Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
I have a doubt of a charge amplifier with a piezoelectric sensor
Hello all,
I have a question about the charge amplifier with a piezoelectric sensor as shown above.
The first image shows a piezoelectric sensor and its equivalent circuit and the second one shows the charge amplifier with the sensor.
Since piezoelectric sensors have a very high impedance, Rp, the amplifier should have a very high input impedance in a voltage mode. Otherwise, the amplifier should have a very low input impedance in a charge mode to feed all the charge from the sensor to the feedback capacitor.
However, if I put a resistor, Ri, as shown above, is it fine?
I think the input signal to the amplifier will be dropped due to the Ri, but a TI application note (SLOA033A) shows the circuit.
I wonder how the circuit works with a piezoelectric sensor having very high impedance.
