Part Number: INA240
i'm using INA240 for High-Side current measurement (DC-Supply Current, no PWM).
The Devices will be factory Calibrated, but i found, that the Offset of the INA240 can change.
A: I found the behavior, that the Offset, which is in the Range of the datasheet, is stable after Power up the 3.3V Supply and didn't change until the next Power up.
b: I also found, that the Offset more or less change between two different Values.
My Question is: can i rely on the Facts i found, or can the Offset (Assuming constant Temperature and environmental state) change arbitarily, even after Power up?
regards,
Chris
