Linux/AM3351: LCD display doesn't work
Part Number: AM3351
Tool/software: Linux
hi, i am using ti-processor-sdk-03.00.00.04 for getting 24 bit LCD display on my am3351 processor based board,
i  did pinmuxing as per below i mentioned. but i am not able to find any light or color changes on my display, please suggest me what we need to take care for getting display on lcd.
///// .dts File ///
 * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License version 2 as
 * published by the Free Software Foundation.
/dts-v1/;
#include "am33xx.dtsi"
#include "am335x-bone-common.dtsi"
#include <dt-bindings/pwm/pwm.h>
#include <dt-bindings/display/tda998x.h>
    model = "TI AM335x BeagleBone Black";
    compatible = "ti,am335x-bone-black", "ti,am335x-bone", "ti,am33xx";
        backlight {
            status = "okay";
            compatible = "pwm-backlight";
            pwms = <&ehrpwm0 0 50000 0>;
            brightness-levels = <
                    0  1  2  3  4  5  6  7  8  9
                    10 11 12 13 14 15 16 17 18 19
                    20 21 22 23 24 25 26 27 28 29
                    30 31 32 33 34 35 36 37 38 39
                    40 41 42 43 44 45 46 47 48 49
                    50 51 52 53 54 55 56 57 58 59
                    60 61 62 63 64 65 66 67 68 69
                    70 71 72 73 74 75 76 77 78 79
                    80 81 82 83 84 85 86 87 88 89
                    90 91 92 93 94 95 96 97 98 99
                    100
            default-brightness-level = <50>;
    panel {
        compatible = "ti,tilcdc,panel";
        status = "okay";
        pinctrl-names = "default";
        pinctrl-0 = <&nxp_hdmi_bonelt_pins>;
        panel-info {
            ac-bias           = <255>;
            ac-bias-intrpt    = <0>;
            dma-burst-sz      = <16>;
            bpp               = <32>;
            fdd               = <0x80>;
            sync-edge         = <0>;
            sync-ctrl         = <1>;
            raster-order      = <0>;
            fifo-th           = <0>;
        display-timings {
            800x480p62 {
                clock-frequency = <30000000>;
                hactive = <800>;
                vactive = <480>;
                hfront-porch = <39>;
                hback-porch = <39>;
                hsync-len = <47>;
                vback-porch = <29>;
                vfront-porch = <13>;
                vsync-len = <2>;
                hsync-active = <1>;
                vsync-active = <1>;
&ldo3_reg {
    regulator-min-microvolt = <1800000>;
    regulator-max-microvolt = <1800000>;
    regulator-always-on;
&mmc1 {
    vmmc-supply = <&vmmcsd_fixed>;
&mmc2 {
    pinctrl-0 = <&emmc_pins>;
    bus-width = <8>;
    status = "okay";
&cpu0_opp_table {
     * All PG 2.0 silicon may not support 1GHz but some of the early
     * BeagleBone Blacks have PG 2.0 silicon which is guaranteed
     * to support 1GHz OPP so enable it for PG 2.0 on this board.
    oppnitro@1000000000 {
        opp-supported-hw = <0x06 0x0100>;
&am33xx_pinmux {
    nxp_hdmi_bonelt_pins: nxp_hdmi_bonelt_pins {
        pinctrl-single,pins = <
            0xa0 0x08       /* lcd_data0.lcd_data0, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xa4 0x08       /* lcd_data1.lcd_data1, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xa8 0x08       /* lcd_data2.lcd_data2, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xac 0x08       /* lcd_data3.lcd_data3, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xb0 0x08       /* lcd_data4.lcd_data4, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xb4 0x08       /* lcd_data5.lcd_data5, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xb8 0x08       /* lcd_data6.lcd_data6, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xbc 0x08       /* lcd_data7.lcd_data7, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xc0 0x08       /* lcd_data8.lcd_data8, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xc4 0x08       /* lcd_data9.lcd_data9, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xc8 0x08       /* lcd_data10.lcd_data10, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xcc 0x08       /* lcd_data11.lcd_data11, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xd0 0x08       /* lcd_data12.lcd_data12, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xd4 0x08       /* lcd_data13.lcd_data13, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xd8 0x08       /* lcd_data14.lcd_data14, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xdc 0x08       /* lcd_data15.lcd_data15, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
            0xe0 0x00       /* lcd_vsync.lcd_vsync, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT */
            0xe4 0x00       /* lcd_hsync.lcd_hsync, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT */
            0xe8 0x00       /* lcd_pclk.lcd_pclk, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT */
            0xec 0x00       /* lcd_ac_bias_en.lcd_ac_bias_en, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT */
                0x3c 0x09 /* lcd_data16.lcd_data16, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
                0x38 0x09 /* lcd_data17.lcd_data17, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
                0x34 0x09 /* lcd_data18.lcd_data18, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
                0x30 0x09 /* lcd_data19.lcd_data19, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
               0x2c 0x09 /* lcd_data20.lcd_data20, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
                0x28 0x09 /* lcd_data21.lcd_data21, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
                0x24 0x09 /* lcd_data22.lcd_data22, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
                0x20 0x09 /* lcd_data23.lcd_data23, OMAP_MUX_MODE1 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */
    nxp_hdmi_bonelt_off_pins: nxp_hdmi_bonelt_off_pins {
            0x1b0 0x03      /* xdma_event_intr0, OMAP_MUX_MODE3 | AM33XX_PIN_OUTPUT */
        ehrpwm0_pins: backlight_pins {
                    0x164 ( PIN_OUTPUT_PULLUP | MUX_MODE3 ) /* (U14) gpmc_a2.ehrpwm1A */
    mcasp0_pins: mcasp0_pins {
            AM33XX_IOPAD(0x9ac, PIN_INPUT_PULLUP | MUX_MODE0) /* mcasp0_ahcklx.mcasp0_ahclkx */
            AM33XX_IOPAD(0x99c, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mcasp0_ahclkr.mcasp0_axr2*/
            AM33XX_IOPAD(0x994, PIN_OUTPUT_PULLUP | MUX_MODE0) /* mcasp0_fsx.mcasp0_fsx */
            AM33XX_IOPAD(0x990, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mcasp0_aclkx.mcasp0_aclkx */
            AM33XX_IOPAD(0x86c, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_a11.GPIO1_27 */
&lcdc {
    status = "okay";
    port {
        lcdc_0: endpoint@0 {
        remote-endpoint = <&hdmi_0>;
&i2c0 {
   hdmi1: hdmi@70 {
        compatible = "nxp,tda998x";
        reg = <0x70>;
&i2c0 {
    tda19988: tda19988 {
        reg = <0x70>;
        pinctrl-names = "default", "off";
        pinctrl-1 = <&nxp_hdmi_bonelt_off_pins>;
        #sound-dai-cells = <0>;
        audio-ports = <    AFMT_I2S    0x03>;
        ports {
            port@0 {
                hdmi_0: endpoint@0 {
                    remote-endpoint = <&lcdc_0>;
&rtc {
    system-power-controller;
&epwmss0 {
    status = "okay";
          ehrpwm0: pwm@48300200{
        status = "okay";
        pinctrl-0 = <&ehrpwm0_pins>;
&mcasp0    {
    pinctrl-0 = <&mcasp0_pins>;
    status = "okay";
    op-mode = <0>;    /* MCASP_IIS_MODE */
    tdm-slots = <2>;
    serial-dir = <    /* 0: INACTIVE, 1: TX, 2: RX */
            0 0 1 0
    tx-num-evt = <32>;
    rx-num-evt = <32>;
&sgx {
    status = "okay";
    clk_mcasp0_fixed: clk_mcasp0_fixed {
        #clock-cells = <0>;
        compatible = "fixed-clock";
        clock-frequency = <24576000>;
    clk_mcasp0: clk_mcasp0 {
        #clock-cells = <0>;
        compatible = "gpio-gate-clock";
        clocks = <&clk_mcasp0_fixed>;
        enable-gpios = <&gpio1 27 0>; /* BeagleBone Black Clk enable on GPIO1_27 */
    sound {
        compatible = "simple-audio-card";
        simple-audio-card,name = "TI BeagleBone Black";
        simple-audio-card,format = "i2s";
        simple-audio-card,bitclock-master = <&dailink0_master>;
        simple-audio-card,frame-master = <&dailink0_master>;
        dailink0_master: simple-audio-card,cpu {
            sound-dai = <&mcasp0>;
            clocks = <&clk_mcasp0>;
        /*simple-audio-card,codec {
            sound-dai = <&tda19988>;
Thank you.
