Other Parts Discussed in Thread: LM311
Hi All,
what is the difference between this two component?
The same circuit work fine with the LM311N but when I use the LM311P it doesn't work.
Hi All,
Antonio,
Two different die designs. Created by two separate companies. Both device work, if design does not violate some specification.
C1 can push pin 2 out of the valid common mode range. It can make pin 2 peak above VCC and below ground. Most concerning is below ground.
Try removing C1; does that help?
Antonio,
I suspect LM311P does not have a parasitic diode from input to GND pin and LM311N does have a diode.
Antonio,
It makes sense that both have diodes. However the -2.987V peak pulse that was observed means the diode is being over-stressed.
You have at least two choice , keep the capacitor out or use the LM311 that seem to ignore the transient.
If you would like to try something else. Sweep pin 2 from 0V to -0.8V and see if if the output goes high. If it does, that is called phase reversal.
