Part Number: INA217
Hello sir,
We are using INA217AIDWT pre-amplifier for converting XLR differential audio input to single endded output
Pre-amplifier single ended output given to Audio codec (PCM2900CDB ) through Active Low Pass filter (using OP-AMP: OPA2353UA ).
We are giving input power supply +5V to this board through USB adapter.
We are generating -5V supply using Charge pump regulator IC ( LTC1046IS8#PBF ).
+5V & -5V given to the Pre-amp ( INA217 ) section.
Last time we did this project by using two layer PCB.
I can't able hear clear audio because of hum noise present in the audio signal.
I done some experiment to find the Noise source.
Hum noise gets cancelled when I am shorting XLR differential inputs together.
Hum noise gets cancelled When I connect Pre amplifier ( INA217 ) output to ground.
We plan to go next revision of this project.
So please give me your suggestion to proceed further.
Hereby attached this Audio Codec Schematic for your reference.
Lakshmanan V
