Part Number: OPA564
Hi Team,
One quick question, when device is NOT ENABLE, what will be the I-Flag and T-Flag status?
Thanks a lot!
Andrew
Part Number: OPA564
Hi Team,
Thanks a lot!
Andrew
Hi Andrew,
Question:
When the E/S pin is pulled low the OPA564 goes into shutdown mode. Yes. When the OPA564 E/S pin is pulled low and the amplifier goes into shutdown mode the IFLAG is active high, even though the output is shutdown and unable to supply current.
OPA564 is CMOS process. The IFLAG and TFLAG should behave similarly; and both pins in OPA564 should be in high impedance states when shutdown mode is occurred.
There is another similar inquiry in E2E, please take a look, if you are intersted.
https://e2e.ti.com/support/amplifiers/f/14/t/730558?tisearch=e2e-sitesearch&keymatch=opa564
Raymond
