit as indicated on the drawing.
Thank you very much for input and help. I really appreciate it.
Charles
