Could you clarify the ordering options for this die?
I would like to use the die in a application where AlSi wire bonding would be used. Is it possible to receive the die for this process, or are all die metallised for use with Flip-chip processing?
Hi Dave,
It took some searching to find the answer to your question regarding the OPA170-DIE because die are processed by a different TI group. The OPA170-DIE bond-pad is AlCu over TiN barrier metal. It is suitable for conventional wirebonding. The metal, as is, isn't intended to be used for flip-chip processes.
Regards, Thomas
PA - Linear Applications Engineering
