Part Number: LMP7721
Hi all:
I have found another phenomenon by Oscilloscope on vout (LMP7721's PIN4) as following ,there is no input on PH+.
Would you please tell me why? how to resolved it ? And the frequency is 50HZ.Probe.pdf
James,
You mentioned in the write-up LMP7721 but your schematic only shows LMP7221 - so what is it?
I am not sure what issue you describe. If you float the input, the input will slowly move over time towards one of its rails and thus the output will follow. This may lead to saturation of the output stage leading to back-and forth tripping of the input stage just like in the case of a comparator.
In order for the input stage to work properly, there must be a current path for the input current flow to system ground or the input will collapse on its rail. Thus, the way to resolve the issue is not to float the input.
