Other Parts Discussed in Thread: TLV2760, LM2904
May i know the Difference between Supply Current IDD and Is that is in DataSheet. And it is belonging for single Channel or Device.
Hi Prasath
What part are you needing info on?
Hello Chris,
In the DataSheet of TLV2760 Part i found IDD. Is it refering Current at Shutdown mode?
Usualy what symbol is used in texas to mention Supply Current (operating) and Supply Current (Shutdown mode).
As i need both current, where can i get it if it is not in DataSheet.
May i know whether the Die Size is Common for all parts of same Package and same pin count.
Prasath,
Op-amp with shutdown will always have two IDD (ICC or Is) specifications. Sometimes they are both in the same section of the data sheet parameters and sometimes the shutdown IDD will be in the shutdown section of the data sheet parameters.
Hello Mr. Ron Michallick,
Thank you for your reply
In the Part LM2904 MWC MCD0950A, may i know what MWC MCD0950A represents to?. Shall i take the Die Size in the link http://www.ti.com/lit/ml/snao363/snao363.pdf for LM2904M part number. And in the same link i found 244µm as Mini pitch. Does it refer the minimum length of a transistor in IC.
May i know whether the Die Size is Common for the parts having same Package and same pin count. (irrespect of family and Process). Please correct me.
Prasath,
I am not familiar with SVA die sales. I suggest starting a new thread with LM2904M part number in the post subject.
Die sizes can vary significantly. The package only limits the maximum die size.
