Other Parts Discussed in Thread: TLK105L, TLK110
Hi
We are using AM335x and AM371x now.
We'll seriously consider AM437x to our next product.
Could you please let us know about below questions?
1. AM437x's EMAC and AM335x's EMAC same IP? It seem both register is almost same.
2. And if the same, for the customers who are using the Ether in AM335X.
Would you please put me in touch with the some of the actual use TI's PHY?
EVM's Reference is other maker's chip on board.
(Small package, GbitEther correspondence is nice to have.)
ex:www.ti.com/.../dp83865
3. Although in portable products will form is realized by providing a LAN connector in the cradle.
If it is two of the configuration of the following, what easy Which is realized?
・Ether PHY is placed in the cradle side, to be connected to the terminal side of the AM437X.
・the Ether PHY is placed on the terminal side, to connect the LAN signal directly to the cradle side of the LAN connector.
If there is such use results in portable products Would you please advise it as a reference.
