Other Parts Discussed in Thread: LM2903B, LM358B, LM2904B
What is the most efficient solution to compare the voltages of two batteries ( voltage range of each battery: 40-62Volt)
and when there is a voltage difference greater than 3Volt between the two battery voltages-> get an output signal, capable of energizing a relay( 5-10Volts) .
Example: VoltageBatteryA = 50V and VoltageBatteryB = 54V OR VoltageBatteryA = 55V and VoltageBatteryB = 51V
