Other Parts Discussed in Thread: DRV134, , OPA1678, OPA1679
Hi TI,
Audio Codec L, R Output The DRV135UA (6dB AMP) is attached to each line to configure the circuit to perform Single Ended output.
On the datasheet, only DRV134 is shown for Single Ended output.
DRV135 also check if there is no problem with Single Ended output and if there is no problem with the circuit configuration given below.
Thank you.
