Hello Champs,
I aware the BOOT and AVS voltage is specified on TDA3x datasheet.
In case of VD_CORE, the BOOT voltage is between min. 1.11V ~ max 1.20V in case of OPP_NOM.
But I found VISION_SDK_02_09_01_00(I know 2.10 is latest but..) TDA3x SBL is defined the BOOT voltage as 1.03V.
So, could you please check and let me know if VD_CORE and VD_EVE is working under 1.11V at BOOT? (ie, 1.03V, 1.06V respectively)
https://e2e.ti.com/support/arm/automotive_processors/f/1021/t/557479
This request is to check 2xLP873x and its 2xDCDC default output values are applicable on my customer's TDA3x application as discussed above e2e thread.
Ernest Cho
