Part Number: AMC1200EVM
Other Parts Discussed in Thread: AMC1200, TIPD104
Hi, I want to measure a current from a high voltage isolated power supply (3000 volts, with ground is different (isolated) from circuit ground), The current measurement ranges from 1 microamps to 1000 microamps with a resolution of 1 microamps. I would like to measure the current either from low side or by measuring the differential voltage across a shunt resistor (1k ohm). Please let me know if i can use AMC1200EVM board to measure current or differential voltage (1 milivolts to 1 volts ). If not, please let me know the solution for measuring the current from isolated high voltage supply.
Regards.
Ismail
