Other Parts Discussed in Thread: TL074
What is TL074's output resistance?
Hello Ron,
Just wanted to make sure. Is it correct to say the maximum op-amp output voltage is only determined by the op-amp output resistance and load resistance?
Just for my reference, I included the equations and Ro solution (almost same as yours with correction of the sign)
Stephen
(Vx-Vo1)/Ro = IL1
(Vx-Vo2)/Ro = IL2
Then,
Ro = (Vo1-Vo2)/(IL2-IL1)
Steven,
I used two real points where I knew output voltage and current (via load resistance).
This current flows through the output resistance and any fixed offset (headroom)
Two points allows getting the resistance without the fixed offset.
