Part Number: OPA2388
Other Parts Discussed in Thread: OPA2336, OPA336, OPA2387
We recently received 5 samples of the OPA2388 to test. We currently use the opa2336 and we're looking for an opamp with a lower offset voltage. We compared the OPA2336 to the new OPA2388 and the measured offset voltage is 110uV (2336) and 240uV (2388) which does not match the spec.
The input is 0 to +50mV with a gain of around 11, power is single supply 5VDC.
The samples are marked with date code P13ZG3
Packaging says lot code is 0750185ASH
Thank you
