Part Number: LM358
The customer wants to know how far bypass capacitor can be apart form IC. Would you advice it?
Toshihiro Watababe
Part Number: LM358
Toshihiro Watababe
Hi Toshihiro,
consider the decoupling cap as part of the chip. As Paul already mentioned, the decoupling cap should sit directly at the supply pin. It's best to have the other side of decoupling capacitor being connected to a solid ground plane, to which the supply ground and signal ground of LM328 is connected, too.
Of course, it depends on the actual application and chip how important it is to have the decoupling cap sitting next to the chip. Some applications have a single decoupling cap for a group of amplifiers and work satisfactorily. Others need sophisticated parallel combinations of several decoupling caps at each chip to make the circuit work. But why taking the risk of having the decoupling cap too far away from the chip? Just place it always close to the chip and everything is fine.
A standard decoupling capacitance of 100nF for each chip and supply line is sufficient for the very most cases.
Kai
