Linux/AM5728: PCIe issue
Part Number: AM5728
Tool/software: Linux
Hi.
I'm using AM572x custom board.
problem:
Arm kernel in PCIe Init process after DSP startup This error appears.
And this kernel error will not always occur.
The following file is the ARM Kernel error log.
6114.PCIe-ARM Kernel Err.txt
and, this is normal log file.
omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arch_sys_counter
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 5, 229376 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 3, 32768 bytes)
UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
NET: Registered protocol family 1
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
squashfs: version 4.0 (2009/01/31) Phillip Lougher
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
ntfs: driver 2.1.32 [Flags: R/O].
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
bounce: pool size: 64 pages
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
PCI host bridge /ocp/axi@0/pcie@51000000 ranges:
  No bus range found for /ocp/axi@0/pcie@51000000, using [bus 00-ff]
   IO 0x20003000..0x20012fff -> 0x00000000
  MEM 0x20013000..0x2fffffff -> 0x20013000
dra7-pcie 51000000.pcie: link is not up
dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [bus 00-ff]
pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
PCI: bus0: Fast back to back transfers disabled
PCI: bus1: Fast back to back transfers enabled
irq: no irq domain found for /ocp/axi@0/pcie@51000000/interrupt-controller !
pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
pci 0000:00:00.0: PCI bridge to [bus 01]
pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 301, base_baud = 3000000) is a 8250
console [ttyS1] enabled
48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 302, base_baud = 3000000) is a 8250
[drm] Initialized drm 1.1.0 20060810
ldoln: supplied by VMAIN
OMAP DSS rev 6.1
omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops)
loop: module loaded
m25p80 spi32766.0: s25fl256s1 (32768 Kbytes)
8 ofpart partitions found on MTD device spi32766.0
Creating 8 MTD partitions on "spi32766.0":
0x000000000000-0x000000040000 : "QSPI.SPL"
0x000000040000-0x000000140000 : "QSPI.u-boot"
0x000000140000-0x000000180000 : "QSPI.env"
0x000000180000-0x0000001c0000 : "QSPI.dtb"
0x0000001c0000-0x0000005c0000 : "QSPI.kernel"
0x0000005c0000-0x0000014c0000 : "QSPI.app"
0x0000014c0000-0x0000019c0000 : "QSPI.db"
0x0000019c0000-0x000001ec0000 : "QSPI.testprg"
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
libphy: Fixed MDIO Bus: probed
CAN device driver interface
c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=358)
e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
e1000: Copyright (c) 1999-2006 Intel Corporation.
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
davinci_mdio 48485000.mdio: davinci mdio revision 1.6
davinci_mdio 48485000.mdio: detected phy mask fffffffe
libphy: 48485000.mdio: probed
davinci_mdio 48485000.mdio: phy[0]: device 48485000.mdio:00, driver Micrel KSZ9031 Gigabit PHY
cpsw 48484000.ethernet: Detected MACID = fc:0f:4b:e4:42:ee
cpsw 48484000.ethernet: cpsw: Random MACID = 8a:df:46:59:2d:c1
mousedev: PS/2 mouse device common for all mice
omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc2
palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: registered 48070000.i2c:tps659 as rtc1
i2c /dev entries driver
omap_hsmmc 4809c000.mmc: Got CD GPIO
smps9: supplied by VMAIN
V3_3D: supplied by smps9
ldo1: supplied by VMAIN
omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Key type dns_resolver registered
omap_voltage_late_init: Voltage driver support not added
Power Management for TI OMAP4+ devices.
Registering SWP/SWPB emulation handler
dmm 4e000000.dmm: initialized all PAT entries
ldo3: supplied by VMAIN
[drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[drm] No driver support for vblank timestamp query.
mmc1: MAN_BKOPS_EN bit is not set
mmc1: new DDR MMC card at address 0001
mmcblk0: mmc1:0001 R1J56L 13.8 GiB
mmcblk0boot0: mmc1:0001 R1J56L partition 1 16.0 MiB
mmcblk0boot1: mmc1:0001 R1J56L partition 2 16.0 MiB
 mmcblk0: p1
[drm] Enabling DMM ywrap scrolling
Console: switching to colour frame buffer device 240x67
omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[drm] Initialized omapdrm 1.0.0 20110917 on minor 0
hctosys: unable to open rtc device (rtc0)
ALSA device list:
  No soundcards found.
EXT4-fs (mmcblk0p1): recovery complete
EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:1.
devtmpfs: mounted
Freeing unused kernel memory: 348K (c093f000 - c0996000)
systemd[1]: System time before build time, advancing clock.
random: systemd: uninitialized urandom read (16 bytes read, 16 bits of entropy available)
systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
systemd[1]: Detected architecture arm.
Welcome to Arago 2016.08!
systemd[1]: Set hostname to <am57xx-evm>.
random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available)
systemd[1]: sockets.target: Found ordering cycle on sockets.target/start
systemd[1]: sockets.target: Found dependency on rpcbind.socket/start
systemd[1]: sockets.target: Found dependency on sysinit.target/start
systemd[1]: sockets.target: Found dependency on alignment.service/start
systemd[1]: sockets.target: Found dependency on basic.target/start
systemd[1]: sockets.target: Found dependency on sockets.target/start
systemd[1]: sockets.target: Breaking ordering cycle by deleting job rpcbind.socket/start
systemd[1]: rpcbind.socket: Job rpcbind.socket/start deleted to break ordering cycle starting with sockets.target/start
[ SKIP ] Ordering cycle found, skipping RPCbind Server Activation Socket
systemd[1]: basic.target: Found ordering cycle on basic.target/start
systemd[1]: basic.target: Found dependency on sysinit.target/start
systemd[1]: basic.target: Found dependency on alignment.service/start
systemd[1]: basic.target: Found dependency on basic.target/start
systemd[1]: basic.target: Breaking ordering cycle by deleting job alignment.service/start
systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with basic.target/start
[ SKIP ] Ordering cycle found, skipping alignment.service
systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
systemd[1]: Created slice System Slice.
[  OK  ] Created slice System Slice.
systemd[1]: Starting Setup Virtual Console...
systemd[1]: Mounting Temporary Directory...
systemd[1]: Starting Create list of required static device nodes for the current kernel...
         Starting Create list of required st... nodes for the current kernel...
systemd[1]: Mounting Debug File System...
systemd[1]: Starting Load Kernel Modules...
CMEMK module: reference Linux version 4.4.19
allocated heap buffer 0x40500000 of size 0x100000
cemk initialized
systemd[1]: Starting Remount Root and Kernel File Systems...
cryptodev: driver 1.8 loaded.
EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
systemd[1]: Mounting POSIX Message Queue File System...
systemd[1]: Starting Journal Service...
systemd[1]: Mounted Debug File System.
[  OK  ] Mounted Debug File System.
systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
systemd[1]: Mounted Temporary Directory.
[  OK  ] Mounted Temporary Directory.
systemd[1]: Started Setup Virtual Console.
[  OK  ] Started Setup Virtual Console.
systemd[1]: Started Create list of required static device nodes for the current kernel.
[  OK  ] Started Create list of required sta...ce nodes for the current kernel.
systemd[1]: Started Load Kernel Modules.
[  OK  ] Started Load Kernel Modules.
systemd[1]: Started Remount Root and Kernel File Systems.
[  OK  ] Started Remount Root and Kernel File Systems.
systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
         Starting udev Coldplug all Devices...
         Starting Flush Journal to Persistent Storage...
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
systemd-journald[222]: Received request to flush runtime journal from PID 1
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /var/volatile...
         Mounting /media/ram...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
[  OK  ] Started udev Kernel Device Manager.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Load/Save Random Seed.
omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@95800000
 remoteproc0: 58820000.ipu is available
 remoteproc0: Note: remoteproc is still under development and considered experimental.
 remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@97800000
 remoteproc1: 55020000.ipu is available
 remoteproc1: Note: remoteproc is still under development and considered experimental.
 remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99800000
 remoteproc2: 40800000.dsp is available
 remoteproc2: Note: remoteproc is still under development and considered experimental.
 remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9b800000
[  OK  ] Started Create Volatile Files and Directories. remoteproc3: 41000000.dsp is available
 remoteproc3: Note: remoteproc is still under development and considered experimental.
 remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
 remoteproc0: registered virtio0 (type 7)
 remoteproc2: Direct firmware load for dra7-dsp1-fw.xe66 failed with error -2
 remoteproc2: failed to load dra7-dsp1-fw.xe66
 remoteproc1: registered virtio1 (type 7)
 remoteproc3: registered virtio2 (type 7)
         Starting Network Time Synchronization...
omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
alg: skcipher: setkey failed on test 5 for ecb-des-omap: flags=100
alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
         Starting Update UTMP about System Boot/Shutdown...ov2659: Unknown symbol v4l2_of_alloc_parse_endpoint (err 0)
omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
ov2659: Unknown symbol v4l2_i2c_subdev_init (err 0)
ov2659: Unknown symbol v4l2_async_unregister_subdev (err 0)
ov2659: Unknown symbol v4l2_ctrl_handler_init_class (err 0)
ov2659: Unknown symbol v4l2_event_subdev_unsubscribe (err 0)
ov2659: Unknown symbol v4l2_of_free_endpoint (err 0)
ov2659: Unknown symbol media_entity_init (err 0)
ov2659: Unknown symbol __v4l2_ctrl_s_ctrl_int64 (err 0)
ov2659: Unknown symbol v4l2_ctrl_subdev_subscribe_event (err 0)
ov2659: Unknown symbol media_entity_cleanup (err 0)
ov2659: Unknown symbol v4l2_ctrl_subdev_log_status (err 0)
ov2659: Unknown symbol v4l2_ctrl_new_std (err 0)
ov2659: Unknown symbol v4l2_ctrl_handler_free (err 0)
ov2659: Unknown symbol v4l2_ctrl_new_std_menu_items (err 0)
ov2659: Unknown symbol v4l2_async_register_subdev (err 0)
Error: Driver 'palmas-rtc' is already registered, aborting...
[  OK  ] Started Network Time Synchronization.
rtc-ds1307: probe of 4-0068 failed with error -5
[  OK  ] Started udev Coldplug all Devices.
Error: Driver 'omap_rtc' is already registered, aborting...
[  OK  ] Found device /dev/ttyS1.
ti_vpe: Unknown symbol v4l2_m2m_init (err 0)
ti_vpe: Unknown symbol vb2_queue_init (err 0)
ti_vpe: Unknown symbol v4l2_fh_exit (err 0)
ti_vpe: Unknown symbol v4l2_m2m_job_finish (err 0)
ti_vpe: Unknown symbol video_ioctl2 (err 0)
ti_vpe: Unknown symbol v4l2_m2m_next_buf (err 0)
ti_vpe: Unknown symbol v4l2_fh_del (err 0)
ti_vpe: Unknown symbol v4l2_m2m_ctx_release (err 0)
ti_vpe: Unknown symbol v4l2_fh_add (err 0)
ti_vpe: Unknown symbol vb2_ops_wait_finish (err 0)
SCSI subsystem initialized
ti_vpe: Unknown symbol v4l2_m2m_buf_remove (err 0)
libata: Unknown symbol glob_match (err 0)
[  OK  ] Started Update UTMP about System Boot/Shutdown.
ti_vpe: Unknown symbol v4l2_ctrl_handler_init_class (err 0)
ti_vpe: Unknown symbol vb2_dma_contig_memops (err 0)
ti_vpe: Unknown symbol v4l2_m2m_ioctl_expbuf (err 0)
ti_vpe: Unknown symbol v4l2_m2m_ioctl_querybuf (err 0)
ti_vpe: Unknown symbol v4l2_ctrl_handler_setup (err 0)
ti_vpe: Unknown symbol v4l2_m2m_buf_queue (err 0)
ti_vpe: Unknown symbol video_devdata (err 0)
ti_vpe: Unknown symbol v4l2_m2m_get_curr_priv (err 0)
ti_vpe: Unknown symbol v4l2_m2m_fop_poll (err 0)
ti_vpe: Unknown symbol v4l2_m2m_ioctl_qbuf (err 0)
ti_vpe: Unknown symbol v4l_bound_align_image (err 0)
ti_vpe: Unknown symbol v4l2_m2m_get_vq (err 0)
ti_vpe: Unknown symbol vb2_plane_cookie (err 0)
ti_vpe: Unknown symbol v4l2_ctrl_new_custom (err 0)
ti_vpe: Unknown symbol vb2_buffer_done (err 0)
ti_vpe: Unknown symbol v4l2_ctrl_subscribe_event (err 0)
[  OK  ] Reached target System Time Synchronized.ti_vpe: Unknown symbol v4l2_fh_init (err 0)
ti_vpe: Unknown symbol v4l2_m2m_ioctl_reqbufs (err 0)
ti_vpe: Unknown symbol vb2_dma_contig_cleanup_ctx (err 0)
ti_vpe: Unknown symbol video_unregister_device (err 0)
ti_vpe: Unknown symbol v4l2_m2m_ioctl_streamoff (err 0)
ti_vpe: Unknown symbol v4l2_device_register (err 0)
         Starting Synchronize System and HW clocks...ti_vpe: Unknown symbol v4l2_m2m_ioctl_streamon (err 0)
ti_vpe: Unknown symbol v4l2_m2m_fop_mmap (err 0)
omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
can_dev: exports duplicate symbol alloc_can_err_skb (owned by kernel)
ti-pruss 4b200000.pruss: creating PRU cores and other child platform devices
irq: no irq domain found for /ocp/pruss@4b200000/intc@4b220000 !
davinci_mdio 4b232400.mdio: davinci mdio revision 1.6
libphy: 4b232400.mdio: probed
davinci_mdio 4b232400.mdio: phy[0]: device 4b232400.mdio:00, driver TI DP83849 10/100 Mbps PHY
davinci_mdio 4b232400.mdio: phy[1]: device 4b232400.mdio:01, driver TI DP83849 10/100 Mbps PHY
omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
ti_vpe: Unknown symbol __video_register_device (err 0)
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
ti_vpe: Unknown symbol v4l2_m2m_release (err 0)
ti_vpe: Unknown symbol vb2_ops_wait_prepare (err 0)
ti_vpe: Unknown symbol v4l2_ctrl_handler_free (err 0)
ti_vpe: Unknown symbol v4l2_device_unregister (err 0)
ti_vpe: Unknown symbol v4l2_m2m_ctx_init (err 0)
ti_vpe: Unknown symbol video_device_release_empty (err 0)
ti_vpe: Unknown symbol vb2_dma_contig_init_ctx (err 0)
ti_vpe: Unknown symbol v4l2_m2m_ioctl_dqbuf (err 0)
ti_vpe: Unknown symbol v4l2_event_unsubscribe (err 0)
ti_vip: Unknown symbol vb2_queue_init (err 0)
ti_vip: Unknown symbol video_ioctl2 (err 0)
ti_vip: Unknown symbol v4l2_get_timestamp (err 0)
ti_vip: Unknown symbol v4l2_async_notifier_unregister (err 0)
ti_vip: Unknown symbol vb2_ioctl_streamoff (err 0)
ti_vip: Unknown symbol vb2_ioctl_expbuf (err 0)
ti_vip: Unknown symbol vb2_ops_wait_finish (err 0)
ti_vip: Unknown symbol v4l2_ctrl_handler_init_class (err 0)
ti_vip: Unknown symbol vb2_dma_contig_memops (err 0)
ti_vip: Unknown symbol vb2_ioctl_querybuf (err 0)
ti_vip: Unknown symbol v4l2_fh_open (err 0)
ti_vip: Unknown symbol video_devdata (err 0)
ti_vip: Unknown symbol v4l_bound_align_image (err 0)
ti_vip: Unknown symbol vb2_plane_cookie (err 0)
ti_vip: Unknown symbol vb2_ioctl_dqbuf (err 0)
ti_vip: Unknown symbol vb2_ioctl_create_bufs (err 0)
ti_vip: Unknown symbol vb2_ioctl_prepare_buf (err 0)
ti_vip: Unknown symbol v4l2_fh_is_singular (err 0)
ti_vip: Unknown symbol vb2_buffer_done (err 0)
ti_vip: Unknown symbol v4l2_async_notifier_register (err 0)
ti_vip: Unknown symbol v4l2_ctrl_subscribe_event (err 0)
ti_vip: Unknown symbol vb2_dma_contig_cleanup_ctx (err 0)
ti_vip: Unknown symbol video_unregister_device (err 0)
ti_vip: Unknown symbol vb2_ioctl_qbuf (err 0)
ti_vip: Unknown symbol vb2_fop_mmap (err 0)
ti_vip: Unknown symbol video_device_alloc (err 0)
ti_vip: Unknown symbol v4l2_of_parse_endpoint (err 0)
ti_vip: Unknown symbol vb2_fop_read (err 0)
ti_vip: Unknown symbol v4l2_device_register (err 0)
ti_vip: Unknown symbol __video_register_device (err 0)
ti_vip: Unknown symbol vb2_ops_wait_prepare (err 0)
ti_vip: Unknown symbol vb2_ioctl_streamon (err 0)
ti_vip: Unknown symbol vb2_fop_poll (err 0)
ti_vip: Unknown symbol v4l2_device_unregister (err 0)
ti_vip: Unknown symbol video_device_release (err 0)
ti_vip: Unknown symbol v4l2_ctrl_log_status (err 0)
ti_vip: Unknown symbol _vb2_fop_release (err 0)
ti_vip: Unknown symbol vb2_dma_contig_init_ctx (err 0)
ti_vip: Unknown symbol v4l2_event_unsubscribe (err 0)
ti_vip: Unknown symbol vb2_ioctl_reqbufs (err 0)
omap-hdmi-audio omap-hdmi-audio.0.auto: snd-soc-dummy-dai <-> 58040000.encoder mapping ok
omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
ti-pruss 4b280000.pruss: creating PRU cores and other child platform devices
davinci_mdio 4b2b2400.mdio: davinci mdio revision 1.6
libphy: 4b2b2400.mdio: probed
davinci_mdio 4b2b2400.mdio: phy[0]: device 4b2b2400.mdio:00, driver TI TLK10X 10/100 Mbps PHY
davinci_mdio 4b2b2400.mdio: phy[1]: device 4b2b2400.mdio:01, driver TI TLK10X 10/100 Mbps PHY
 remoteproc4: 4b234000.pru0 is available
 remoteproc4: Note: remoteproc is still under development and considered experimental.
 remoteproc4: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
 remoteproc4: registered virtio3 (type 7)
pru-rproc 4b234000.pru0: PRU rproc node /ocp/pruss@4b200000/pru0@4b234000 probed successfully
 remoteproc5: 4b238000.pru1 is available
 remoteproc5: Note: remoteproc is still under development and considered experimental.
 remoteproc5: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
 remoteproc5: registered virtio4 (type 7)
pru-rproc 4b238000.pru1: PRU rproc node /ocp/pruss@4b200000/pru1@4b238000 probed successfully
 remoteproc6: 4b2b4000.pru0 is available
 remoteproc6: Note: remoteproc is still under development and considered experimental.
 remoteproc6: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
pru-rproc 4b2b4000.pru0: PRU rproc node /ocp/pruss@4b280000/pru0@4b2b4000 probed successfully
 remoteproc7: 4b2b8000.pru1 is available
 remoteproc7: Note: remoteproc is still under development and considered experimental.
 remoteproc7: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
pru-rproc 4b2b8000.pru1: PRU rproc node /ocp/pruss@4b280000/pru1@4b2b8000 probed successfully
prueth pruss1_eth: port 1: using random MAC addr: 62:75:b6:ef:59:5a
[drm] Initialized pvr 1.14.3699939 20110701 on minor 1
omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
==== dp83848_ack_interrupt 135===
BMCR(0x0): 0x2100
BMSR(0x1): 0x7849
BMSR(0x1): 0x7849
PHYIDR1(0x2): 0x2000
PHYIDR2(0x3): 0x5ca2
CR1(0x9): 0x0
CR2(0xa): 0x0
FLDSTS(0xF): 0x0
PHYSTS(0x10): 0x4
PHYSCR(0x11): 0x0
RCSR(0x17): 0x1
LEDCR(0x18): 0x0
PHYCR(0x19): 0x21
GENCFG(0x465): 0x0
prueth pruss1_eth: port 2: using random MAC addr: 36:62:00:72:e6:5d
BMCR(0x0): 0x2100
BMSR(0x1): 0x7849
BMSR(0x1): 0x7849
CR1(0x9): 0x0
CR2(0xa): 0x0
FLDSTS(0xF): 0x0
PHYSTS(0x10): 0x4
PHYSCR(0x11): 0x0
RCSR(0x17): 0x1
LEDCR(0x18): 0x0
PHYCR(0x19): 0x20
GENCFG(0x465): 0x0
prueth pruss1_eth: TI PRU ethernet driver initialized
prueth pruss2_eth: port 1: using random MAC addr: 02:3e:6c:42:a4:e5
==== PHY regs ===
BMCR(0x0): 0x3100
BMSR(0x1): 0x7849
BMSR(0x1): 0x7849
PHYIDR2(0x3): 0xa212
CR1(0x9): 0x7c00
CR2(0xa): 0x104
PHYSCR(0x11): 0x108
RCSR(0x17): 0x41
LEDCR(0x18): 0x400
PHYCR(0x19): 0x8020
BMCR(0x0): 0x3100
BMSR(0x1): 0x7849
BMSR(0x1): 0x7849
CR1(0x9): 0x7c00
CR2(0xa): 0x104
FLDSTS(0xF): 0x0
PHYSTS(0x10): 0x4002
PHYSCR(0x11): 0x108
RCSR(0x17): 0x41
LEDCR(0x18): 0x400
PHYCR(0x19): 0x8020
GENCFG(0x465): 0x0
prueth pruss2_eth: port 2: using random MAC addr: a2:1e:f1:8a:e8:33
==== PHY regs ===
BMCR(0x0): 0x3100
BMSR(0x1): 0x7849
BMSR(0x1): 0x7849
CR1(0x9): 0x7c00
CR2(0xa): 0x104
PHYSCR(0x11): 0x108
RCSR(0x17): 0x61
LEDCR(0x18): 0x400
PHYCR(0x19): 0x8021
BMCR(0x0): 0x3100
BMSR(0x1): 0x7849
BMSR(0x1): 0x7849
CR1(0x9): 0x7c00
CR2(0xa): 0x104
FLDSTS(0xF): 0x0
PHYSCR(0x11): 0x108
RCSR(0x17): 0x41
LEDCR(0x18): 0x400
PHYCR(0x19): 0x8021
GENCFG(0x465): 0x0
[  OK  ] Reached target System Initialization.
prueth pruss2_eth: TI PRU ethernet driver initialized
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
 remoteproc0: powering up 58820000.ipu
 remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 4963044
[  OK  ] Listening on D-Bus System Message Bus Socket.omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[  OK  ] Reached target Sockets.
 remoteproc0: remote processor 58820000.ipu is now up
virtio_rpmsg_bus virtio0: rpmsg host is online
[  OK  ] Reached target Basic System. remoteproc1: powering up 55020000.ipu
 remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3497356
omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
omap-rproc 55020000.ipu: dma_alloc_coherent err: 45088768
 remoteproc1: Failed to process resources: -12
 remoteproc1: rproc_boot() failed -12
virtio_rpmsg_bus: probe of virtio1 failed with error -12
 remoteproc3: powering up 41000000.dsp
         Starting uim-sysfs.service...
 remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 22081496
omap_hwmod: mmu0_dsp2: _wait_target_disable failed
omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[  OK  ] Started Kernel Logging Service. remoteproc3: remote processor 41000000.dsp is now up
virtio_rpmsg_bus virtio2: rpmsg host is online
 remoteproc4: powering up 4b234000.pru0
 remoteproc4: Booting fw image am57xx-pru1_0-fw, size 75856
ti-pruss 4b200000.pruss: configured system_events = 0x0000000000030000 intr_channels = 0x00000005 host_intr = 0x00000005
 remoteproc4: remote processor 4b234000.pru0 is now up
virtio_rpmsg_bus virtio3: rpmsg host is online
virtio_rpmsg_bus virtio3: creating channel rpmsg-pru addr 0x1e
 remoteproc5: powering up 4b238000.pru1
 remoteproc5: Booting fw image am57xx-pru1_1-fw, size 75856
ti-pruss 4b200000.pruss: configured system_events = 0x00000000000c0000 intr_channels = 0x0000000a host_intr = 0x0000000a
 remoteproc5: remote processor 4b238000.pru1 is now up
virtio_rpmsg_bus virtio4: rpmsg host is online
virtio_rpmsg_bus virtio4: creating channel rpmsg-pru addr 0x1f
         Starting Telephony service...
         Starting Save/Restore Sound Card State...
         Starting Permit User Sessions...
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Print notice about GPLv3 packages...
[  OK  ] Started System Logging Service.
[  OK  ] Started sootoo23 scripts.
udc_core: Unknown symbol usb_speed_string (err 0)
udc_core: Unknown symbol usb_otg_register_gadget (err 0)
udc_core: Unknown symbol usb_otg_unregister_gadget (err 0)
udc_core: Unknown symbol usb_state_string (err 0)
c_can_platform 4ae3c000.can can0: setting BTR=4d00 BRPE=0000
         Starting Login Service...
net eth0: initializing cpsw version 1.15 (0)
net eth0: initialized cpsw ale version 1.4
net eth0: ALE Table size 1024
net eth0: phy found : id is : 0x221622
[  OK  ] Started D-Bus System Message Bus.
sootoo23-InitScript.sh[863]: route: SIOCADDRT: Network is unreachable
rpmsg_pru rpmsg0: new rpmsg_pru device: /dev/rpmsg_pru30
rpmsg_pru rpmsg1: new rpmsg_pru device: /dev/rpmsg_pru31
random: nonblocking pool is initialized
[  OK  ] Started Telephony service.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
Bluetooth: Core ver 2.21
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
         Starting Network Service...
Bluetooth: HCI socket layer initialized
[  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Network Service.
 remoteproc7: powering up 4b2b8000.pru1
 remoteproc7: Booting fw image ti-pruss/am57xx-pru1-prueth-fw.elf, size 4382
ti-pruss 4b280000.pruss: configured system_events = 0x0060000000a00000 intr_channels = 0x0000012a host_intr = 0x0000022a
 remoteproc7: remote processor 4b2b8000.pru1 is now up
net eth5: started
 remoteproc6: powering up 4b2b4000.pru0
 remoteproc6: Booting fw image ti-pruss/am57xx-pru0-prueth-fw.elf, size 4350
NET: Registered protocol family 15
ti-pruss 4b280000.pruss: configured system_events = 0x0000060000500000 intr_channels = 0x00000095 host_intr = 0x00000115
 remoteproc6: remote processor 4b2b4000.pru0 is now up
net eth4: started
net eth3: started
genirq: Flags mismatch irq 495. 00002004 (eth2) vs. 00002000 (remoteproc4)
eth2: unable to request RX IRQ
net eth1: initializing cpsw version 1.15 (0)
libphy: PHY  not found
net eth1: phy "" not found on slave 1, err -19
Initializing XFRM netlink socket
NOTICE: This file system contains the following GPLv3 packages:
	autoconf
	binutils-dev
	binutils
	bison-dev
	bison
	cpp-symlinks
	cpp
	dosfstools
	g++-symlinks
	g++
	gawk-dev
	gawk
	gcc-symlinks
	gcc
	gdb
	gdbc6x
	gdbserver
	gstreamer1.0-libav
	hidapi
	libcairo-perf-utils
	libgmp10
	libidn11
	libmpc3
	libmpfr4
	make
	nettle
	parted
	swig-dev
	swig
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Started Print notice about GPLv3 packages.
[  OK  ] Started Login Service.
[  OK  ] Reached target Sound Card.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Reached target Network.
         Starting Lightning Fast Webserver With Light System Requirements...
         Starting Network Name Resolution...
[  OK  ] Started Serial Getty on ttyS1.
[  OK  ] Started Getty on tty1.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started Network Name Resolution.
[  OK  ] Started Lightning Fast Webserver With Light System Requirements.
cpsw 48484000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[  OK  ] Started uim-sysfs.service.
         Starting rc.pvr.service...
PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[  OK  ] Started rc.pvr.service.
         Starting tiipclad-daemon.service...
         Starting telnetd.service...
[  OK  ] Started telnetd.service.
[  OK  ] Started tiipclad-daemon.service.
         Starting thttpd.service...
[  OK  ] Started thttpd.service.
         Starting rng-tools.service...
[  OK  ] Started rng-tools.service.
         Starting gdbserverproxy.service...
[  OK  ] Started gdbserverproxy.service.
         Starting thermal-zone-init.service...
[  OK  ] Started thermal-zone-init.service.
[  OK  ] Reached target Multi-User System.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org am57xx-evm ttyS1
Arago 2016.08 am57xx-evm ttyS1
am57xx-evm login: root
root@am57xx-evm:~#
root@am57xx-evm:~#
root@am57xx-evm:~#
root@am57xx-evm:~#
root@am57xx-evm:~#
root@am57xx-evm:~# route add default gw 192.168.0.1;
root@am57xx-evm:~# ifconfig eth0 192.168.0.50 up;
root@am57xx-evm:~# mount -t nfs -o nolock,rsize=8192,wsize=8192,timeo=100,nfsvers=3 192.168.0.240:/test /test;
root@am57xx-evm:~# cd /test/URIED-TEST/;
root@am57xx-evm:/test/URIED-TEST# cd /sys/bus/platform/drivers/omap-rproc;
root@am57xx-evm:/sys/bus/platform/drivers/omap-rproc#
root@am57xx-evm:/sys/bus/platform/drivers/omap-rproc# echo 40800000.dsp > unbind;
 remoteproc2: releasing 40800000.dsp
root@am57xx-evm:/sys/bus/platform/drivers/omap-rproc# echo 40800000.dsp > bind;
root@am57xx-evm:/sys/bus/platform/drivers/omap-rproc#  remoteproc2: powering up 40800000.dsp
 remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 8009108
omap_hwmod: mmu0_dsp1: _wait_target_disable failed
omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
 remoteproc2: remote processor 40800000.dsp is now up
virtio_rpmsg_bus virtio5: rpmsg host is online
 remoteproc2: registered virtio5 (type 7)
virtio_rpmsg_bus virtio5: creating channel rpmsg-proto addr 0x3d
NET: Registered protocol family 41
The DSP PCIe Init process used the PCIe_sample_board.c code of the PDK as it was.
What is wrong?
John Kim
    Please post the complete log file and explain in details what you are trying to do.
  • Hi, Biser
    this is full error log.
    1325.PCIe-ARM Kernel Err.txt
    OMAP DSS rev 6.1
    loop: module loaded
     mmcblk0: p1
    ALSA device list:
    devtmpfs: mounted
    cemk initialized
    BMCR(0x0): 0x2100
    BMSR(0x1): 0x7849
    BMSR(0x1): 0x7849
    CR1(0x9): 0x0
    CR2(0xa): 0x0
    FLDSTS(0xF): 0x0
    PHYSTS(0x10): 0x4
    PHYSCR(0x11): 0x0
    RCSR(0x17): 0x1
    LEDCR(0x18): 0x0
    PHYCR(0x19): 0x21
    GENCFG(0x465): 0x0
    BMCR(0x0): 0x2100
    BMSR(0x1): 0x7849
    BMSR(0x1): 0x7849
    CR1(0x9): 0x0
    CR2(0xa): 0x0
    FLDSTS(0xF): 0x0
    PHYSTS(0x10): 0x4
    PHYSCR(0x11): 0x0
    RCSR(0x17): 0x1
    LEDCR(0x18): 0x0
    PHYCR(0x19): 0x20
    GENCFG(0x465): 0x0
    ==== PHY regs ===
    BMCR(0x0): 0x3100
    BMSR(0x1): 0x7849
    BMSR(0x1): 0x7849
    CR1(0x9): 0x7c00
    CR2(0xa): 0x104
    PHYSCR(0x11): 0x108
    RCSR(0x17): 0x41
    LEDCR(0x18): 0x400
    PHYCR(0x19): 0x8020
    BMCR(0x0): 0x3100
    BMSR(0x1): 0x7849
    BMSR(0x1): 0x7849
    CR1(0x9): 0x7c00
    CR2(0xa): 0x104
    FLDSTS(0xF): 0x0
    PHYSCR(0x11): 0x108
    RCSR(0x17): 0x41
    LEDCR(0x18): 0x400
    PHYCR(0x19): 0x8020
    GENCFG(0x465): 0x0
    ==== PHY regs ===
    BMCR(0x0): 0x3100
    BMSR(0x1): 0x7849
    BMSR(0x1): 0x7849
    CR1(0x9): 0x7c00
    CR2(0xa): 0x104
    PHYSCR(0x11): 0x108
    RCSR(0x17): 0x61
    LEDCR(0x18): 0x400
    PHYCR(0x19): 0x8021
    BMCR(0x0): 0x3100
    BMSR(0x1): 0x7849
    BMSR(0x1): 0x7849
    CR1(0x9): 0x7c00
    CR2(0xa): 0x104
    FLDSTS(0xF): 0x0
    PHYSCR(0x11): 0x108
    RCSR(0x17): 0x41
    LEDCR(0x18): 0x400
    PHYCR(0x19): 0x8021
    GENCFG(0x465): 0x0
    net eth5: started
    net eth4: started
    net eth3: started
    	autoconf
    	binutils-dev
    	binutils
    	bison-dev
    	bison
    	cpp-symlinks
    	cpp
    	dosfstools
    	g++-symlinks
    	g++
    	gawk-dev
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbc6x
    	gdbserver
    	gstreamer1.0-libav
    	hidapi
    	libcairo-perf-utils
    	libgmp10
    	libidn11
    	libmpc3
    	libmpfr4
    	make
    	nettle
    	parted
    	swig-dev
    	swig
     _____                    _____           _         _
                  |___|                    |___|
    root@am57xx-evm:~#
    root@am57xx-evm:~#
    root@am57xx-evm:~#
    root@am57xx-evm:~#
    root@am57xx-evm:~#
    Detail :
    This problem occurs after the DSP is started. In the process of initializing the tracking result PCIe, an error log is generated in the Arm side kernel.
    However, this problem has problems with random.
    John Kim
  • Hi, John,
    What ProcSDK release are you using?
    Do you have a PCIe device plugged into the board? what does it do?
    The PCIe shouldn't be involved in unbinding and binding the DSP.
    Could you disable PCIe and do the same practice to unbind and bind?
    Rex
  • Hi, Rex,
    I'm using pdk_am57xx_1_0_4
    It is connected to AM 5728 dsp PCIe, and the connected device plays a role of exchanging ADC Data.
    PCIe is not involved in Remote proc 's Bind / Unbind at all.
    Also, even if you delete the PCIe related routine in the DSP, it will work without problems.
    The exact problem is that the ARM Side kernel error occurs in the process of PCIe initialization in the DSP.
    John Kim
    "The DSP PCIe Init process used the PCIe_sample_board.c code of the PDK as it was."
    The PCIE can only be initialized by ARM or DSP, but not both. It looks that you used DSP code to do PCIE initialization, then in the Linux you need to disable the code, I knew some customer managed this by deleting the PCIE entry in device tree.
    If you decide to use the Linux to initialize the PCIE, then you can't run it again in DSP.
    Regards, Eric
    Thank you for your reply!
    Although the problem has not yet been solved,
    I'll give it a try.
    John kim
  • We were having similar issues and did what lding suggested - removed PCIe references from the Linux device tree.
    Gerard
    I removed the PCIe driver.
    However, a problem occurred.
    An error occurs during the process of "insmod" of pvrsrvkm.ko module.
    insmod /lib/modules/4.4.19-rt25-gf572d285f0/extra/pvrsrvkm.ko
    pvrsrvkm: disagrees about version of symbol pci_save_state
    pvrsrvkm: Unknown symbol pci_save_state (err -22)
    pvrsrvkm: disagrees about version of symbol pci_request_region
    pvrsrvkm: Unknown symbol pci_request_region (err -22)
    pvrsrvkm: disagrees about version of symbol pci_enable_device
    pvrsrvkm: Unknown symbol pci_enable_device (err -22)
    pvrsrvkm: disagrees about version of symbol pci_choose_state
    pvrsrvkm: Unknown symbol pci_choose_state (err -22)
    pvrsrvkm: disagrees about version of symbol pci_get_device
    pvrsrvkm: Unknown symbol pci_get_device (err -22)
    pvrsrvkm: disagrees about version of symbol pci_disable_msi
    pvrsrvkm: Unknown symbol pci_disable_msi (err -22)
    pvrsrvkm: disagrees about version of symbol pci_set_power_state
    pvrsrvkm: Unknown symbol pci_set_power_state (err -22)
    pvrsrvkm: disagrees about version of symbol pci_enable_msi_range
    pvrsrvkm: Unknown symbol pci_enable_msi_range (err -22)
    pvrsrvkm: disagrees about version of symbol pci_clear_master
    pvrsrvkm: Unknown symbol pci_clear_master (err -22)
    pvrsrvkm: disagrees about version of symbol drm_platform_init
    pvrsrvkm: Unknown symbol drm_platform_init (err -22)
    pvrsrvkm: disagrees about version of symbol drm_put_dev
    pvrsrvkm: Unknown symbol drm_put_dev (err -22)
    pvrsrvkm: disagrees about version of symbol pci_restore_state
    pvrsrvkm: Unknown symbol pci_restore_state (err -22)
    pvrsrvkm: disagrees about version of symbol pci_set_master
    pvrsrvkm: Unknown symbol pci_set_master (err -22)
    pvrsrvkm: disagrees about version of symbol pci_disable_device
    pvrsrvkm: Unknown symbol pci_disable_device (err -22)
    pvrsrvkm: disagrees about version of symbol drm_platform_set_busid
    pvrsrvkm: Unknown symbol drm_platform_set_busid (err -22)
    pvrsrvkm: disagrees about version of symbol pci_release_region
    pvrsrvkm: Unknown symbol pci_release_region (err -22)
    insmod: ERROR: could not insert module /lib/modules/4.4.19-rt25-gf572d285f0/extra/pvrsrvkm.ko: Invalid parameters
    John Kim
  • Hi, John,
    The bottom line is only initialize PCIe at one place. If Linux SGX needs to access PCIe, you should initialize PCIe on Linux side. In that case, DSP can still access PCIe if it needs to. Initializing PCie on DSP side, Linux doesn't have info on PCIe.
    Rex
  • Hi, Rex,
    I have a few questions.
    There are various problems when deleting PCI driver on Linux.
    Omap remote proc can not be used and PRU core can not be used.
    Also, QT's EGLFS Platform can not be used.
    Q1. When Using PCI Driver in Linux, Can DSP use PCIe Driver (initialized) ?
    Q2. When I remove "PCI Driver" in Linux, Then I can't use "Remote Proc Driver" now.
    I think OMAP-Remote proc Driver reter to PCI.... isn't it?
    John Kim
  • Hi, John,
    When Linux initializes the PCIe, DSP does not need to do it, but it can use it. Linux works on virtual addresses, but DSP can access directly the physical address. Once Linux set up the in/out bound areas, DSP can access them.
    I don't think that is a true statement that remoteproc driver uses PCIe. I can't make any sense out of it.
    Rex
  • Hi, Rex,
    It is PCI problem. It is not PCIe.
    Removing (non-PCIe) PCI drivers from Linux will cause a lot of problems.
    (Remote proc / eglfs platform / etc ..)
    My question is, can PCI drivers be used on Linux and PCIe drivers on DSP? .
    John Kim
  • Hi, John,
    The way I see it is that the PCI is the foundamental, and PCIe is an extension to the PCI. Take a look at the drivers directory structure. PCI includes PCIe subdirectory. I don't think PCIe will work by removing PCI driver.
    I thought we suggested that only one application initializes the PCIe which is Linux and DSP can access the PCIe area through direct physical address mapping.
    Rex
    I have solved it by building module inbuilt with the kernel. Strange but its working.
  • Hi, Yohan,
    Any time when Kernel configuration changed, the modules need to be rebuilt.
    Rex
